Home » Eclipse Projects » Remote Application Platform (RAP) » Migrating the exsisting Application
Migrating the exsisting Application [message #531692] Wed, 05 May 2010 15:20 Go to next message
Hi All,
Still early days for me in RAP.
I have an existing application which in turn uses EMF,has a Common Navigator view ,XML FIle based Editors, Properties view etc.
I know there are limitations of RAP.I would like to get a heads up of how to go ahead with testing my app for RAP.I was trying to put the my explorer view first in the RAP.For that i had put my plug-ins into the RAP application plug-in, but in turn my plug-in requires some other Eclipse platform Plug-ins.
My problem is that Reduntant plug-ins selected.How do i ensure proper plug-ins are selected as a Target platform.?
Any heads up or some link to case studies as how an exsisting RCP/Plug-in app was converted into an RAP app would be also hugely appreciated.
Thanks and Regards,
Saurav
Re: Migrating the exsisting Application [message #531816 is a reply to message #531692] Thu, 06 May 2010 04:39 Go to previous messageGo to next message
Hi Saurav,
the good news first: you can use EMF core and EMF-generated editors with
RAP [1]. The Common Navigator Framework is not yet available for RAP,
there is an open feature request with some experimental code [2]. Please
note that many platform bundles will not work with RAP without changes
because they are not multi-user ready. So simply dragging dependencies
into your target might not work as expected. I would recommend to start
single-sourcing with a small subset of your application and extend bit
by bit.
Hope this helps to get you started.
Regards, Ralf
[1] http://wiki.eclipse.org/RAP/EMF_Integration
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=288761
saurav wrote:
> Hi All,
> appreciated.
> Thanks and Regards,
> Saurav
Re: Migrating the exsisting Application [message #532516 is a reply to message #531816] Mon, 10 May 2010 07:23 Go to previous messageGo to next message
Hi Ralf,
Thanks for the reply.
I am slowly getting into the groove of RAP.
My application does depend on several plug-ins of WTP
like org.eclipse.wst.jsdt.core.
Do we have support for those plug-ins on RAP ?.
cheers,
Saurav
Re: Migrating the exsisting Application [message #532764 is a reply to message #532516] Tue, 11 May 2010 03:34 Go to previous message
There is neither support for resources nor for full-featured source code
editors in RAP, which currently prevents the adoption of IDE features.
I'm sorry. If your application is supposed to be some kind of Web-IDE,
you'll need to implement those features (resources management, code
editors) on your own.
Regards, Ralf
Previous Topic:Need Deployment Files have no CVS
Next Topic:CSS font
Current Time: Sun Jul 20 17:30:38 EDT 2025
Powered by FUDForum. Page generated in 0.24433 seconds
