Home » Archived » M2M (model-to-model transformation) » [ATL] I can't find the button "Inject KM3 to Ecore metamodel"
[ATL] I can't find the button "Inject KM3 to Ecore metamodel" [message #536653] Sat, 29 May 2010 06:17 Go to next message
Hello all
I am doing my Master Thesis about M2M transformation and I will do it with ATL. I started to read the "ATL Starter Guide.pdf" and try to do it actively in Eclipse nearby.
I wrote now my first *.km3 file and tried to press the "Inject KM3 to Ecore metamodel" button. The problem is that this button is not available. Do you have any clue how I can get this button?
I am using the Galileo version of Eclipse, with the additional "Eclipse Modeling Project" Package. Thanks for your help.
Cheers Roger
Re: [ATL] I can't find the button "Inject KM3 to Ecore metamodel" [message #537502 is a reply to message #536653] Wed, 02 June 2010 12:30 Go to previous messageGo to next message
The KM3 was the way to write the metamodels in the older versions of Eclipse, with the newer version all you have to do is to design it with the new ecore graphical design ...and then make your transformation with *.ecore meta model ...
Hope I helped !
Re: [ATL] I can't find the button "Inject KM3 to Ecore metamodel" [message #537508 is a reply to message #537502] Wed, 02 June 2010 12:53 Go to previous message
If you like editing meta-models textually, the new OCLinEcore Xtext
editor supports direct textual editing of a *.ecore file including
support for embedded OCL class invariants, property derivations, and
operation bodies.
See the OCLinEcore tutorial in the Helios OCL Documentation.
Ed Willink
On 02/06/2010 17:30, zoro wrote:
> Hello,
> Hope I helped !
Previous Topic:[QVTo] xmi:id getting/setting possible?
Next Topic:how to check the type of a property if it is String
Current Time: Sat Jul 19 10:23:40 EDT 2025
Powered by FUDForum. Page generated in 0.03397 seconds
