Home » Archived » M2M (model-to-model transformation) » [ATL] I do not understand rule inheritance
[ATL] I do not understand rule inheritance [message #535699] Tue, 25 May 2010 06:20 Go to next message
The user guide for rule inheritance is not very clear to me.
here is the pb
IN!A is not an abstract class
IN!B inherits from IN!A
rule RuleA {
from s : IN!A (s.oclIsOfType(IN!A))
to [toA]
do [doA]
rule RuleB extends RuleA{
from s: IN!B
to [toB]
this seems to working fine, but if I change
from s: IN!B
to
from s: IN!B (s.oclIsOfType(IN!B))
I do not have any more matches ??????
I do not understand why ?
because if I create a Rule C
rule RuleC extends RuleB{
from s: IN!C
to [toC]
where IN!C inherits from IN!B I am afraid that this raises a multiple matching problem.
Any idea on solving this problem?
Thanks.
Re: [ATL] I do not understand rule inheritance [message #535785 is a reply to message #535699] Tue, 25 May 2010 11:42 Go to previous messageGo to next message
Le 25/05/2010 12:20, seb.fr a écrit :
> Hello,
> here is the pb
> IN!A is not an abstract class IN!B inherits from IN!A
> rule RuleA {
> from s : IN!A ()
from s : IN!A just represents the constraint s.oclIsOfType(IN!A)
so you do not need to specify it
> to [toA]
> do [doA]
> from s: IN!B to [toB]
> from s: IN!B to
same...
and inheriting rules is done by a rewriting /merge of the rule so the
two constraints conflict.
> from s: IN!C to [toC]
ruleC will only match IN!C instances....
> matching problem.
> Thanks.
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: [ATL] I do not understand rule inheritance [message #535787 is a reply to message #535785] Tue, 25 May 2010 12:09 Go to previous messageGo to next message
Are you sure that
from s : IN!A
is equivalent to
s.oclIsOfType(IN!A)
because looking at the Wiki user guide, it says otherwise ( http://wiki.eclipse.org/ATL/User_Guide_-_The_ATL_Language#AT L_Tips_.26_Tricks )
The user guide seems to say it is equivalent to
s.oclIsOfKind(IN!A)
I really am confused now Shocked
Vincent MAHE wrote on Tue, 25 May 2010 17:42
> Hello,
> here is the pb
> rule RuleA {
> from s : IN!A ()
> to [toA]
> do [doA]
> from s: IN!B to
same...
> matching problem.
> Thanks.
Cordialement
Vincent MAHÉ
Re: [ATL] I do not understand rule inheritance [message #535793 is a reply to message #535787] Tue, 25 May 2010 12:43 Go to previous message
Le 25/05/2010 18:09, seb.fr a écrit :
> Are you sure that
> from s : IN!A is equivalent to
> s.oclIsOfType(IN!A)
> s.oclIsOfKind(IN!A)
Sorry. I do not investigate enough :-(
When you define the super rule using oclIsOfType, you put the same
constraint on sub rules. In your case it means they can only apply on A
types not B or C ones....
I do not used inheritance many times but the parser manages the
differences and distributes matches on appropriate rule without multiple
matches error...
> I really am confused now 8o
>> > Hello,
>> > here is the pb
>> > rule RuleA {
>> > from s : IN!A ()
>> > to [toA]
>> > do [doA]
>> > from s: IN!B to
>> same...
>> > matching problem.
>> > Thanks.
>> Cordialement
>> Vincent MAHÉ
Cordialement
Vincent MAHÉ
Previous Topic:extract element of sequence
Next Topic:[ATL] override attribute in sub rules
Current Time: Sat Jul 19 08:51:53 EDT 2025
Powered by FUDForum. Page generated in 0.03786 seconds
