Home » Modeling » EMF » More generics in EMF/JFace
More generics in EMF/JFace [message #532432] Sun, 09 May 2010 18:41 Go to next message
I'm an EMF/JFace newbie. I've designed a fairly simple model as well as
various SWT/Jface GUI elements to edit parts of my model with the help
of JFace databinding. I'm quite happy with the result. However, I find
that many times, an increased usage of generics could improve the type
safety of EMF/JFace related code a lot.
For instance, one of the most useful things I'd like is if
EStructuralFeature was defined as EStructuralFeature<D,T>, where D would
be the declaring type, and T the feature type. Are there reasons not to
do this? Contrary to Field and Method in Java's own reflection system,
we do have the literals of all our structural features in EMF, which
could be declared with the full type information. Getting this
additional information (together with more generics in interfaces like
ILabelProvider, IObservableList, etc.) would be great; for now, I really
have the feeling that I'm dealing with Objects and a lot of casts all
over the place, which I'm uncomfortable with.
Any chance we'll be going this direction in the future?
Thanks a lot,
Jean-Philippe
[cross-posting this to eclipse.tools.emf and eclipse.platform.jface]
Re: More generics in EMF/JFace [message #532448 is a reply to message #532432] Mon, 10 May 2010 02:27 Go to previous messageGo to next message
Jean-Philippe,
Comments below.
J.-P. Pellet wrote:
> as various SWT/Jface GUI elements to edit parts of my model with the
> help of JFace databinding. I'm quite happy with the result. However, I
> find that many times, an increased usage of generics could improve the
> type safety of EMF/JFace related code a lot.
> would be the declaring type, and T the feature type. Are there reasons
> not to do this?
Yes.
> Contrary to Field and Method in Java's own reflection system, we do
> have the literals of all our structural features in EMF, which could
True, but when we have such generated literals, we also have a generated
API that provides the full type safety.
> Getting this additional information (together with more generics in
> interfaces like ILabelProvider, IObservableList, etc.) would be great;
> for now, I really have the feeling that I'm dealing with Objects and a
> lot of casts all over the place, which I'm uncomfortable with.
Given the erased nature of Java-style generics, runtime type safety is a
bit of an illusion
No. We did consider it at the time, but it seems to me that in almost
cases where you'd benefit from such a thing you could better use the
generated API. One of the places you'd want to use it is in eGet, but
depending on whether the feature is multi-valued you'd get either
EList<T> or T.
> Thanks a lot,
> Jean-Philippe
Re: More generics in EMF/JFace [message #532479 is a reply to message #532448] Mon, 10 May 2010 04:30 Go to previous messageGo to next message
Ed,
Thanks for your answer. I have a few more questions/remarks...
> bit of an illusion
What do you mean? If I use no raw types and there are no "unchecked"
warnings in my code, then I get run-time type safety even if generics
are implemented with erasure, no? Why would this be an illusion?
> EList<T> or T.
What's wrong with making multi-valued features map to
EStructuralFeature<D, EList<T>>?
generated API that provides the full type safety.
But sometimes it's nice to pass those features around and still know
what they types refer to. Can you give me some pointers on where to
start if I want to extend/customize the generator so that this
information is available to me in client code?
And now JFace: what about IObservableList and related databinding
interfaces? Any chance those will have a parametrized version soon?
J.-P.
Re: More generics in EMF/JFace [message #532488 is a reply to message #532432] Mon, 10 May 2010 05:00 Go to previous messageGo to next message
What would EStructuralFeature<D,T> help? The only area it would is when
calling eGet()/eSet() which are hidden anyways by EMF-Databinding.
JFace-Viewers can't use generics because it is constrainted to Java 1.3.
Tom
Am 10.05.10 00:41, schrieb J.-P. Pellet:
> Thanks a lot,
> Jean-Philippe
Re: More generics in EMF/JFace [message #532696 is a reply to message #532488] Mon, 10 May 2010 17:04 Go to previous messageGo to next message
Even if eGet()/eSet() do not use this information, it would be useful.
Take the example of creating Table columns. A lot of repetitive things
have to be done while creating a column - manage sorting, set label and
icon provider, set layout data, etc., so I do this in a separate method,
and I use my own class EMFColumnData to save the needed info.
