Home » Language IDEs » ServerTools (WTP) » m2eclipse mojo Exceptions(Exceptions when creating from archetype or updating project config)
m2eclipse mojo Exceptions [message #537266] Tue, 01 June 2010 13:51
Forgive me if this is the wrong forum to post this question, but the m2eclipse mailing list appears to be down (user-subscribe@m2eclipse.codehaus.org). I have even sent an email to 'info@sonatype.com' about not being able to subscribe, but have yet to receive a response.
If there is a better list/forum, please let me know.
I get an error when creating a new Maven project based on an archetype (see error 1 attache). The project still seems to be created, but I would like to know why I'm getting the error, what if any ramifications it may have and ideally how to fix it.
Also, when I try to update the project created from the archetype, I get an error (see error 2 below).
The archetype I used is org.codehaus.mojo.archetypes ejb-javaee6 and I'm using Galileo with m2eclipse.
I then manually updated my .project file and added:
<buildCommand>
    <name>org.eclipse.wst.common.project.facet.core.builder</name>
    <arguments>
    </arguments>
</buildCommand>
		<nature>org.eclipse.jem.workbench.JavaEMFNature</nature>
<nature>org.eclipse.wst.common.modulecore.ModuleCoreNature</nature>
<nature>org.eclipse.wst.common.project.facet.core.nature</nature>
So that I could add the EJB Module and JPA facets to the project.
Thanks for any insight!
ERROR 1:
eclipse.buildId=unknown
java.version=1.6.0_18
Framework arguments:  -product org.eclipse.epp.package.jee.product
Command-line arguments:  -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
Error
Tue Jun 01 11:01:51 MDT 2010
Could not get mojo execution paramater value
org.apache.maven.plugin.PluginResolutionException: Plugin org.apache.maven.plugins:maven-compiler-plugin:2.0.2 or one of its dependencies could not be resolved: Missing:
1) javax:javaee-endorsed-api:jar:6.0
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=javax -DartifactId=javaee-endorsed-api -Dversion=6.0 -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=javax -DartifactId=javaee-endorsed-api -Dversion=6.0 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
  	1) org.apache.maven.plugins:maven-compiler-plugin:maven-plugin:2.0.2
  	2) javax:javaee-endorsed-api:jar:6.0
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2, releases=true, snapshots=false)
	at org.apache.maven.plugin.internal.DefaultMavenPluginManager.resolvePluginArtifacts(DefaultMavenPluginManager.java:453)
	at org.apache.maven.plugin.internal.DefaultMavenPluginManager.createPluginRealm(DefaultMavenPluginManager.java:360)
	at org.apache.maven.plugin.internal.DefaultMavenPluginManager.setupPluginRealm(DefaultMavenPluginManager.java:311)
	at org.maven.ide.eclipse.internal.project.EclipseMavenPluginManager.setupPluginRealm(EclipseMavenPluginManager.java:42)
	at org.apache.maven.plugin.DefaultBuildPluginManager.getPluginRealm(DefaultBuildPluginManager.java:184)
	at org.maven.ide.eclipse.internal.embedder.MavenImpl.getMojoParameterValue(MavenImpl.java:597)
	at org.maven.ide.eclipse.project.configurator.AbstractProjectConfigurator.getParameterValue(AbstractProjectConfigurator.java:173)
	at org.maven.ide.eclipse.jdt.internal.AbstractJavaProjectConfigurator.getCompilerLevel(AbstractJavaProjectConfigurator.java:390)
	at org.maven.ide.eclipse.jdt.internal.AbstractJavaProjectConfigurator.collectOptions(AbstractJavaProjectConfigurator.java:352)
	at org.maven.ide.eclipse.jdt.internal.AbstractJavaProjectConfigurator.configure(AbstractJavaProjectConfigurator.java:102)
	at org.maven.ide.eclipse.project.configurator.AbstractLifecycleMapping.configure(AbstractLifecycleMapping.java:57)
	at org.maven.ide.eclipse.internal.project.GenericLifecycleMapping.configure(GenericLifecycleMapping.java:48)
	at org.maven.ide.eclipse.internal.project.ProjectConfigurationManager.updateProjectConfiguration(ProjectConfigurationManager.java:332)
	at org.maven.ide.eclipse.internal.project.ProjectConfigurationManager.configureNewMavenProject(ProjectConfigurationManager.java:267)
	at org.maven.ide.eclipse.internal.project.ProjectConfigurationManager.importProjects(ProjectConfigurationManager.java:175)
	at org.maven.ide.eclipse.internal.project.ProjectConfigurationManager.createArchetypeProject(ProjectConfigurationManager.java:498)
	at org.maven.ide.eclipse.wizards.MavenProjectWizard$5.runInWorkspace(MavenProjectWizard.java:279)
