Home » Modeling » EMF » Running Teneo library example MySQL/Eclipselink problem.
Running Teneo library example MySQL/Eclipselink problem. [message #537681] |
Thu, 03 June 2010 07:29  |
I have checkout the org.eclipse.emf.teneo.eclipselink.examples.library
and org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests .
For standard configuration on derby database everything works just fine, and all tests pass.
But when i want to use mysql database with persistence.xml looking like:
<persistence xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
<persistence-unit name="library" transaction-type="RESOURCE_LOCAL">
<properties>
<property name="eclipselink.session-name" value="library" />
<property name="eclipselink.logging.level" value="FINEST" />
<property name="eclipselink.logging.timestamp" value="false" />
<property name="eclipselink.logging.thread" value="false" />
<property name="eclipselink.logging.session" value="false" />
<property name="eclipselink.jdbc.bind-parameters" value="false"/>
<property name="eclipselink.target-database" value="Mysql"/>
<property name="eclipselink.jdbc.driver" value="com.mysql.jdbc.Driver"/>
<property name="eclipselink.jdbc.url" value="jdbc:mysql://localhost:3306/test"/>
<property name="eclipselink.jdbc.user" value="user"/>
<property name="eclipselink.jdbc.password" value="pass"/>
<property name="eclipselink.session.customizer" value="org.eclipse.emf.teneo.eclipselink.EmfSessionCustomizer"/>
<property name="eclipselink.jdbc.read-connections.min" value="1"/>
<property name="eclipselink.jdbc.write-connections.min" value="1"/>
<property name="eclipselink.ddl-generation.output-mode" value="database" />
<!-- Uncomment to create database schema -->
<property name="eclipselink.ddl-generation" value="drop-and-create-tables"/>
<property name="eclipselink.ddl-generation.output-mode" value="database"/>
</properties>
</persistence-unit>
</persistence>
Tests does not even run because of exceptions :
!SESSION 2010-06-03 13:09:56.532 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_24
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
Framework arguments: -version 3 -port 51300 -testLoaderClass org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestLoader -loaderpluginname org.eclipse.jdt.junit.runtime -classNames org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests.AllTests -application org.eclipse.pde.junit.runtime.coretestapplication -testpluginname org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests
Command-line arguments: -os macosx -ws carbon -arch x86 -version 3 -port 51300 -testLoaderClass org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestLoader -loaderpluginname org.eclipse.jdt.junit.runtime -classNames org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests.AllTests -application org.eclipse.pde.junit.runtime.coretestapplication -data /Users/michabartoszewski/Documents/examples/../junit-workspace -dev file:/Users/michabartoszewski/Documents/examples/.metadata/.plugins/org.eclipse.pde.core/pde-junit/dev.properties -os macosx -ws carbon -arch x86 -testpluginname org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests
!ENTRY org.eclipse.osgi 2 0 2010-06-03 13:10:01.972
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-06-03 13:10:01.972
!MESSAGE Bundle reference:file:/Applications/eclipse/dropins/mysql-connector-java-5.1.12-bin.jar was not resolved.
!SUBENTRY 2 com.mysql.jdbc 2 0 2010-06-03 13:10:01.972
!MESSAGE Missing imported package javax.xml.transform.stax_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2010-06-03 13:10:02.023
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-06-03 13:10:02.023
!MESSAGE Bundle com.mysql.jdbc_5.1.12 [6] was not resolved.
!SUBENTRY 2 com.mysql.jdbc 2 0 2010-06-03 13:10:02.023
!MESSAGE Missing imported package javax.net.ssl_[1.0.1,2.0.0).
!MESSAGE Missing imported package org.apache.log4j_[1.2.15,2.0.0).
!MESSAGE Missing imported package com.mchange.v2.c3p0_[0.9.1.2,1.0.0).
!MESSAGE Missing imported package org.jboss.resource.adapter.jdbc_0.0.0.
!SUBENTRY 2 com.mysql.jdbc 2 0 2010-06-03 13:10:02.024
!MESSAGE Missing imported package org.jboss.resource.adapter.jdbc.vendor_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-06-03 13:10:02.024
!MESSAGE Bundle org.eclipse.emf.teneo.eclipselink.examples.library_1.0.0.qualifier [199] was not resolved.
!SUBENTRY 2 org.eclipse.emf.teneo.eclipselink.examples.library 2 0 2010-06-03 13:10:02.024
!MESSAGE Missing imported package com.mysql.jdbc_5.1.12.
!MESSAGE Bundle org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests_1.0.0.qualifier [200] was not resolved.
!SUBENTRY 2 org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests 2 0 2010-06-03 13:10:02.024
!MESSAGE Missing required bundle org.eclipse.emf.teneo.eclipselink.examples.library_[1.0.0,2.0.0).
!MESSAGE Missing imported package org.hsqldb_1.8.1.
!MESSAGE Bundle org.eclipse.jdt.apt.pluggable.core_1.0.201.R35x_v20090925-1100 [348] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.apt.pluggable.core 2 0 2010-06-03 13:10:02.024
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.tool_0.0.0.
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.apt.dispatch_0.0.0.