Simplified, the relevant part looks like this:
public class EMFColumnData {
public final EStructuralFeature feature;
public final IColumnLabelProvider labelProvider;
public EMFColumnData( EStructuralFeature feature,
IColumnLabelProvider labelProvider ) {
this.feature = feature;
this.labelProvider = labelProvider;
public interface IColumnLabelProvider {
String getText( Object element, Object feature );
Now, each time I implement IColumnLabelProvider I have to cast element
(which is the object represented by the column row) and feature (the
element's feature for this column). I'd love to declare it this way instead:
public class EMFColumnData<D,T> {
public final EStructuralFeature<D,T> feature;
public final IColumnLabelProvider<D,T> labelProvider;
public EMFColumnData( EStructuralFeature<D,T> feature,
IColumnLabelProvider<D,T> labelProvider ) {
public interface IColumnLabelProvider<D,T> {
String getText( D element, T feature );
And I'd avoid passing a feature with an incompatible type. In some other
places, in a utility method I would like to accept features that belong
to a given class BaseClass or its descendents only, and would enjoy
writing this:
void someMethod( EStructuralFeature<? extends BaseClass, ?> feature );
Does this look absurd to you?
What about other things like EClass<T>? Much in the vein of Class<T>?
Ouch! Is this going to change some day, soon? I understand that legacy
environment have to be supported, but it is too bad that it is at such a
cost for developers who can use Java 5 or 6.
Has no effort been made to introduce more generics into JFace
databinding? IObservableValue, IObservableList & co. are just begging
for a parametrized version... :-) I'd gladly invest some time in this.
Best,
J.-P.
Re: More generics in EMF/JFace [message #532736 is a reply to message #532696] Tue, 11 May 2010 01:58 Go to previous messageGo to next message
Am 10.05.10 23:04, schrieb J.-P. Pellet:
> instead:
> writing this:
Ok. I can see your use case.
No. I started on working for this in e4 but didn't had time to implement
it fully. The viewers in UFaceKit are generified but they have not the
same featureset JFace-Viewers have today.
Same applies to databinding. We try to keep the level very low (think
about embedded systems).
Tom
Re: More generics in EMF/JFace [message #532835 is a reply to message #532479] Tue, 11 May 2010 06:51 Go to previous messageGo to next message
Jean-Philippe,
Comments below.
J.-P. Pellet wrote:
> Ed,
>> is a bit of an illusion
Because libraries themselves are rife with unchecked warnings, so one
must rely on the tested correctness of the type safety they provide
rather than be absolute guaranteed of it. No doubt the collection
classes are free of such errors, but that's not guaranteed by the
compiler nor fail-fast at runtime. That's not even pointing out that it
can easily and accidentally be subverted with problem showing up far
from their origin.
>> almost cases where you'd benefit from such a thing you could better
>> use the generated API. One of the places you'd want to use it is in
>> eGet, but depending on whether the feature is multi-valued you'd get
>> either EList<T> or T.
Yes, there are bunch of approaches. One could even add more type
arguments so you might have EStructuralFeature<D, T, EList<T>> to
separate out the feature's type from the actual return type of the getter.
Yes, people made those arguments and in the edit, those sometimes
generally reduced to places where using the generated API was actually
more natural.
> Can you give me some pointers on where to start if I want to
> extend/customize the generator so that this information is available
Without sweeping changes in the Ecore model itself, I don't see how this
will pan out.
It would be nice if the platform could decide between supporting Java ME
stuck in the 1.4 days verses Java as it evolves to 1.7, but it's hard to
please everyone with one thing.
> Cheers,
> J.-P.
Re: More generics in EMF/JFace [message #532860 is a reply to message #532736] Tue, 11 May 2010 07:57 Go to previous messageGo to next message
--------------000707020105040408090401
Guys,
Comments below.
>> instead:
What actually interesting things can you do knowing D and T? They're
completely unconstrained so generically you can only assume
java.lang.Object as possible substitutions.
>> writing this:
I'm not sure how this pans out in context either....
I'm still doubtful.
At least this is simpler than the feature case, but I still argue its
utility is greatly limited. In the end, parameterizing the Ecore model
itself would have resulted in much more disruptive changes in all the
downstream usage, only a very very tiny portion of which would have
derived any real value from it. Look how quickly your example above
degrades into using ? all over the place.
> Tom
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Guys,<br>
<br>
Comments below.<br>
<br>
Tom Schindl wrote:
<blockquote cite="mid:hsarli$sfk$1@build.eclipse.org" type="cite">
<pre wrap="">Am 10.05.10 23:04, schrieb J.-P. Pellet:
</pre>
<blockquote type="cite">
<pre wrap="">What would EStructuralFeature&lt;D,T&gt; help? The only area it would is when
</pre>
</blockquote>
<pre wrap="">Even if eGet()/eSet() do not use this information, it would be useful.