	at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
Caused by: org.apache.maven.artifact.resolver.MultipleArtifactsNotFoundException: Missing:
  Path to dependency:
for artifact:
	at org.apache.maven.artifact.resolver.DefaultResolutionErrorHandler.throwErrors(DefaultResolutionErrorHandler.java:71)
	at org.apache.maven.plugin.internal.DefaultMavenPluginManager.resolvePluginArtifacts(DefaultMavenPluginManager.java:449)
	... 18 more
ERROR 2:
!SESSION 2010-05-26 14:47:38.780 -----------------------------------------------
This is a continuation of log file C:\Documents and Settings\sorton\workspace\.metadata\.bak_0.log
Created Time: 2010-05-26 16:25:27.610
!ENTRY org.eclipse.core.resources 4 1 2010-05-26 16:25:27.610
!MESSAGE Core exception while retrieving the content description
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource is out of sync with the file system: '/NxxTrackingQueryTool/target/NxxTrackingQueryTool-0.1-SNAPSHOT.war'.
	at org.eclipse.core.internal.resources.File.checkSynchronized(File.java:104)
	at org.eclipse.core.internal.resources.File.getContentDescription(File.java:268)
	at org.eclipse.core.internal.propertytester.FilePropertyTester.testContentType(FilePropertyTester.java:67)
	at org.eclipse.core.internal.propertytester.FilePropertyTester.test(FilePropertyTester.java:43)
	at org.eclipse.core.internal.expressions.Property.test(Property.java:58)
	at org.eclipse.core.internal.expressions.TestExpression.evaluate(TestExpression.java:99)
	at org.eclipse.core.internal.expressions.CompositeExpression.evaluateOr(CompositeExpression.java:68)
	at org.eclipse.core.internal.expressions.OrExpression.evaluate(OrExpression.java:21)
	at org.eclipse.core.internal.expressions.CompositeExpression.evaluateAnd(CompositeExpression.java:53)
	at org.eclipse.core.internal.expressions.AdaptExpression.evaluate(AdaptExpression.java:91)
	at org.eclipse.core.internal.expressions.AndExpression.evaluate(AndExpression.java:29)
	at org.eclipse.ui.internal.dialogs.RegistryPageContributor.failsEnablement(RegistryPageContributor.java:260)
	at org.eclipse.ui.internal.dialogs.RegistryPageContributor.isApplicableTo(RegistryPageContributor.java:209)
	at org.eclipse.ui.internal.dialogs.PropertyPageContributorManager.getApplicableContributors(PropertyPageContributorManager.java:199)
	at org.eclipse.ui.dialogs.PropertyDialogAction.hasPropertyPagesFor(PropertyDialogAction.java:104)
	at org.eclipse.ui.dialogs.PropertyDialogAction.isApplicableForSelection(PropertyDialogAction.java:146)
	at org.eclipse.ui.dialogs.PropertyDialogAction.isApplicableForSelection(PropertyDialogAction.java:126)
	at org.eclipse.ui.internal.navigator.resources.actions.PropertiesActionProvider.fillContextMenu(PropertiesActionProvider.java:62)
	at org.eclipse.ui.navigator.NavigatorActionService.addCommonActionProviderMenu(NavigatorActionService.java:220)
	at org.eclipse.ui.navigator.NavigatorActionService.fillContextMenu(NavigatorActionService.java:174)
	at org.eclipse.ui.navigator.CommonNavigatorManager.fillContextMenu(CommonNavigatorManager.java:277)
	at org.eclipse.ui.navigator.CommonNavigatorManager$4.menuAboutToShow(CommonNavigatorManager.java:292)
	at org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuManager.java:338)
	at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:469)
	at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:465)
	at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:491)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:235)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
	at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java:4270)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:3974)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:342)
	at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1578)
	at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2010)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4619)
	at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
	at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:254)
	at org.eclipse.swt.widgets.Display.runPopups(Display.java:3936)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3497)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!SUBENTRY 1 org.eclipse.core.resources 4 274 2010-05-26 16:25:27.610
!MESSAGE Resource is out of sync with the file system: '/NxxTrackingQueryTool/target/NxxTrackingQueryTool-0.1-SNAPSHOT.war'.
