Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Updating images in view in background(How to update images in view in background)
Updating images in view in background [message #533483] |
Fri, 14 May 2010 04:41  |
I'm looking forward to provide a video support within eclipse. Till now managed to have a view with continueosly updating images with endless stream.
Everything works well till this point. But when I change focus to some other view or click anywhere within the eclipse, it hangs. It cannot even come back to video view. There are no listeners in the code. I'm simply changing background images in the loop.
Here is code snippet.
public class SampleView_1 extends ViewPart {
public Canvas imageCanvas;
private Action change_image;
private Image sourceImage;
public void createPartControl(Composite parent) {
imageCanvas=new Canvas(parent, SWT.BACKGROUND | SWT.V_SCROLL | SWT.H_SCROLL);
imageCanvas.setBackgroundImage(new Image(parent.getDisplay(), "C:/Documents and Settings/All Users/Documents/My Pictures/Sample Pictures/Blue hills.jpg"));
makeActions();
contributeToActionBars();
private void contributeToActionBars() {
IActionBars bars = getViewSite().getActionBars();
fillLocalToolBar(bars.getToolBarManager());
private void fillLocalToolBar(IToolBarManager manager) {
manager.add(change_image);
private void makeActions() {
change_image = new Action() {
public void run() {
ChangeImage();
change_image.setText("Change Image");
change_image.setToolTipText("Change Image");
change_image.setImageDescriptor(PlatformUI.getWorkbench().ge tSharedImages().
getImageDescriptor(ISharedImages.IMG_OBJS_INFO_TSK));
private void ChangeImage() {
/*String path = "C:/Documents and Settings/All Users/Documents/My Pictures/Sample Pictures/";
String arr[] = new String[]{"/Blue hills.jpg","/Sunset.jpg","/Water lilies.jpg","/Winter.jpg"};
for(int i=0;i<4;i++){
imageCanvas.setBackgroundImage(new Image(imageCanvas.getDisplay(), path + arr[i]));
try {
Thread.sleep(100);
} catch (InterruptedException e) {
e.printStackTrace();
/* IWorkbenchWindow window = PlatformUI.getWorkbench().getActiveWorkbenchWindow();
IViewPart viewPart = window.getActivePage().findView(
"lcdview.views.SampleView_1");
Shell shell = viewPart.getSite().getShell();
PaletteData palette[] = new PaletteData[5];
palette[0] = new PaletteData(0, 0, 0);//new PaletteData(0xff, 0xff00, 0xff0000);
palette[1] = new PaletteData(0, 0, 1);//new PaletteData(0xff00, 0xff0000, 0xff);
palette[2] = new PaletteData(0, 1, 0);//new PaletteData(0xff0000, 0xff, 0xff00);
palette[3] = new PaletteData(1, 0, 0);//new PaletteData(0xff, 0xff00, 0xff0000);
palette[4] = new PaletteData(0, 0, 1);//new PaletteData(0xff00, 0xff0000, 0xff);
int i=0;
while(true){
ImageData hueData = new ImageData(1024, 720, 24, palette[i]);
float hue = 0;
for (int x = 0; x < hueData.width; x++) {
for (int y = 0; y < hueData.height; y++) {
int pixel = palette[i].getPixel(new RGB(hue, 1f, 1f));
hueData.setPixel(x, y, pixel);
hue += 360f / hueData.width;
Image hueImage = new Image(imageCanvas.getDisplay(), hueData);
sourceImage = hueImage;
imageCanvas.setBackgroundImage(sourceImage);
imageCanvas.update();
// shell.setBackgroundImage(sourceImage);
// shell.update();
if(i%4 == 0)
i = 0;
i++;
public void setFocus() {
Stuck since long. Please provide any pointers. Badly stuck
Thanks in advance,
Vrushali.
Re: Updating images in view in background [message #533536 is a reply to message #533526] |
Fri, 14 May 2010 09:44   |
Ok i have modified the snippet for u r requirement...
