Home » Archived » M2M (model-to-model transformation) » [QVTO] mapping to EType
[QVTO] mapping to EType [message #537750] Thu, 03 June 2010 10:35 Go to next message
When using QVTO, to generate an ecore, I run into this challenge
to produce a valid value for an EAttribute.eType. It needs to be an
EClassifier, which I would expect is a bunch of type literals I can
simply assign. I am not able to locate these literals.
In the end, the serialized eType value should something like this:
"ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String"
I can generate it, but it would become a new type, instead of a
reference to an existing Literal.
What would be the solution for this?
thank you,
Christophe Bouhier
Re: [QVTO] mapping to EType [message #537773 is a reply to message #537750] Thu, 03 June 2010 11:19 Go to previous messageGo to next message
Christophe,
Things like XMLTypePackage.Literals.STRING would do the trick in Java.
I'm not sure about QVTo.
Christophe Bouhier wrote:
> thank you,
> Christophe Bouhier
Re: [QVTO] mapping to EType [message #537850 is a reply to message #537750] Thu, 03 June 2010 16:22 Go to previous message
Hi Christophe ,
There were already similar threads. Please have a look at
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg03742.html
another approach for Ecore primitive types referencing
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg03752.html
ECore primitive types referencing with help of black-box
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg03939.html
for UML primitive types referencing
Sergey
> thank you,
> Christophe Bouhier
Previous Topic:[ATL] Is it possible to have elements in the target model?
Next Topic:[QVTO] standalone qvt stereotypes in profile not recognized
Current Time: Sun Jul 20 11:05:54 EDT 2025
Powered by FUDForum. Page generated in 0.04297 seconds