!STACK 1
!STACK 1
!ENTRY org.eclipse.search 4 0 2010-05-26 16:28:40.297
!MESSAGE Problems encountered during text search.
!SUBENTRY 1 org.eclipse.search 4 4 2010-05-26 16:28:40.297
!MESSAGE File 'NxxTrackingQueryTool/target/NxxTrackingQueryTool-0.1-SNAPSHOT.war' has been skipped, problem while reading: ('Resource is out of sync with the file system: '/NxxTrackingQueryTool/target/NxxTrackingQueryTool-0.1-SNAPSHOT.war'.').
!STACK 1
	at org.eclipse.core.internal.localstore.FileSystemResourceManager.read(FileSystemResourceManager.java:664)
	at org.eclipse.core.internal.resources.File.getContents(File.java:288)
	at org.eclipse.core.internal.resources.File.getContents(File.java:277)
	at org.eclipse.search.internal.core.text.FileCharSequenceProvider$FileCharSequence.getInputStream(FileCharSequenceProvider.java:283)
	at org.eclipse.search.internal.core.text.FileCharSequenceProvider$FileCharSequence.initializeReader(FileCharSequenceProvider.java:277)
	at org.eclipse.search.internal.core.text.FileCharSequenceProvider$FileCharSequence.reset(FileCharSequenceProvider.java:269)
	at org.eclipse.search.internal.core.text.FileCharSequenceProvider.newCharSequence(FileCharSequenceProvider.java:40)
	at org.eclipse.search.internal.core.text.TextSearchVisitor.processFile(TextSearchVisitor.java:260)
	at org.eclipse.search.internal.core.text.TextSearchVisitor.processFiles(TextSearchVisitor.java:196)
	at org.eclipse.search.internal.core.text.TextSearchVisitor.search(TextSearchVisitor.java:172)
	at org.eclipse.search.internal.core.text.TextSearchVisitor.search(TextSearchVisitor.java:184)
	at org.eclipse.search.core.text.TextSearchEngine$1.search(TextSearchEngine.java:54)
	at org.eclipse.search.internal.ui.text.FileSearchQuery.run(FileSearchQuery.java:182)
	at org.eclipse.search2.internal.ui.InternalSearchUI$InternalSearchJob.run(InternalSearchUI.java:91)
!SUBENTRY 2 org.eclipse.core.resources 4 274 2010-05-26 16:28:40.297
!ENTRY org.eclipse.jst.jsp.core 2 2 2010-05-27 08:57:15.188
!MESSAGE Taglib Index IOException: C:/Program Files/OpenOffice.org 3/URE/bin/ C:\Program Files\OpenOffice.org 3\URE\bin (Access is denied)
!ENTRY org.eclipse.core.resources 4 4 2010-05-27 13:30:52.817
!MESSAGE Exception loading preferences from: /TestJPA/.settings/org.eclipse.wst.ws.service.policy.prefs.
