Home » Language IDEs » Java Development Tools (JDT) » Java Structure Compare window missing(In Galileo 3.5 Java: while doing a comparison the structure compare window is missing)
Java Structure Compare window missing [message #534995] Thu, 20 May 2010 19:22 Go to next message
I've just upgraded from Eclipse 3.2 to Eclipse Java IDE (Galileo), with the CDT added (the sysadmin didn't use Install New Software).
When I synchronize and then double click to compare, the comparison comes up without the Java Structure Compare at the top, and there is no way to open it.
I checked "Open structure compare automatically" under General -> Compare/Patch in the Preferences, which was unchecked, even though its supposed to default to on.
I've looked around in Install New Software and installed anything that looks related to JDT.
My current workaround is to exit from 3.5 and run 3.2 when I want to check in.
Has anyone else had this problem and/or been able to fix it?
Thanks!
Sue
Re: Java Structure Compare window missing [message #535020 is a reply to message #534995] Fri, 21 May 2010 01:53 Go to previous messageGo to next message
Originally posted by: Norbert.Utella.googlemail.com
Hi Sue,
sometimes the Source Compare is hidden at the bottom of the compare
view. So if you see "Java Source Compare" at the bottom, simply move it
up a little.
Hope this helps.
Norbert
Am 21.05.2010 01:23, schrieb sueh@colorado.edu:
> way to open it.
> check in.
> Thanks!
> Sue
Re: Java Structure Compare window missing [message #535203 is a reply to message #535020] Fri, 21 May 2010 10:34 Go to previous messageGo to next message
Sorry but this does not help. The Source Compare is there.
The Java Structure Compare window is missing. Perhaps they removed this extremely useful feature since 3.2, making much harder to check in extensively modified large files. But they still have an option about it the preferences.
Sue
Re: Java Structure Compare window missing [message #535213 is a reply to message #535203] Fri, 21 May 2010 11:17 Go to previous messageGo to next message
Oh sorry, I misread the text. I thought the source compare is missing.
No, it's definitely there. Try to double click on the "Java Source
Compare"-Text.
Re: Java Structure Compare window missing [message #535242 is a reply to message #535213] Fri, 21 May 2010 13:19 Go to previous message
Norbert,
You are right it is there. It showed up when I turned off Preferences -> General -> Compare/Patch -> Show structure compare in Outline view when possible. Which is wierd.
Yey! Very Happy
Thanks!
Sue
Previous Topic:Compare API using Eclipse
Next Topic:Problems getting 1.4.2 JRE recognized on OS X
Current Time: Sun Jul 20 04:30:59 EDT 2025
Powered by FUDForum. Page generated in 0.04976 seconds
