Home » Language IDEs » ServerTools (WTP) » Javascript highlighting in CDATA content(cannot highlight JavaScript in CDATA in XML file)
Javascript highlighting in CDATA content [message #533797] Mon, 17 May 2010 03:16 Go to next message
Hi People, Smile
We have a lot of xml files with embedded JavaScript code in CDATA content of XML documents. Because of CDATA it display the JavaScript without syntax highlighting.
For example:
<page id="admin" title="Administration">
<js:visible>
<![CDATA[
session.currentDatabase.accessLevel > 1 && (session.currentUser.getManagedUnits.length > 0 || session.currentUser.hasId(['{manager}', '[TemplateAdmin]']));
// true
</js:visible>
<outline>outline.olnAdministration</outline>
</page>
How can we enable Javascript highlighting in CDATA in Eclipse?
Thanks!
[Updated on: Mon, 17 May 2010 03:17] by Moderator
Re: Javascript highlighting in CDATA content [message #534409 is a reply to message #533797] Wed, 19 May 2010 00:25 Go to previous messageGo to next message
On 5/17/2010 3:16 AM, xemox wrote:
> Hi People, :)
> For example:
> <js:visible><![CDATA[
> // true
> ]]></js:visible>
> </page>
There's no way without writing a plug-in. The first steps would be to
identify your XML files as their own content type, otherwise you'd be
treating all CDATA sections in all XML files as JavaScript, which
certainly can't be right. Then it would require similar features as the
org.eclipse.wst.jsdt.web.core plug-in provides to handle the JavaScript
within the page, but as we don't have this working yet for XHTML,
there's not an example yet for doing so. XHTML should be something we
tackle in 3.3, but even then I'm sure changes to allow that flexibility
would need to be added to the XML model for your scenario.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: Javascript highlighting in CDATA content [message #535960 is a reply to message #534409] Wed, 26 May 2010 09:37 Go to previous message
Hi Nitiin, Smile
Thanks for your reply. I started to dig in org.eclipse.wst.jsdt.web.core plug-in in order to understand how syntax coloring works for Javascript.
Initially, for testing purposes what I wanted was just to highlight the content inside the <script2> </script2> element instead of default <script> </script> javascript tags.
I have searched for ''script" tag in the source code and than have changed them accordingly into "script2". These are the places where I have changed:
1. In org.eclipse.wst.jsdt.web.core\JsTranslator.java in :
a. translate() method:
if ((!nh.isEndTag() || nh.isSelfClosingTag()) && (nh.nameEquals("script2"){ ...
b. in translateJSNode() method
if(name==null || !name.trim().equalsIgnoreCase("script2") || !nh.isEndTag()) { ...
2. in org.eclipse.wst.jsdt.web.core \src\org\eclipse\wst\jsdt\web\core\javascript\HTML40Namespac e.java:
public static final String SCRIPT = "SCRIPT2"; //$NON-NLS-1$
3. org.eclipse.wst.jsdt.web.ui \src\org\eclipse\wst\jsdt\web\ui\views\contentoutline\JFaceN odeAdapterForJs.java:
in isJSElementParent() metod:
return (node.hasChildNodes() && node.getNodeName().equalsIgnoreCase("script2"));
4. And similarly relevant 3 places at org.eclipse.wst.html.core files
Afterwards I exported the 3 aforementioned plugins and replaced them with old ones and run Eclipse from Manifest file as "Launch an Eclipse application".
And I opened a testing X/HTML file and typed simple JS code like:
<script2>
function addition()
var a = 4;
c = a + 5;
return c;
</script2>
But it did not highlight the <script2> content. Now I also missed the syntax coloring in normal <syntax> tags.
1. What I miss? or What did I do wrongly? Could you please enlighten me on this?
2. Most of our javascript code is embedded in XML files with "js:" namespace as follows:
<js:unless><![CDATA[
var favoritesEnabled = session.currentDatabase.getConfigSetting('fdFavoritesEnabled ');
if (favoritesEnabled != null && favoritesEnabled.length > 0 && favoritesEnabled[0] == '1') {
session.getDatabase('om').getView('user.$vwUsers').getDocume nt(session.currentUser.id) != null;
} else {
false;
]]></js:unless>
My idea is to check whether each tag starts with "js:" namespace, and than syntax coloring the element with javascript code highligting.
Where can I find namespace handling in JSDT and how can I tell eclipse that it can syntax color all elements with "js:" namespace? And what are the concepts, steps to learn and follow to achieve this? Where can I start? Show me some guidelines.
I would really appreciate your reply. thanks!
Best Regards,
Xemox.
[Updated on: Wed, 26 May 2010 09:42] by Moderator
Previous Topic:CVS resource of org.eclipse.wst.jsdt.ui is virus infected?
Next Topic:Eclipse error during geneation of java source code from wsdl.
Current Time: Sun Jul 20 09:38:07 EDT 2025
Powered by FUDForum. Page generated in 0.03266 seconds