!STACK 1
org.eclipse.core.runtime.CoreException: File not found: C:\Documents and Settings\sorton\workspace\TestJPA\.settings\org.eclipse.wst.ws.service.policy.prefs.
	at org.eclipse.core.internal.filesystem.Policy.error(Policy.java:55)
	at org.eclipse.core.internal.filesystem.local.LocalFile.openInputStream(LocalFile.java:371)
	at org.eclipse.core.internal.localstore.FileSystemResourceManager.read(FileSystemResourceManager.java:667)
	at org.eclipse.core.internal.resources.ProjectPreferences.load(ProjectPreferences.java:457)
	at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:307)
	at org.eclipse.core.internal.preferences.EclipsePreferences.getChild(EclipsePreferences.java:412)
	at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:541)
	at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:669)
	at org.eclipse.core.internal.resources.ProjectPreferences.deleted(ProjectPreferences.java:111)
	at org.eclipse.core.internal.resources.ProjectPreferences.deleted(ProjectPreferences.java:162)
	at org.eclipse.core.internal.resources.Resource.deleteResource(Resource.java:790)
	at org.eclipse.core.internal.localstore.RefreshLocalVisitor.deleteResource(RefreshLocalVisitor.java:99)
	at org.eclipse.core.internal.localstore.RefreshLocalAliasVisitor.deleteResource(RefreshLocalAliasVisitor.java:41)
	at org.eclipse.core.internal.localstore.RefreshLocalVisitor.synchronizeExistence(RefreshLocalVisitor.java:186)
	at org.eclipse.core.internal.localstore.RefreshLocalVisitor.visit(RefreshLocalVisitor.java:290)
	at org.eclipse.core.internal.localstore.UnifiedTree.accept(UnifiedTree.java:107)
	at org.eclipse.core.internal.localstore.FileSystemResourceManager.refreshResource(FileSystemResourceManager.java:784)
	at org.eclipse.core.internal.localstore.FileSystemResourceManager.refresh(FileSystemResourceManager.java:768)
	at org.eclipse.core.internal.resources.Resource.refreshLocal(Resource.java:1528)
	at org.eclipse.core.internal.localstore.DeleteVisitor.delete(DeleteVisitor.java:72)
	at org.eclipse.core.internal.localstore.DeleteVisitor.visit(DeleteVisitor.java:150)
	at org.eclipse.core.internal.localstore.FileSystemResourceManager.delete(FileSystemResourceManager.java:254)
	at org.eclipse.core.internal.resources.ResourceTree.internalDeleteFolder(ResourceTree.java:351)
	at org.eclipse.core.internal.resources.ResourceTree.internalDeleteProject(ResourceTree.java:386)
	at org.eclipse.core.internal.resources.ResourceTree.standardDeleteProject(ResourceTree.java:832)
	at org.eclipse.core.internal.resources.Resource.unprotectedDelete(Resource.java:1772)
	at org.eclipse.core.internal.resources.Resource.delete(Resource.java:724)
	at org.eclipse.core.internal.resources.Project.delete(Project.java:309)
	at org.eclipse.ltk.core.refactoring.resource.DeleteResourceChange.perform(DeleteResourceChange.java:130)
	at org.eclipse.ltk.core.refactoring.CompositeChange.perform(CompositeChange.java:278)
	at org.eclipse.ltk.core.refactoring.PerformChangeOperation$1.run(PerformChangeOperation.java:260)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1800)
	at org.eclipse.ltk.core.refactoring.PerformChangeOperation.executeChange(PerformChangeOperation.java:308)
	at org.eclipse.ltk.internal.ui.refactoring.UIPerformChangeOperation.executeChange(UIPerformChangeOperation.java:92)
	at org.eclipse.ltk.core.refactoring.PerformChangeOperation.run(PerformChangeOperation.java:220)
	at org.eclipse.ltk.internal.ui.refactoring.WorkbenchRunnableAdapter.run(WorkbenchRunnableAdapter.java:87)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: java.io.FileNotFoundException: C:\Documents and Settings\sorton\workspace\TestJPA\.settings\org.eclipse.wst.ws.service.policy.prefs (The system cannot find the file specified)
	at java.io.FileInputStream.open(Native Method)
	at java.io.FileInputStream.<init>(FileInputStream.java:106)
	at org.eclipse.core.internal.filesystem.local.LocalFile.openInputStream(LocalFile.java:362)
	... 39 more
!SUBENTRY 1 org.eclipse.core.filesystem 4 271 2010-05-27 13:30:52.817
!MESSAGE File not found: C:\Documents and Settings\sorton\workspace\TestJPA\.settings\org.eclipse.wst.ws.service.policy.prefs.
