Web Project Composed of various svn resources [message #535331] |
Sat, 22 May 2010 09:01  |
Hi all.
Out web project has completely different layout in SVN than Eclipse suppose. So I can not just checkout project from SVN. I need to compose Eclipse Dynamic Web Project of various SVN resources (web content folders, java code folders, web static resource folders etc.)
Is it possible?
Dmitri
Re: Web Project Composed of various svn resources [message #536648 is a reply to message #535331] |
Sat, 29 May 2010 05:41  |
Russell, thanks for your reply.
I can change WebContent name, but I can not find how to change the place where the WebContent sources getting from. Should I use import from file system and overwrite WebContent?
Also I can add java sources to project, and that sources are from SVN (.svn directories are present), but Project Team capabilities are turned off (except "Share..." and "Apply patch"). It seems that project does not "know" that I use SVN for some resources in project.
This is completely unusable. I used to work with IntelliJ IDEA and IDEA lets developer compose project structure from file system sources freely. In IDEA Project description files (.iml etc.) and resources (java files, web content etc.) are completely separated. Now a have to use Eclipse and this killing me.
The main point is that we does not store project special(service) files (.iml, .project, .classpath) in SVN, just resources (jars, java code, web resources).
Can anybody help with this? Is it possible or not?
Dmitri
FUDForum. Page generated in 0.06480 seconds
