Home » Modeling » EMF » Reflective Java code generator for instances ?
Reflective Java code generator for instances ? [message #539401] Thu, 10 June 2010 11:25 Go to next message
Hi all,
I'm wondering, because it looks like a pretty basic need, if anybody out
there already wrote a code generator generating, from any EMF based model,
the sequence of Java statements needed to instantiate it ?
It would be usefull for instance to capture model instances for unit
testing, the unit test is then independant of the launching mode (plugin or
not) and breaking the API compatiblity breaks the java compilation..
Anybody heard something about such a thing ?
Cédric
Re: Reflective Java code generator for instances ? [message #539476 is a reply to message #539401] Thu, 10 June 2010 17:41 Go to previous messageGo to next message
did I get you write, that you need code to instanciate a arbitrary model
completly for testing issues? We have a random generator with a
configurable depth and reference level.
But I am not sure if that what you requested ;-)
Cheers
Jonas
Cédric Brun wrote:
> Hi all,
> Cheers,
> Cédric
Re: Reflective Java code generator for instances ? [message #539645 is a reply to message #539476] Fri, 11 June 2010 11:26 Go to previous messageGo to next message
That's quite tricky to explain though not so complex todo , I'd like to
generate the java code needed to instanciate instance of a model from a
model.
Basically turning this :
<eClassifiers name="a" />
into this
EClass a = EcoreFactory.eINSTANCE.createEClass();
a.setName("a");
If nothing is available I'll write one and share it ;)
Jonas wrote:
> Cheers
> Jonas
> Cédric Brun wrote:
>> Hi all,
>> model, the sequence of Java statements needed to instantiate it ?
>> or not) and breaking the API compatiblity breaks the java compilation..
>> Cheers,
>> Cédric
Re: Reflective Java code generator for instances ? [message #539646 is a reply to message #539645] Fri, 11 June 2010 11:34 Go to previous messageGo to next message
--------------020304020907090009060207
Cédric,
Long ago I thought about writing such a thing but I don't believe anyone
else has done it.
> model.
> into this
> a.setName("a");
> Jonas wrote:
>> Hi,
>> Cheers
>> Jonas
>> Cédric Brun wrote:
>>> Hi all,
>>> Cheers,
>>> Cédric
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Cédric,<br>
<br>
anyone else has done it.<br>
<br>
<br>
Cédric Brun wrote:
<blockquote cite="mid:hutkel$kf3$1@build.eclipse.org" type="cite">
<pre wrap="">That's quite tricky to explain though not so complex todo , I'd like to
model.
&lt;eClassifiers name="a" /&gt;
into this
a.setName("a");
Jonas wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
Cheers
Jonas
Cédric Brun wrote:
</pre>
<pre wrap="">Hi all,
Cédric
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------020304020907090009060207--
Re: Reflective Java code generator for instances ? [message #539658 is a reply to message #539645] Fri, 11 June 2010 13:28 Go to previous messageGo to next message
> generate the java code needed to instanciate instance of a model from a model.
Even though you are using Ecore itself as an example, you'd like to have this available for any EMF model (described in Ecore), not just Ecore model itself, right? (For Ecore itself, doesn't EMF generator do something very similar, for small enough models?)
The output artifact is expected to be Java code that builds the instance, correct?
As far as tooling, while this surely can be done in code, model-to-text (such as Acceleo) seems a perfect fit. Ecore-to-JavaCodeModel-to text is likely an overkill? Wink
Alex
Re: Reflective Java code generator for instances ? [message #539888 is a reply to message #539658] Mon, 14 June 2010 04:20 Go to previous message
Hi Alex,
You're right, for any kind of model, as an Acceleo commiter I'll work on it
and provide it back soon ;)
Cédric
>> model.
> correct?
> likely an overkill? ;)
> Alex
Previous Topic:CDO introductory example frustration
Next Topic:EMF Validation
Current Time: Sat Jul 19 19:21:35 EDT 2025
Powered by FUDForum. Page generated in 0.04786 seconds