!STACK 0
!ENTRY org.eclipse.equinox.preferences 4 4 2010-05-27 13:30:52.817
!MESSAGE Exception loading preferences from: C:/Documents and Settings/sorton/workspace/TestJPA/.settings/org.eclipse.wst.ws.service.policy.prefs.
!STACK 0
org.osgi.service.prefs.BackingStoreException: Exception loading preferences from: /TestJPA/.settings/org.eclipse.wst.ws.service.policy.prefs.
	at org.eclipse.core.internal.resources.ProjectPreferences.load(ProjectPreferences.java:462)
!ENTRY org.eclipse.ltk.ui.refactoring 4 10000 2010-05-27 13:30:53.082
!MESSAGE Internal Error
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Problems encountered while deleting resources.
	at org.eclipse.core.internal.resources.Resource.delete(Resource.java:737)
Contains: Could not delete '/TestJPA/.settings'.
	at org.eclipse.core.internal.localstore.FileSystemResourceManager.delete(FileSystemResourceManager.java:257)
Contains: Problems encountered while deleting files.
Contains: Could not delete: C:\Documents and Settings\sorton\workspace\TestJPA\.settings\org.eclipse.wst.common.component.
Contains: Could not delete: C:\Documents and Settings\sorton\workspace\TestJPA\.settings.
Contains: Could not delete 'C:\Documents and Settings\sorton\workspace\TestJPA'.
!SUBENTRY 1 org.eclipse.core.resources 4 273 2010-05-27 13:30:53.082
!MESSAGE Problems encountered while deleting resources.
!SUBENTRY 2 org.eclipse.core.resources 4 273 2010-05-27 13:30:53.082
!MESSAGE Could not delete '/TestJPA/.settings'.
!STACK 1
!SUBENTRY 3 org.eclipse.core.resources 4 273 2010-05-27 13:30:53.082
!SUBENTRY 4 org.eclipse.core.filesystem 4 273 2010-05-27 13:30:53.082
!MESSAGE Problems encountered while deleting files.
!SUBENTRY 5 org.eclipse.core.filesystem 4 273 2010-05-27 13:30:53.082
!MESSAGE Could not delete: C:\Documents and Settings\sorton\workspace\TestJPA\.settings\org.eclipse.wst.common.component.
!MESSAGE Could not delete: C:\Documents and Settings\sorton\workspace\TestJPA\.settings.
!MESSAGE Could not delete 'C:\Documents and Settings\sorton\workspace\TestJPA'.
!ENTRY org.eclipse.core.resources 4 273 2010-05-27 13:30:53.082
!STACK 1
!SUBENTRY 3 org.eclipse.core.filesystem 4 273 2010-05-27 13:30:53.082
!ENTRY com.sun.enterprise.jst.server.sunappsrv 1 1 2010-05-27 17:16:57.365
!MESSAGE GlassFish: STOP IS CALLED!!!!!!!!!!!!!!!!
!ENTRY org.eclipse.hyades.trace.ui 4 0 2010-05-27 17:16:58.522
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.hyades.trace.ui.UIPlugin.stop() of bundle org.eclipse.hyades.trace.ui.
