Home » Archived » M2M (model-to-model transformation) » [ATL] set something to null (or equivalent)  () 1 Vote
[ATL] set something to null (or equivalent) [message #533506] Fri, 14 May 2010 06:24 Go to next message
I want to do something like this:
to
  a: outMM!A (
      feature <- null
This is needed since I want to override the super rule's binding. So omitting the 'feature <- null' binding won't do the job.
Any ideas?
Re: [ATL] set something to null (or equivalent) [message #533798 is a reply to message #533506] Mon, 17 May 2010 03:23 Go to previous messageGo to next message
Le 14/05/2010 12:24, Marten Sijtema a écrit :
> Hello,
> to
> a: outMM!A (
> feature <- null
> Any ideas?
try OclUndefined. It is the equivalent of null in OCL
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: [ATL] set something to null (or equivalent) [message #533805 is a reply to message #533798] Mon, 17 May 2010 03:45 Go to previous messageGo to next message
Thanks for the reply!
I got your hint from a colleague this morning, and tried it without success. So I tried something different. The strange thing is this.
Consider my situation (i'm building a higher order transformation of myExtendedATL-2-ATL):
rule MatchedRule2MatchedRule extends Rule2Rule {
	from
		s : fatl!MatchedRule
	to
		t : atl!MatchedRule (
			inPattern <- s.inPattern,
			children <- s.children, -- *** breakpoint here
			superRule <- if s.oclIsTypeOf(fatl!DependentVariabilityRule) then
							OclUndefined
						 else
						 	s.superRule
						 endif,
			isAbstract <- s.isAbstract,
			isRefining <- s.isRefining,
			isNoDefault <- s.isNoDefault
--this rule extends the one above
rule DependentVariabilityRule2LazyRule extends MatchedRule2MatchedRule {
	from
		s : fatl!DependentVariabilityRule
	to
		t : atl!LazyMatchedRule (
			isUnique <- false,
			isAbstract <- false,
			isRefining <- false,
			isNoDefault <- s.isNoDefault,
			outPattern <- thisModule.getOutPattern(s),
			name <- s.variantName
If i put a breakpoint in the line before the superRule binding, I would expect that the t.superRule is undefined at that point, correct?
Well, it isn't, it is initialized with s.superRule (even before the if-then-else statement)! Why is this the case? The sub rule does not bind it, so I don't see why it is initialized like this. After that, the if-statement is correct according to the debugger, but it does not unset the value.
Is this a bug or a feature from ATL? And is there a work-around? Appearantly, things get initialized without me wanting it to...
(the work-around would be 'unsetting' a binding, is there a way to unset a binding?)
[Updated on: Mon, 17 May 2010 03:59] by Moderator
Re: [ATL] set something to null (or equivalent) [message #533845 is a reply to message #533506] Mon, 17 May 2010 05:32 Go to previous messageGo to next message
Do you have superRule <- s.superRule in Rule2Rule ?
Re: [ATL] set something to null (or equivalent) [message #533849 is a reply to message #533845] Mon, 17 May 2010 05:38 Go to previous messageGo to next message
no, I checked the super rules for these things. Is it a bug? nowhere else in the code the s.superRule is bound.
Re: [ATL] set something to null (or equivalent) [message #533853 is a reply to message #533506] Mon, 17 May 2010 05:51 Go to previous messageGo to next message
You're not in refining right ?
Re: [ATL] set something to null (or equivalent) [message #533867 is a reply to message #533853] Mon, 17 May 2010 06:37 Go to previous messageGo to next message
No. I even thought about that. Sorry for not mentioning.
Thus:
- Not refining
- Nowhere in inheritance stack there is a similar binding
- But it is initialized prematurely.
Still missing something?
Re: [ATL] set something to null (or equivalent) [message #533879 is a reply to message #533805] Mon, 17 May 2010 07:15 Go to previous messageGo to next message
> from
> to
> inPattern <- s.inPattern, children <- s.children, -- *** breakpoint here
> OclUndefined
> else
> s.superRule
> endif,
> from
> s : fatl!DependentVariabilityRule to
> isUnique <- false,
> outPattern <- thisModule.getOutPattern(s), name <- s.variantName
> the value.
You may try an helper returning OclUndefined (in place of direct
OclUndefined)....
Cordialement
Vincent MAHÉ
Re: [ATL] set something to null (or equivalent) [message #533880 is a reply to message #533879] Mon, 17 May 2010 07:27 Go to previous messageGo to next message
I tried it in both ways, ie. superrule with if-then-else statement as described above, and the normal way by overriding in the subrule, but it doesn't work.
Re: [ATL][SOLVED] set something to null (or equivalent) [message #533939 is a reply to message #533506] Mon, 17 May 2010 10:17 Go to previous message
SOLVED!
Now I get what was going on.
A MatchedRule element has a property children. This is the EOpposite of a superRule property. If one of them is omitted, but the EOpposite version is still there, the link will still be made. Therefore, I had to outcomment 'children' attribute, like shown below. Sounds logical, but it costed me a few hours to find out.
	from
	to
			--children <- s.children,
			superRule <-  s.superRule,
There is a fair chance this introduced some other errors, but with a helper i could create some guards to fix this.
Thanks for all the quick replies today. Hopefully this could be some help for other people.
Previous Topic: iterate
Next Topic:error message
Current Time: Sat Jul 19 16:57:35 EDT 2025
Powered by FUDForum. Page generated in 1.05047 seconds
