Home » Eclipse Projects » EGit / JGit » mutli-projects repository
mutli-projects repository [message #533074] Wed, 12 May 2010 03:51 Go to next message
Some of my Eclipse projects share the same git repository. Would it be possible for EGit to discover the repository from the parent directory?
Thanks a lot for your great work!
Nicolas
Re: mutli-projects repository [message #533522 is a reply to message #533074] Fri, 14 May 2010 07:57 Go to previous messageGo to next message
Yes, the Share project... wizard looks for a repository in the parent
directories.
The repository which contains the egit sources does also contain several
eclipse projects.
Does this answer your question?
Stefan
Re: mutli-projects repository [message #533882 is a reply to message #533522] Mon, 17 May 2010 07:36 Go to previous message
Great! Thank you very much.
Nicolas
Re: mutli-projects repository [message #580374 is a reply to message #533522] Mon, 17 May 2010 07:36 Go to previous message
Nicolas
Previous Topic:Installation (dependency) problem under Eclipse 3.6
Next Topic:Maven repository unavailable
Current Time: Sat Jul 19 20:44:27 EDT 2025
Powered by FUDForum. Page generated in 0.25326 seconds