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:863)
	at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:474)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:546)
	at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1098)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:593)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:261)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:216)
	at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:266)
	at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:685)
	at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:583)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:409)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:200)
Caused by: java.lang.ExceptionInInitializerError
	at org.eclipse.hyades.trace.ui.UIPlugin.stop(UIPlugin.java:388)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:843)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:836)
	... 19 more
	at org.eclipse.hyades.ui.internal.util.ImageManager.add(ImageManager.java:119)
	at org.eclipse.tptp.platform.common.ui.trace.internal.CommonUITraceImages.addImages(CommonUITraceImages.java:51)
	at org.eclipse.hyades.ui.internal.util.ImageManager.checkImages(ImageManager.java:95)
	at org.eclipse.hyades.ui.internal.util.ImageManager.getImageDescriptor(ImageManager.java:212)
	at org.eclipse.hyades.trace.internal.ui.PDPluginImages.createManaged(PDPluginImages.java:164)
	at org.eclipse.hyades.trace.internal.ui.PDPluginImages.<clinit>(PDPluginImages.java:102)
	... 23 more
Root exception:
	... 23 more
!SESSION 2010-05-28 09:09:23.537 -----------------------------------------------
!ENTRY org.maven.ide.eclipse 4 -1 2010-05-28 11:38:01.959
!MESSAGE Could not get mojo execution paramater value
!STACK 0
  Path to dependency:
for artifact:
  Path to dependency:
for artifact:
	... 18 more
!ENTRY org.eclipse.jface 2 0 2010-05-28 11:38:25.100
!MESSAGE Ignored reentrant call while viewer is busy. This is only logged once per viewer instance, but similar calls will still be ignored.
!STACK 0
java.lang.RuntimeException
	at org.eclipse.jface.viewers.ColumnViewer.checkBusy(ColumnViewer.java:763)
	at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer.java:541)
	at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.java:358)
	at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.java:515)
	at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider$3.run(ResourceExtensionContentProvider.java:294)
	at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider.runUpdates(ResourceExtensionContentProvider.java:306)
	at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider.processDelta(ResourceExtensionContentProvider.java:116)
	at org.eclipse.ui.model.WorkbenchContentProvider.resourceChanged(WorkbenchContentProvider.java:106)
	at org.eclipse.core.internal.events.NotificationManager$2.run(NotificationManager.java:291)
	at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
	at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
	at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:313)
	at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1022)
	at org.eclipse.core.internal.resources.Project.setDescription(Project.java:1070)
	at org.eclipse.core.internal.resources.Project.setDescription(Project.java:1082)
	at org.eclipse.wst.common.project.facet.core.internal.FacetedProjectFrameworkImpl.create(FacetedProjectFrameworkImpl.java:718)
	at org.eclipse.wst.common.project.facet.core.ProjectFacetsManager.create(ProjectFacetsManager.java:375)
	at org.maven.ide.eclipse.wtp.internal.WebResourcesContentProvider.getPipelinedChildren(WebResourcesContentProvider.java:66)
	at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.pipelineChildren(NavigatorContentServiceContentProvider.java:323)
	at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.internalGetChildren(NavigatorContentServiceContentProvider.java:259)
	at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.getChildren(NavigatorContentServiceContentProvider.java:607)
	at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1346)
	at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:390)
	at org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChildren(AbstractTreeViewer.java:636)
	at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:602)
	at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:797)
	at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:776)
	at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:639)
	at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpand(AbstractTreeViewer.java:1442)
	at org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeViewer.java:937)
	at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded(AbstractTreeViewer.java:1453)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:126)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
	at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7349)
	at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4877)
	at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:1757)
	at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4507)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4000)
	at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
	at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2314)
	at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1530)
	at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:6280)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:3981)
	at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5821)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4632)
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2411)
[Updated on: Tue, 01 June 2010 15:25] by Moderator
Previous Topic:Extend editorConfiguration
Next Topic:Completition Proposal not working
Current Time: Sat Jul 19 22:37:03 EDT 2025
Powered by FUDForum. Page generated in 0.03513 seconds
