Installing agent controller on Tomcat6 [message #532342] |
Sat, 08 May 2010 11:42  |
I would like to try the TPTP plugin under eclipse. I have a tomcat6 server running on Ubuntu 9.10, hosting a web application. The server is running fine.
I downloaded an agent controller and unziped it in /home/tomcat/agent_controller.
The I added a few lines in the tomcat startup script /etc/init.d/tomcat6 :
export TPTP_AC_HOME=/home/tomcat/agent_controller
export JAVA_PROFILER_HOME=$TPTP_AC_HOME/plugins/org.eclipse.tptp.ja vaprofiler
export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$JAVA_PROFILER_HOME:$TPTP_AC_HOME/lib "
JAVA_OPTS="$JAVA_OPTS -agentlib:JPIBootLoader=JPIAgent:server=enabled\;GCProf"
When I run the startup script, I fails. I got the following error message in /var/log/syslog:
jsvc.exec[5301]: Error occurred during initialization of VM
jsvc.exec[5301]: Could not find agent library on the library path or in the local directory: JPIBootLoader
I believe java fails to load my /home/tomcat/agent_controller/plugins/org.eclipse.tptp.javap rofiler/libJPIBootLoader.so. I think my LD_LIBRARY_PATH is ok, but I'm not sure this environment variable is really transmitted. I also tried to replace -agentlib by -agentpath and write directly the .so path, but it didn't work either.
I also temporarly set all /home/tomcat permissions to 777, so I'm sure the libJPIBootLoader.so can be accessed.
A little help would be greatly appreciated !
Thank you in advance.
Re: Installing agent controller on Tomcat6 [message #532646 is a reply to message #532342] |
Mon, 10 May 2010 12:17  |
Hi Olivier,
As you may have guessed, the error message you are seeing is due to the environment variables not being set properly:
Try with the following environment:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$JAVA_PROFILER_HOME:$TPTP_A C_HOME/lib
JAVA_OPTS="$JAVA_OPTS -agentlib:JPIBootLoader=JPIAgent:server=enabled\;CGProf"
I have removed spaces, and quotation marks, and updated 'GCProf' to CGProf. You may need to adjust the semicolons, quotation marks and backslashes on your JAVA_OPTS line such that they are interpreted properly by Linux.
FUDForum. Page generated in 0.03506 seconds
