[Acceleo] Launching java services from a .mtl file [message #537355] |
Wed, 02 June 2010 03:38  |
Hi all and thank you for your help.
This doubt may seem very simple but I would like you to help me.
In Acceleo 2.7 when you wanted to use a java service you only had to import it:
import org.acceleo.module.pim.uml21.gen.java.services.Common
That way you could use the Common.java services.
How do I do this in Acceleo 3 using .mtls?
Thank you very much.
Re: [Acceleo] Launching java services from a .mtl file [message #537465 is a reply to message #537386] |
Wed, 02 June 2010 10:30   |
Hi again, I am trying but I am having some trouble.
1.
I am using the wizard to create templates with querys to my java modules but I get errors and I dont know exactly how invoke goes. I mean I have a Java file with:
public class Common {
public String addQuote(String value) {......
It creates me:
[query public addQuote(arg0 : String) : String
= invoke('org.acceleo.module.pim.uml21.gen.java.services.Commo n', 'addQuote(java.lang.String)', Sequence{arg0}) /]
Ok so the invoke goes like this:
invoke('path to file', 'method(parameters)', ??? )
What is the third parameter? I mean suppos I want to use this service in a class.name, how would I do that?
I think if I do it with the query it would be :
[addQuote(class.name)]
but I dont know if the way to do it would be:
[class.name.addQuote()]
Ok, and also if I dont want to use the query and I want to use invoke directly how would it be?
invoke('org.acceleo.module.pim.uml21.gen.java.services.Commo n', 'addQuote(java.lang.String)', Sequence{class.name}) /]
2.
Thats one problem, the other problems are that some of the generated querys are incorrect, for example in Acceleo 2.7 I used:
import org.eclipse.uml2.uml.Classifier;
public class Service {
public Classifier[] hasName(Classifier cl){ .....
And the generated query is:
[query public hasName(arg0 : Classifier) : Classifier;
= invoke('org.acceleo.module.pim.uml21.gen.java.services.Servi ce', 'hasName(org.eclipse.uml2.uml.Classifier)', Sequence{arg0}) /]
But there is an error:
"Invalid Type: Classifier"
How do I fix this?
3.
Finally my other problem is that I used a java services file which used this packages:
import fr.obeo.acceleo.gen.template.eval.ENode;
import fr.obeo.acceleo.tools.AcceleoToolsPlugin;
Which are from Acceleo 2.7, and now, having installed the 3.0.0 version it produces errors. What should I do? Import the packages from Acceleo 2.7 or is there any equivalent in 3.0.0?
Re: [Acceleo] Launching java services from a .mtl file [message #537486 is a reply to message #537465] |
Wed, 02 June 2010 11:21   |
--------------080500060407040406050103
Hi Daniel,
See my comments inlined below.
Laurent Goubet
Obeo
> 1.
> a Java file with:
> It creates me:
Yup, the query is good.
The third parameter of the "invoke" service is a Sequence containing all
of the arguments of your own service. If your service is "test(String,
String)" you pass a Sequence containing two Strings to the invoke service.
Both are okay. addQuote(class.name) is MTL's way, class.name.addQuote()
is more of an Acceleo way. We decided to allow both of these in our
implementation as the MTL specification doesn't forbid the second, and
we think it is easier.
Yep, that's it. The wrapper query only makes it easier to isolate calls
to a given Java service, and makes reading the template easier.
I for one would rather read
[class.name.addQuote().replace('test', 'thing')/]
instead of
[invoke('org.acceleo.module.pim.uml21.gen.java.services.Comm on'
'addQuote(java.lang.String)', Sequence{class.name}).replace('test',
'thing')/]
> 2.
> How do I fix this?
This would mean you haven't imported the UML model in the module header
of that query : [module test('<UML metamodel URI>')].
You do know you can now call EOperations directly from the generation
module instead of using Java services for each call? For example you can
use [classifier.hasValue(stereotype, 'value')/] directly... don't know
if this help in this particular case.
> 3.
> this packages:
I don't know why you used both of these classes in your Java service,
but they no longer exist in Acceleo 3.0. You could import the package
from Acceleo 2... but that would serve no purpose since you'll never get
elements of type "ENode" in Acceleo 3.
You should look at the java method making use of these classes and see
if they are useful. You'll most likely end up removing the references
altogether, but don't hesitate to come back to us if you can't find a
way to work around these imports.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------080500060407040406050103--
Re: [Acceleo] Launching java services from a .mtl file [message #538297 is a reply to message #538190] |
Mon, 07 June 2010 04:18   |
--------------040405080606030200000007
Hi Daniel,
2- Is the ';' behind "Classifier" a generated character? There shouldn't
be anything between the return type of the query and the "=" character.
This should be :
[query public hasName(arg0 : Classifier) : Classifier =
If that doesn't do the trick, does qualifying the types help? (Replacing
"Classifier" with "uml::Classifier".)
3- I know some of the Acceleo 2 services used those ... but they were
internal of the tool and thus have no equivalent in Acceleo 3. Please
let us know if you don't manage to port equivalent services.
Laurent Goubet
Obeo
Daniel wrote:
> Hi again and thank you for your help, you have solved me a lot of
> problems :d
> Nevertheless I still have doubts about point 2:
> 2-
> I generated this module:
> [module service('http://www.eclipse.org/uml2/2.1.0/UML')/]
> So I am importing the metamodel but it stills tells me:
> "Invalid type: Classifier"
> This is the beginning of the Java class:
> package org.acceleo.module.pim.uml21.gen.java.services;
> import org.eclipse.uml2.uml.Operation;
> import org.eclipse.uml2.uml.Class;
> import org.eclipse.uml2.uml.Interface;
> public Classifier[] hasName(Classifier cl){....
> I thought that using the org.eclipse.uml2.uml it would be enough
> importing 'http://www.eclipse.org/uml2/2.1.0/UML' in the module.
> Also when I use the method "hasName" it doesnt really do anything about
> "hasName", its only a bad name. The service does things that I cant
> solve using EOperations.
> 3-
> I was trying to migrate an Acceleo 2 module that used a service which
> imported:
> Thats why I used them, so I would try to figure out how can I migrate it
> without using them.
> Thank you very much again!
--------------040405080606030200000007--
FUDForum. Page generated in 0.05103 seconds