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.apt.model_0.0.0.
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.apt.util_0.0.0.
!MESSAGE Bundle org.eclipse.jdt.compiler.apt_1.0.201.R35x_v20090925-1100 [350] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2010-06-03 13:10:02.024
!MESSAGE Bundle org.eclipse.jdt.compiler.tool_1.0.100.v_981_R35x [351] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2010-06-03 13:10:02.024
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: JavaSE-1.6
!ENTRY org.eclipse.osgi 4 0 2010-06-03 13:10:02.062
!MESSAGE Application error
!STACK 1
java.lang.IllegalArgumentException: No Classloader found for plug-in org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.getClassLoader(RemotePluginTestRunner.java:77)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.getTestClassLoader(RemotePluginTestRunner.java:71)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadClass(RemoteTestRunner.java:693)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadClasses(RemoteTestRunner.java:429)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:452)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.main(RemotePluginTestRunner.java:62)
at org.eclipse.pde.internal.junit.runtime.CoreTestApplication.run(CoreTestApplication.java:23)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:574)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!ENTRY org.eclipse.osgi 2 0 2010-06-03 13:10:02.187
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-06-03 13:10:02.187
!SUBENTRY 2 com.mysql.jdbc 2 0 2010-06-03 13:10:02.187
!ENTRY org.eclipse.osgi 2 0 2010-06-03 13:10:02.236
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-06-03 13:10:02.236
!SUBENTRY 2 com.mysql.jdbc 2 0 2010-06-03 13:10:02.236
!SUBENTRY 2 org.eclipse.emf.teneo.eclipselink.examples.library 2 0 2010-06-03 13:10:02.236
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-06-03 13:10:02.237
!SUBENTRY 2 org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests 2 0 2010-06-03 13:10:02.237
!SUBENTRY 2 org.eclipse.jdt.apt.pluggable.core 2 0 2010-06-03 13:10:02.237
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2010-06-03 13:10:02.237
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2010-06-03 13:10:02.237
I suspect that something with osgi execution environment is going wrong.
Bundle reference:file:/Applications/eclipse/dropins/mysql-connector -java-5.1.12-bin.jar was not resolved.
I am 100% sure about that this package is there.
My manifest for library example looks like:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %pluginName
Bundle-SymbolicName: org.eclipse.emf.teneo.eclipselink.examples.library;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-ClassPath: .
Bundle-Activator: org.eclipse.emf.teneo.eclipselink.examples.library.Activator$Implementation
Bundle-Vendor: %providerName
Bundle-Localization: plugin
Bundle-RequiredExecutionEnvironment: J2SE-1.5,
JavaSE-1.6
Export-Package: META-INF,
org.eclipse.emf.teneo.eclipselink.examples.library,
org.eclipse.emf.teneo.eclipselink.examples.library.forum,
org.eclipse.emf.teneo.eclipselink.examples.library.forum.impl,
org.eclipse.emf.teneo.eclipselink.examples.library.forum.util,
org.eclipse.emf.teneo.eclipselink.examples.library.impl,
org.eclipse.emf.teneo.eclipselink.examples.library.util
Require-Bundle: org.eclipse.core.runtime;bundle-version="[3.5.0,4.0.0)",
org.eclipse.emf.ecore;bundle-version="[2.5.0,3.0.0)",
org.eclipse.emf.teneo.eclipselink;bundle-version="[1.0.0,2.0.0)",
org.eclipse.emf.teneo.orm;bundle-version="[1.0.0,2.0.0)"
Bundle-ActivationPolicy: lazy
Import-Package: com.mysql.jdbc;version="5.1.12"
JPA-PersistenceUnits: library
my manifest for library.orm.tests
looks like:
Bundle-SymbolicName: org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests; singleton:=true
Require-Bundle: org.eclipse.core.resources,
org.eclipse.emf.ecore,
org.eclipse.emf.ecore.xmi;bundle-version="[2.5.0,3.0.0)",
org.junit;bundle-version="[3.8.0,5.0.0)",
javax.persistence;bundle-version="1.99.0",
org.eclipse.emf.teneo.eclipselink.examples.library;bundle-version="[1.0.0,2.0.0)",
org.apache.derby;bundle-version="[10.1.2,11.0.0)",
org.eclipse.persistence.jpa;bundle-version="1.1.3",
org.eclipse.persistence.asm;bundle-version="1.1.3",
org.eclipse.persistence.antlr;bundle-version="1.1.3",
org.eclipse.emf.teneo.eclipselink.elistfactory;bundle-version="[1.0.0,2.0.0)",
org.eclipse.emf.teneo.orm;bundle-version="1.0.0",
org.eclipse.core.runtime;bundle-version="3.5.0"
JavaSE-1.6
Import-Package: org.hsqldb;version="1.8.1";resolution:=optional
Does any one have some ideas what i can be doing wrong ?
With regards
e1n
P.S.
