Home » Eclipse Projects » Rich Client Platform (RCP) » Popup / Context Menu on a View without a Viewer
Popup / Context Menu on a View without a Viewer [message #532303] Fri, 07 May 2010 16:53 Go to next message
Hi, I've been looking around to find how to add a popup / context menu to a View, and all the documentation seems to require a "viewer" to be able to add a popup menu. In the specific circumstance I'm attempting to solve, I don't use a Viewer in this view (The view just displays an image directly on the Canvas). Is there a way to add a popup menu to this?
Here's the code that I've been seeing (roughly):
MenuManager menuMgr = new MenuManager();
menuMgr.setRemoveAllWhenShown(true);
menuMgr.addMenuListener(new IMenuListener() {
    public void menuAboutToShow(IMenuManager mgr) {
        fillContextMenu(mgr);
// Create menu.
Menu menu =
    menuMgr.createContextMenu(viewer.getControl());
viewer.getControl().setMenu(menu);
// Register menu for extension.
getSite().registerContextMenu(menuMgr, viewer);
Now, I've attempted to do this in the 'createPartControl(Composite)' method, but have had no luck in getting it to work. Here's my approach:
public void createPartControl(Composite pParent) {
        MenuManager manager = new MenuManager();
        manager.setRemoveAllWhenShown(true);
        manager.addMenuListener(new IMenuListener() {
        Menu menu = manager.createContextMenu(pParent);
        pParent.setMenu(menu);
       getSite().registerContextMenu(manager, this);
All help is greatly appreciated.
R
Re: Popup / Context Menu on a View without a Viewer [message #532370 is a reply to message #532303] Sun, 09 May 2010 00:49 Go to previous messageGo to next message
I don't think you need a Viewer but there are a couple steps here:
1. create the menu on a Control. I guess pParent will work - I've never
tried attaching a menu to a Composite.
* I'm not sure why both this and the previous line are
* required - they seem redundant to me (anyone?)
2. register an ISelectionProvider implementation with which to garner
menu contributions. As context menus are commonly attached to Viewers and
they are all SelectionProviders, they are often used in that registration:
getSite().registerContextMenu(manager, viewer);
I suspect your ViewPart, "this", is not a SelectionProvider so it
couldn't be used in that registration. That should have been a
compilation error though so I could be wrong here somewhere :(
You can instantiate an ISelectionProvider and use it in the registration.
Then, when #getSelection is called on it (upon right-click), provide
whatever object you want in a StructuredSelection, presumably something
displayed in your view. You should get all menu contributions from all
plugins (started or not) appropriate for your selection object.
Also note that I don't think you need the lines:
.... if you use Commands/Handlers/Menus extensions rather than the older
IAction API. Those wizards really need updating Paul ;)
Hope that helps,
Craig Foote
> this?
> // Create menu.
> Menu menu =
> R
Re: Popup / Context Menu on a View without a Viewer [message #532557 is a reply to message #532303] Mon, 10 May 2010 08:55 Go to previous message
Craig's given you some steps.
If you just want a context menu, you don't need to register it with your
site.
Menu menu = menuMgr.createContextMenu(myControl);
myControl.setMenu(menu);
You are creating the context menu on the control that you are going to
right-click on. I think your example will only work if you don't put
anything in your composite :-) although I'm not 100% sure.
You only need to register your context menu if you want
org.eclipse.ui.menus (commands) and org.eclipse.ui.popupMenus (actions)
to be able to contribute to it.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Jboss
Next Topic:How to close a empty editor area automatically?
Current Time: Sun Jul 20 12:10:00 EDT 2025
Powered by FUDForum. Page generated in 0.06638 seconds
