Home » Modeling » M2T (model-to-text transformation) » Strange behaviour of EXPAND statement (expand, null-expression)
Strange behaviour of EXPAND statement [message #531515] Wed, 05 May 2010 06:03 Go to next message
somehow i have a realy strange xpand2 behaviour in an EXPAND call. I have the following code:
«DEFINE statesyntax FOR WFState»
        if state == '«stateName()»': «this.ifstatement.toString()»
«IF ifstatement != null» «EXPAND newstatesyntax FOR ifstatement» «ENDIF»
«ENDDEFINE»
If i ommit the if statement, the expand is executed although ifstatement is null.. I thought that expand wouldn t expand if the FOR expression is null. Isn´t that correct?
Daniel
[Updated on: Wed, 05 May 2010 08:31] by Moderator
Re: Strange behaviour of EXPAND statement [message #531665 is a reply to message #531515] Wed, 05 May 2010 13:54 Go to previous messageGo to next message
Hello Daniel,
yes it should be only invoked when the property is not null. can you share a sample for me that reproduces the problem?
~Christian
Re: Strange behaviour of EXPAND statement [message #531777 is a reply to message #531665] Thu, 06 May 2010 03:41 Go to previous messageGo to next message
Yes sure,
i m using the following xtext-grammer:
WFState:
	'state' name=ID '{'
	(doc=STRING)?
	('entryaction' ':' pyentryaction=STRING)?
	('exitaction'  ':' pyexitaction=STRING)?
	(ifstatement = WFIfStatement (elseifstatments += WFElseIfStatement)*)?
	(gotostatement = WFGotoStatement)?
	(stopstatement = WFFlowstopStatement)?;
WFGotoStatement:
	'goto' state=[WFState];
WFFlowstopStatement:
	flowstop?='flowstop';
WFIfStatement:
	// 'if' expressions=EXpression 'goto' state=[WFState];
	'if' clause=WFIfClause 'goto' state=[WFState];
WFElseIfStatement:
	'elseif' clause=WFIfClause 'goto'state=[WFState];
WFIfClause:
	WFIfClauseEvent | WFIfClauseExpression ;
WFIfClauseEvent:
	'ev' '(' eventname=ID ')';
WFIfClauseExpression:
	'(' pyexpression=STRING ')';
and the following model code:
state Entwurf { entryaction: "self.status = 'new'" }
if ("self.lines.count() > 0") goto Angebot
elseif ev(cancel) goto Abbruch
state Angebot { entryaction: "self.status = 'draft'" }
if ev(confirm) goto Beauftragt
state Beauftragt { entryaction: "self.status = 'accepted'" } flowstop
state Abbruch { entryaction: "self.status = 'canceled'" } flowstop
Then i use the xpand2 template:
REM» WORKFLOW STUFF -------------------------------------------------------------- «ENDREM»
«DEFINE statemachinesyntax FOR WFMainSection»
«EXPAND statesyntax FOREACH states»
«ENDDEFINE»
ifstatement is: «this.ifstatement.toString()»
«ENDDEFINE»
«DEFINE newstatesyntax FOR WFIfStatement»
I WAS EXPANDED
«ENDDEFINE»
what generates:
ifstatement is: org.modellwerk.erpm.mState.impl.WFIfStatementImpl@1a4c5b4
I WAS EXPANDED
ifstatement is: org.modellwerk.erpm.mState.impl.WFIfStatementImpl@6504bc
I WAS EXPANDED
ifstatement is: null
I WAS EXPANDED
I WAS EXPANDED
Thanks for your help,
Dan
Re: Strange behaviour of EXPAND statement [message #531786 is a reply to message #531777] Thu, 06 May 2010 04:20 Go to previous message
Hello, seems the behavour has changed. so you have to add the if.
I don't know what is the expected behavoiour so you may file a bug.
[Updated on: Thu, 06 May 2010 04:36] by Moderator
Previous Topic:[XPand] Passing context / parameters through expansions
Next Topic:[Acceleo] Sequence Diagram to text
Current Time: Sat Jul 19 11:20:10 EDT 2025
Powered by FUDForum. Page generated in 0.27406 seconds
