[Acceleo] match/drop Special chars [message #535714] |
Tue, 25 May 2010 07:33  |
I think it's for the moment impossible to do...
I need to match special chars in the an attribute of my artefacts, and after to replace the Special char to an other char.
For example, if I have a class with the name "école", I want to replace é to e ( and to do the same thing for the "ù" "à" "ç" etc )
Is it possible? ( with Something like Regular expressions?)
Thank you in advance
Benoit
[edit] I dont want to use the methode replace(matchstr,replacementstr)
[Updated on: Tue, 25 May 2010 07:47] by Moderator
Re: [Acceleo] match/drop Special chars [message #535889 is a reply to message #535714] |
Wed, 26 May 2010 04:30   |
--------------020301090003010701080807
Hi Benoit,
If you don't mind using hard-coded mappings (and pray you don't forget
one of the potential mappings), you can use something like
string.replaceAll('éêèë', 'e').replaceAll('ÉÊÈË',
'E').replaceAll('áàãåä', 'a').replace ....
This doesn't really make for the most robust code.
A more reliable solution would be to call a Java service which would do
this :
public String stripDiacritics(String s) {
final String decomposed = Normalizer.normalize(s, Normalizer.Form.NFD);
return decomposed.replaceAll("\\p{M}", "");
Take note that the "Normalizer" API has changed in Java 1.6 ; if you're
using Java 1.5 or lower your code would be :
String decomposed = Normalizer.normalize(s, Normalizer.DECOMP, 0);
Laurent Goubet
Obeo
Laviale Benoit wrote:
> I think it's for the moment impossible to do, but i need to match
> special char in the an attribute of my artefacts, and after to replace
> Benoit
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020301090003010701080807--
FUDForum. Page generated in 0.03820 seconds
