Home » Archived » M2M (model-to-model transformation) » how can I explore .xmi files othther than text editor(xmi editor in UML2Java example)
how can I explore .xmi files othther than text editor [message #532336] Sat, 08 May 2010 09:21 Go to next message
Hi all
in the example UML2Java i found no ecore,KM3 metamodels for java but xmi for both uml and Java
How could I explore them given that i could not import them using magic draw forexample
is there an editor in eclipse or s th like that
wafaa
Re: how can I explore .xmi files othther than text editor [message #533422 is a reply to message #532336] Thu, 13 May 2010 15:26 Go to previous messageGo to next message
On 08.05.10 15.21, wafaa wrote:
> Hi all
> draw forexample
XMI-files can usually be edited by using Open with->Other... Sample
Reflective Ecore Model editor.
Hallvard
Re: how can I explore .xmi files othther than text editor [message #533423 is a reply to message #533422] Thu, 13 May 2010 15:34 Go to previous message
yes, thank u very much Hallvard
Actually it generated errors due to missing packages as it says by the error window but when i run the program it works well, i wanted to navigate the metamodels to follow up the transformation but it shows error, I tried many versions of eclipse.
if some one has tried the example or investigated similar problem please notify me
thanks again
Previous Topic:[Xtend] Workflow interrupted
Next Topic:I don't want a reference !
Current Time: Sat Jul 19 19:53:10 EDT 2025
Powered by FUDForum. Page generated in 0.03604 seconds
