Home » Eclipse Projects » Eclipse 4 » XWT fails to load x:Class class
XWT fails to load x:Class class [message #535287] |
Fri, 21 May 2010 17:30  |
I created a small plugin project which has a simple Composite with two buttons. I created a SelectionEvent handler for one of the buttons. Without this handler the Composite appears to load fine, but as soon as I add the event handler in .xwt it fails to load. Turns out if fails to load the class containing the event handler which is specified in x:Class.
Is this a known limitation or a bug?
Here is the XWT file
<Composite xmlns="http://www.eclipse.org/xwt/presentation"
xmlns:x="http://www.eclipse.org/xwt" xmlns:c="clr-namespace:networkeditor.config.ui"
xmlns:j="clr-namespace:java.lang" x:Class="networkeditor.config.ui.MyConfigDialog"
x:DataContext="networkeditor.config.ui.MyConfigData">
<Composite.layout>
<GridLayout numColumns="2" />
</Composite.layout>
<Button x:style="SWT.PUSH" text="Push Me" SelectionEvent="performSelectionEvent"></Button>
<Button x:style="SWT.PUSH" text="Don't push me"></Button>
</Composite>
Here is the Java class.
package networkeditor.config.ui;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
public class MyConfigDialog extends Composite {
public MyConfigDialog(Composite parent, int style) {
super(parent, style);
// TODO Auto-generated constructor stub
protected void performSelectionEvent (Event event) {
MessageDialog.openInformation(getShell(), "Title", "you pushed me");
And here is the data context class.
public class MyConfigData {
Here is how I invoke it.
public static void main (String [] args) {
try {
URL file = MyConfigData.class.getResource("/networkeditor/config/ui/MyConfigDialog.xwt ");
XWT.open(file);
} catch (Exception e) {
e.printStackTrace();
BTW, When I press the Preview button in the XWT file editor (in XWT perspective) the event handler is invoked correctly. So there is something that I am not doing correctly.
I tried passing parent composite so that ILoadingContext is set differently.
I exported the package containing these classes via MANIFEST.MF.
I changed Eclipse-BuddyPolicy: global (although it shouldn't help in theory)
I checked the Eclipse-BuddyPolicy in org.eclipse.e4.xwt and it is not set so I don't know how the xwt plugin loads these classes. I am using ver 0.9.1 from 2010 04 06.
XWT simply can't load the MyConfigDialog class.
Any help will be appreciated.
Swavek
[Updated on: Tue, 25 May 2010 15:34] by Moderator
Re: XWT fails to load x:Class class [message #536906 is a reply to message #536896] |
Mon, 31 May 2010 09:03   |
Hi Yves,
I wouldn't call it an OSGi-Issue but an OSGi-Requirement :-)
Out of curiosity would it be possible instead of setting the class
loader to provide an OSGified load-Method.
XWT.load(Bundle bundle,String resource) this could make all relative
resources (Images, Classes, ...) relative to this bundle?
Tom
Am 31.05.10 14:45, schrieb Yves YANG:
>> Is setting of class loader still necessary for the XWT.load to succeed in
>> loading x:Class? None of the examples are showing that this is necessary
>> but I had to add a code like this to get the event handler class loaded.
>> This class and the .xwt file are in the same package in the same plugin,
>> but XWT has trouble loading it.
> If your application is in plugin, the setting of class loader is always
> necessary. It is not a problem of the implementation of XWT. It is a common
> issue of OSGi.
> Best regards
> Yves YANG
> "Swavek" <slorenc@infogix.com> wrote in message
> news:htk1g7$aau$1@build.eclipse.org...
>> Yves,
>> I just downloaded the latest e4 M6 and verified that this problem goes
>> away. Thank you. I was almost ready to give up on XWT.
>> // override the class loader for the x:Class classes located within this
>> plugin or else they will not be loaded
>> DefaultLoadingContext loadingContext = new DefaultLoadingContext ();
>> loadingContext.setClassLoader(getClass().getClassLoader());
>> XWTLoaderManager.getActive().setLoadingContext(loadingContex t);
>> . then call XWT.load
>> Thanks,
>> Swavek
Re: XWT fails to load x:Class class [message #537017 is a reply to message #536906] |
Mon, 31 May 2010 19:28  |
Hi Tom,
You are absolutely right. Thanks for correcting me.
I think it should have the same result. The class loader can load resources
as well. We do use the classloader to load images, XWT files.
yves
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:hu0c3a$53n$1@build.eclipse.org...
> Hi Yves,
> Tom
>>> in
>>> necessary
>> common
>> issue of OSGi.
>> Best regards
>> Yves YANG
>>> Yves,
>>> in
>>> necessary
>>> Thanks,
>>> Swavek
Re: XWT fails to load x:Class class [message #576806 is a reply to message #535848] |
Wed, 26 May 2010 16:49  |
Yves,
I just downloaded the latest e4 M6 and verified that this problem goes away. Thank you. I was almost ready to give up on XWT.
Is setting of class loader still necessary for the XWT.load to succeed in loading x:Class? None of the examples are showing that this is necessary but I had to add a code like this to get the event handler class loaded. This class and the .xwt file are in the same package in the same plugin, but XWT has trouble loading it.
// override the class loader for the x:Class classes located within this plugin or else they will not be loaded
.. then call XWT.load
Swavek
Re: XWT fails to load x:Class class [message #576834 is a reply to message #536069] |
Mon, 31 May 2010 08:45  |
issue of OSGi.
Best regards
Yves YANG
> Yves,
> Swavek
Re: XWT fails to load x:Class class [message #576845 is a reply to message #536896] |
Hi Yves,
Tom
> issue of OSGi.
> Best regards
> Yves YANG
>> Yves,
>> Thanks,
>> Swavek
Re: XWT fails to load x:Class class [message #576874 is a reply to message #536906] |
Hi Tom,
yves
> Hi Yves,
> Tom
>>> in
>>> necessary
>> common
>> issue of OSGi.
>> Best regards
>> Yves YANG
>>> Yves,
>>> in
>>> necessary
>>> Thanks,
>>> Swavek
Current Time: Sat Jul 19 19:32:11 EDT 2025
Powered by FUDForum. Page generated in 0.05685 seconds
