Home » Modeling » GMF (Graphical Modeling Framework) » Label alignment inside a compartment
Label alignment inside a compartment [message #533778] Sun, 16 May 2010 19:24 Go to next message
Hi!
may someone of you got the helping idea, because i can't get it done right.
Situation:
I got a Node N.
I got a Node SN.
Node N can have compartments of the type SN.
Until now everything works just fine:)
Now I'd like to see a centered label inside the SN Nodes.
Well, after a very long period of googling and clicking inside my gmfmap/gmfgraph i still got no good result.
Not working solution:
I've found one setting which will get my label centered. However the SN mode won't fill its compartment anymore. (In this setting a got an eclipse with grid layout inside an rectangle as gmfgraph definition for the SN node)
Florian
[Updated on: Sun, 16 May 2010 19:37] by Moderator
Re: Label alignment inside a compartment [message #533828 is a reply to message #533778] Mon, 17 May 2010 04:44 Go to previous messageGo to next message
Have you try to add a child "Border Layout Data" under your label with "alignement = CENTER" and "vertical = false" ?
(In the gmfgraph)
Re: Label alignment inside a compartment [message #534082 is a reply to message #533778] Mon, 17 May 2010 18:12 Go to previous messageGo to next message
Jeep, but it won't work, too.
Re: Label alignment inside a compartment [message #535709 is a reply to message #533828] Tue, 25 May 2010 07:05 Go to previous messageGo to next message
Dewas wrote on Mon, 17 May 2010 10:44
(In the gmfgraph)
Have you tried this?
http:// wiki.eclipse.org/GMF_Newsgroup_Q_and_A#How_can_I_right-justi fy_items_in_a_compartment.3F
In this example the compartment content is right-justified but it explains how layout information is applied to compartments.
Maybe this helps.
Sebastian
Re: Label alignment inside a compartment [message #536058 is a reply to message #533778] Wed, 26 May 2010 15:59 Go to previous message
Hi Sebastian,
thx for this hint, this place of the source could be it. But i didn't get it to work the right way either. Well now I'm just out of the time i had for this project.. So i choose some cheating like centering the label by using indent values. Surprised
Regards Florian
Previous Topic:Class invoked when attribute value is changed
Next Topic:Appearance tab is disabled for certain nodes
Current Time: Sat Jul 19 12:50:55 EDT 2025
Powered by FUDForum. Page generated in 0.04071 seconds