Try this
* Copyright (c) 2000, 2004 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* IBM Corporation - initial API and implementation
package org.eclipse.swt.snippets;
* Image example snippet: display an animated GIF
* For a list of all SWT example snippets see
* http://www.eclipse.org/swt/snippets/
import org.eclipse.swt.SWT;
import org.eclipse.swt.SWTException;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.ImageData;
import org.eclipse.swt.widgets.Shell;
public class Snippet141
static Display display;
static Shell shell;
static GC shellGC;
static Color shellBackground;
// static ImageLoader loader;
static ImageData[] imageDataArray;
static Thread animateThread;
static Image image;
static final boolean useGIFBackground = false;
public static void main(String[] args)
display = new Display();
shell = new Shell(display);
shell.setSize(300, 300);
shell.open();
shellGC = new GC(shell);
shellBackground = shell.getBackground();
// FileDialog dialog = new FileDialog(shell);
// dialog.setFilterExtensions(new String[] { "*.gif" });
String fileName = "";
// dialog.open();
if (fileName != null)
// loader = new ImageLoader();
try
imageDataArray = new ImageData[] { new ImageData("c:\\Blue hills.jpg"),
new ImageData("c:\\Sunset.jpg"), new ImageData("c:\\Water lilies.jpg"),
new ImageData("c:\\Winter.jpg") };
if (imageDataArray.length > 1)
animateThread = new Thread("Animation")
public void run()
/* Create an off-screen image to draw on, and fill it with the shell background. */
Image offScreenImage = new Image(display, 400, 300);
GC offScreenImageGC = new GC(offScreenImage);
offScreenImageGC.setBackground(shellBackground);
offScreenImageGC.fillRectangle(0, 0, 400, 300);
try
/* Create the first image and draw it on the off-screen image. */
int imageDataIndex = 0;
ImageData imageData = imageDataArray[imageDataIndex];
if (image != null && !image.isDisposed()) image.dispose();
image = new Image(display, imageData);
offScreenImageGC.drawImage(image, 0, 0, imageData.width,
imageData.height, imageData.x, imageData.y,
imageData.width, imageData.height);
/* Now loop through the images, creating and drawing each one
* on the off-screen image before drawing it on the shell. */
int repeatCount = 50;
while (repeatCount > 0)
switch (imageData.disposalMethod)
case SWT.DM_FILL_BACKGROUND:
/* Fill with the background color before drawing. */
Color bgColor = null;
// if (useGIFBackground && loader.backgroundPixel !=
// -1)
// bgColor = new Color(display, imageData.palette
// .getRGB(loader.backgroundPixel));
offScreenImageGC
.setBackground(bgColor != null ? bgColor
: shellBackground);
offScreenImageGC
.fillRectangle(imageData.x, imageData.y,
if (bgColor != null) bgColor.dispose();
break;
case SWT.DM_FILL_PREVIOUS:
/* Restore the previous image before drawing. */
imageData.width, imageData.height,
imageData.x, imageData.y, imageData.width,
imageData.height);
break;
imageDataIndex = (imageDataIndex + 1) % imageDataArray.length;
image.dispose();
/* Draw the off-screen image to the shell. */
shellGC.drawImage(offScreenImage, 0, 0);
/* Sleep for the specified delay time (adding commonly-used slow-down fudge factors). */
try
int ms = imageData.delayTime * 10;
if (ms < 20) ms += 30;
if (ms < 30) ms += 10;
Thread.sleep(500);
/* If we have just drawn the last image, decrement the repeat count and start again. */
if (imageDataIndex == imageDataArray.length - 1) repeatCount--;
catch (SWTException ex)
System.out.println("There was an error animating the GIF");
finally
if (offScreenImage != null && !offScreenImage.isDisposed()) offScreenImage
.dispose();
if (offScreenImageGC != null && !offScreenImageGC.isDisposed()) offScreenImageGC
.dispose();
animateThread.setDaemon(true);
animateThread.start();
System.out.println("There was an error loading the GIF");
while (!shell.isDisposed())
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Current Time: Sat Jul 19 06:51:21 EDT 2025
Powered by FUDForum. Page generated in 0.28282 seconds
