Home » Eclipse Projects » Subversive » Modifying file removes it from change set
Modifying file removes it from change set [message #533695] Sat, 15 May 2010 12:56 Go to next message
Is the following an expected behavior (not for me at least) or it is
a known problem issue? I have lots of modified files in my working
copy so I assign part of them to a change set I would like to commit
sometime later. Whenever I modify file part of this set next, it
gets removed from the set and I need to locate and add it again.
Stanimir
Re: Modifying file removes it from change set [message #533814 is a reply to message #533695] Mon, 17 May 2010 03:53 Go to previous messageGo to next message
Hello Stanimir,
This is not expected behavior. Please, provide detailed steps how to
reproduce the problem. What Subversive version do you use?
> Is the following an expected behavior (not for me at least) or it is a
> known problem issue? I have lots of modified files in my working copy so
> I assign part of them to a change set I would like to commit sometime
> later. Whenever I modify file part of this set next, it gets removed
Igor Burilo
Re: Modifying file removes it from change set [message #533893 is a reply to message #533814] Mon, 17 May 2010 08:13 Go to previous messageGo to next message
Mon, 17 May 2010 10:53:30 +0300, /Igor Burilo/:
I'm using the latest 0.7.9 release, but it happened with previous
versions also. Step to reproduce:
1. Modify couple of files in an SVN connected project;
2. Choose Team -> Synchonize with Repository from the project's
context menu;
3. Make sure the "Show Change Sets" button in the Synchronize view
is pressed and either Outgoing or Incoming/Outgoing mode is selected;
4. Select couple of the modified files in the Synchronize view and
choose Reassign Changes To -> New Change Set... and create a change set;
5. Observe the change set in the Synchronize view;
6. Open some of the files belonging to the new change set for
editing; Make a modification and save the file;
7. Observe the change set in the Synchronize view - the file you've
just modified and saved has gone from the change set.
FWIW, I have the "Allow models (e.g. Java) to participate in
synchronizations" option unchecked.
Stanimir
Re: Modifying file removes it from change set [message #535048 is a reply to message #533893] Fri, 21 May 2010 03:42 Go to previous messageGo to next message
Hello Stanimir,
I suppose that file could disappear from Sync View because as a result
of your modification, it didn't contain changes any more.
Where did the file disappear, to '<Unassigned>' change set? You can
check that file doesn't have changes if it doesn't have modification
decoration in navigator view.
> 2. Choose Team -> Synchonize with Repository from the project's context
> menu;
> 3. Make sure the "Show Change Sets" button in the Synchronize view is
> 6. Open some of the files belonging to the new change set for editing;
> 7. Observe the change set in the Synchronize view - the file you've just
>>> sometime later. Whenever I modify file part of this set next, it gets
Igor Burilo
Re: Modifying file removes it from change set [message #535336 is a reply to message #535048] Sat, 22 May 2010 09:49 Go to previous messageGo to next message
Fri, 21 May 2010 10:42:26 +0300, /Igor Burilo/:
It is not the case. I just make more changes to it.
Yes it disappears from the initially assigned change set and appears
as unassigned change. I've now tried it again and initially it just
happened like that. Then I've closed and reopened the project and
tried it again - but could not get it again. I'll try to find more
reliable way of reproducing it.
Stanimir
Re: Modifying file removes it from change set [message #535676 is a reply to message #535336] Tue, 25 May 2010 04:33 Go to previous messageGo to next message
Hello Stanimir,
I suppose that the problem can do happen under some specific conditions,
but I can't reproduce it. I think there's a sense to create a bug in
tracker if we find the way how to reproduce it.
> Yes it disappears from the initially assigned change set and appears as
> happened like that. Then I've closed and reopened the project and tried
> it again - but could not get it again. I'll try to find more reliable
Igor Burilo
Re: Modifying file removes it from change set [message #536175 is a reply to message #535676] Thu, 27 May 2010 05:46 Go to previous message
Tue, 25 May 2010 11:33:35 +0300, /Igor Burilo/:
Yep. It appears the problem magically disappeared for me now, while
been steadily visible in the past. May be it has gone fixed and I
have just not noticed between updates. If I ever get it again I'll
file a report. Thanks for your support.
Stanimir
Previous Topic:Revisions to stop merge at & merge markers in the source
Next Topic:Some of selected resources were not committed.
Current Time: Sat Jul 19 10:42:59 EDT 2025
Powered by FUDForum. Page generated in 0.26876 seconds