instead:
public class EMFColumnData&lt;D,T&gt; {
public final EStructuralFeature&lt;D,T&gt; feature;
public final IColumnLabelProvider&lt;D,T&gt; labelProvider;
public EMFColumnData( EStructuralFeature&lt;D,T&gt; feature,
IColumnLabelProvider&lt;D,T&gt; labelProvider ) {
public interface IColumnLabelProvider&lt;D,T&gt; {
</pre>
</blockquote>
</blockquote>
What actually interesting things can you do knowing D and T?&nbsp; They're
java.lang.Object as possible substitutions.<br>
<pre wrap="">
writing this:
void someMethod( EStructuralFeature&lt;? extends BaseClass, ?&gt; feature );
</pre>
</blockquote>
</blockquote>
I'm not sure how this pans out in context either....<br>
<pre wrap="">
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
I'm still doubtful.<br>
<pre wrap="">
</pre>
<pre wrap="">What about other things like EClass&lt;T&gt;? Much in the vein of Class&lt;T&gt;?
</pre>
</blockquote>
</blockquote>
utility is greatly limited.&nbsp; In the end, parameterizing the Ecore model
derived any real value from it.&nbsp; Look how quickly your example above
degrades into using ? all over the place.<br>
<pre wrap="">
</pre>
<pre wrap="">JFace-Viewers can't use generics because it is constrainted to Java 1.3.
</pre>
</blockquote>
<pre wrap="">Ouch! Is this going to change some day, soon? I understand that legacy
</pre>
</blockquote>
</pre>
<pre wrap="">Has no effort been made to introduce more generics into JFace
databinding? IObservableValue, IObservableList &amp; co. are just begging
</pre>
</blockquote>
Tom
</pre>
</blockquote>
</body>
</html>
--------------000707020105040408090401--
Re: More generics in EMF/JFace [message #532968 is a reply to message #532860] Tue, 11 May 2010 12:58 Go to previous messageGo to next message
Actually this is quite useful. If I create a EMFColumnData<ModelObject,
String>, then I can sure that I pass a compatible EStructuralFeature,
and that my IColumnLabelProvider gets a ModelObject and a String
directly, without the need to dangerously cast two Objects. If I
copy-paste my EMFColumnData and change the feature to something else
that's incompatible with the label provider, I get a compile-time error.
Suppose I have a method in some utility class setupTableViewer() that
sets up a viewer to work with all objects derived from some BaseClass
(which, say, all have a name and a timestamp in common). If I want to
pass additional features to this method (say, to create additional
columns), I would like to make sure that they are applicable to
BaseClass, hence this parametrization: EStructuralFeature<? extends
BaseClass, ?>.
I agree that there are too many "?". We could imagine that the
EStructualFeature interface remains parameterless, which can be used as
before by everyone, but that the literals are typed something like
EStructualFeatureX<D,T>, where EStructualFeatureX extends
EStructualFeature. Same with EClass/EClassX<T>. This makes more type
information available with minimal changes to the public interface and
no require change to user code.
A workaround that I'm implementing now is to extend
org.eclipse.emf.codegen.ecore.generatorAdapters with my own generator. I
am creating an extra package interface named "<modelname>PackageX" that
holds parametrized literals of the type EClassX<T>, etc. These
"extended" literals do nothing but provide the extra type information
and wrap the standard literals.
Best,
J.-P.
Re: More generics in EMF/JFace [message #532969 is a reply to message #532968] Tue, 11 May 2010 13:22 Go to previous message
J.-P.,
Comments below.
> EMFColumnData<ModelObject, String>, then I can sure that I pass a
> compatible EStructuralFeature, and that my IColumnLabelProvider gets a
> ModelObject and a String directly, without the need to dangerously
> cast two Objects. If I copy-paste my EMFColumnData and change the
> feature to something else that's incompatible with the label provider,
What I'm wondering about is how you'd actually do anything interesting
to implement the getText method. Of course JFace itself doesn't provide
any of this generic stuff either...
> BaseClass, ?>.
It's clear one can come up with examples that are relatively interesting
but how generally useful such things will be isn't as clear.
>> model itself would have resulted in much more disruptive changes in
>> all the downstream usage, only a very very tiny portion of which
>> would have derived any real value from it. Look how quickly your
>> example above degrades into using ? all over the place.
> as before by everyone, but that the literals are typed something like
People already complain that EMF is too complex, so adding more
complexity with very significant added value isn't at all appealing.
> I am creating an extra package interface named "<modelname>PackageX"
> that holds parametrized literals of the type EClassX<T>, etc. These
Maybe you'll want to write an interesting article about it. That would
be cool...
> Best,
> J.-P.
Previous Topic:Problem with namespace and capitalization during XML serialization
Next Topic:EList ordered or not
Current Time: Sat Jul 19 11:43:59 EDT 2025
Powered by FUDForum. Page generated in 1.08097 seconds
