Home » Archived » Test and Performance Tools Platform (TPTP) » Allocation Details for String(Allocation Details for String)
Allocation Details for String [message #533793] Mon, 17 May 2010 02:32 Go to next message
In Obect Allocation in Memory Statistics tab I am able to view String if I set it not to exclude it from filters. But, on double clicking the same I am not able to view the Allocation Details of String even though it shows some live instances of Strings. Whereas for other object similar details can be seen.
How can we see Allocation Details for String containing package name, etc?
Re: Allocation Details for String [message #534667 is a reply to message #533793] Wed, 19 May 2010 15:35 Go to previous messageGo to next message
Hi NRN, I was able to profile a simple class containing a String and view the allocation site, using 4.7.0. Could you provide more details on your environment?
Re: Allocation Details for String [message #534705 is a reply to message #533793] Thu, 20 May 2010 00:44 Go to previous messageGo to next message
I am using TPTP-4.6.2 as this is the latest release I am able to find in downlaods on eclipse website. And I am using JDK1.6 to run the tool.
Re: Allocation Details for String [message #535259 is a reply to message #534705] Fri, 21 May 2010 14:35 Go to previous messageGo to next message
Hi NRN,
Can you try with 4.7.0 (http://www.eclipse.org/tptp/home/downloads/?ver=4.7.0) and see if you are still able to reproduce? If so, please open a bug and provide a sample case to reproduce the problem, and we will investigate. Thanks!
Re: Allocation Details for String [message #535500 is a reply to message #535259] Mon, 24 May 2010 00:52 Go to previous messageGo to next message
Hi Jonathan,
Thanks for reply. With 4.7 I am able to view the require details. But, now live String instances are shown as 22 and if we see details then details can be seen only for 11 instances.
Can you let me know why there is a difference?
Re: Allocation Details for String [message #537011 is a reply to message #535500] Mon, 31 May 2010 17:20 Go to previous message
Hi NRN, this difference is expected, and is due to calculation differences between the two versions.
Previous Topic:Profiling using TPTP
Next Topic:Is the Generic Log Adapter alive?
Current Time: Sat Jul 19 07:56:15 EDT 2025
Powered by FUDForum. Page generated in 0.26768 seconds