However when i set resolution of com.mysql.jdbc boundle as optional i get following erros:
[EL Severe]: Local Exception Stack:
Exception [EclipseLink-4003] (Eclipse Persistence Services - 1.1.3.v20091002-r5404): org.eclipse.persistence.exceptions.DatabaseException
Exception Description: Configuration error. Class [com.mysql.jdbc.Driver] not found.
at org.eclipse.persistence.exceptions.DatabaseException.configurationErrorClassNotFound(DatabaseException.java:82)
at org.eclipse.persistence.sessions.DefaultConnector.loadDriverClass(DefaultConnector.java:265)
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:84)
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.connectInternal(DatasourceAccessor.java:324)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.connectInternal(DatabaseAccessor.java:276)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.connect(DatasourceAccessor.java:407)
at org.eclipse.persistence.sessions.server.ConnectionPool.buildConnection(ConnectionPool.java:130)
at org.eclipse.persistence.sessions.server.ConnectionPool.startUp(ConnectionPool.java:376)
at org.eclipse.persistence.sessions.server.ServerSession.connect(ServerSession.java:502)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.login(DatabaseSessionImpl.java:629)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:229)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:255)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getServerSession(EntityManagerFactoryImpl.java:112)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:164)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:151)
at org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests.JPATest.setUp(JPATest.java:50)
at junit.framework.TestCase.runBare(TestCase.java:128)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at junit.framework.TestSuite.runTest(TestSuite.java:230)
at junit.framework.TestSuite.run(TestSuite.java:225)
at org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestReference.run(JUnit3TestReference.java:130)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
[Updated on: Thu, 03 June 2010 07:37] by Moderator
Re: Running Teneo library example MySQL/Eclipselink problem. [message #537705 is a reply to message #537681] |
Thu, 03 June 2010 08:26   |
Hi Michel,
Are you sure that the mysql jar file is a valid osgi bundle?
You can install a mysql plugin from this update site location: http://www.elver.org/eclipse/update
gr. Martin
e1n wrote:
> and all tests pass.
> <properties> <property
> value="false"/>
> value="org.eclipse.emf.teneo.eclipselink.EmfSessionCustomizer "/>
> <property
> value="1"/>
> value="database" />
> value="database"/>
> </properties>
> </persistence-unit>
> </persistence>
> org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestLoade r
> org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests .AllTests
> -testpluginname
> /Users/michabartoszewski/Documents/examples/../junit-workspa ce -dev
> file:/Users/michabartoszewski/Documents/examples/.metadata/. plugins/org.eclipse.pde.core/pde-junit/dev.properties
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle com.mysql.jdbc_5.1.12 was not resolved.
> !MESSAGE Bundle
> org.eclipse.emf.teneo.eclipselink.examples.library_1.0.0.qua lifier
> was not resolved.
> !MESSAGE Bundle
> org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests _1.0.0.qualifier
> was not resolved.
> org.eclipse.emf.teneo.eclipselink.examples.library_[1.0.0,2. 0.0).
> !MESSAGE Bundle
> org.eclipse.jdt.apt.pluggable.core_1.0.201.R35x_v20090925-11 00 was
> not resolved.
> was not resolved.
> was not resolved.
> JavaSE-1.6
> !STACK 1
> at
> org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.getClassLoader(RemotePluginTestRunner.java:77)
> at
> org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.getTestClassLoader(RemotePluginTestRunner.java:71)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lass(RemoteTestRunner.java:693)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lasses(RemoteTestRunner.java:429)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:452)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:683)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:390)
> at
> org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:62)
> at
> org.eclipse.pde.internal.junit.runtime.CoreTestApplication.r un(CoreTestApplication.java:23)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at
> org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at
> at
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> not resolved.
> was not resolved.
> was not resolved.
> JavaSE-1.6
> org.eclipse.emf.teneo.eclipselink.examples.library;singleton :=true
> Bundle-ClassPath: .
> Bundle-Activator:
> org.eclipse.emf.teneo.eclipselink.examples.library.Activator $Implementation
> JavaSE-1.6
> org.eclipse.emf.teneo.eclipselink.examples.library.forum.imp l,
> org.eclipse.emf.teneo.eclipselink.examples.library.forum.uti l,
> org.eclipse.emf.teneo.eclipselink;bundle-version="[1.0.0,2.0.0) ",
> looks like:
> org.eclipse.emf.teneo.eclipselink.examples.library.orm.tests ;
> singleton:=true
> org.eclipse.emf.teneo.eclipselink.examples.library;bundle-ve rsion= "[1.0.0,2.0.0)",
> org.eclipse.emf.teneo.eclipselink.elistfactory;bundle-versio n= "[1.0.0,2.0.0)",
> JavaSE-1.6
> With regards
> e1n
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Running Teneo library example MySQL/Eclipselink problem. [message #537727 is a reply to message #537720] |
Thu, 03 June 2010 09:26  |
Hi Michal,
Here is another hint :-), if you are developing for a web (server) environment then the Texo project maybe of interest
to you. It generates pure java pojo's and also the ORM. The Texo project uses a different (more handy) way of annotating
the model with orm annotations.
http://wiki.eclipse.org/Texo
e1n wrote:
> Thank you Martin, your hint solved the problem.
The Netherlands
Current Time: Sat Jul 19 08:44:41 EDT 2025
Powered by FUDForum. Page generated in 0.77453 seconds
