Home » Archived » Service Component Architecture (SCA) Tools » Java Callback interface is not supported
Java Callback interface is not supported [message #536260] Thu, 27 May 2010 09:49 Go to next message
Currently Java callback interface is not supported in version 2.0.1
Is there a plan to include it in the next version?
Re: Java Callback interface is not supported [message #536272 is a reply to message #536260] Thu, 27 May 2010 10:12 Go to previous messageGo to next message
Are you sure?
When I select a Java Interface in the Composite Designer, I can see, in
the property view, a property named "Callback Interface".
Stephane Drapeau
Obeo
Re: Java Callback interface is not supported [message #536285 is a reply to message #536272] Thu, 27 May 2010 10:39 Go to previous messageGo to next message
Yes, but when you right click on the Java Interface you find "set Java Interface" that allows you to add a java interface and not a java callback interface.
I think we need also a "set Java Callback interface" that allows us to add CB interface similar to the forward interface.
Re: Java Callback interface is not supported [message #536387 is a reply to message #536285] Thu, 27 May 2010 18:33 Go to previous messageGo to next message
> callback interface.
Yes, it's a good idea to have also a wizard to set the Java callback
interface. Can you please file a bug?
Stephane Drapeau
Obeo
Re: Java Callback interface is not supported [message #536603 is a reply to message #536387] Fri, 28 May 2010 16:29 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=314957
Re: Java Callback interface is not supported [message #577147 is a reply to message #536272] Thu, 27 May 2010 10:39 Go to previous messageGo to next message
Re: Java Callback interface is not supported [message #577197 is a reply to message #536285] Thu, 27 May 2010 18:33 Go to previous messageGo to next message
> callback interface.
Stephane Drapeau
Obeo
Re: Java Callback interface is not supported [message #577262 is a reply to message #536387] Fri, 28 May 2010 16:29 Go to previous message
Previous Topic:Build SCA Tools from source
Next Topic:Deployment in SCA and SCA Tools
Current Time: Sat Jul 19 08:59:19 EDT 2025
Powered by FUDForum. Page generated in 0.05151 seconds
