Home » Language IDEs » Java Development Tools (JDT) » Difference between eclipse and javac
icon5.gif  Difference between eclipse and javac [message #531716] Wed, 05 May 2010 17:37 Go to next message
The following code (in a file called Bad.java) compiles and runs in eclipse (in particular galileo with Build id: 20100218-1602):
public class Bad<T>  {
    public abstract static class Base<S extends Base<S>> {
        public Base(Class<S> sClass) {
            Class<S> theClass = sClass;
            System.out.println(theClass);
            System.out.println(sClass);
    public class Arr extends Base<Arr> {
        public Arr() {
            super(Arr.class);
            System.out.println(Arr.class);
        Bad<Integer> bad = new Bad<Integer>();
        Bad<Integer>.Arr a = bad.new Arr();
        System.out.println(a);
However, javac (I've tried 1.5, 1.6 and 1.7) gives this error:
Bad.java:13: cannot find symbol
symbol  : constructor Base(java.lang.Class<Bad.Arr>)
            super(Arr.class);
1 error
If I change the argument of the Base ctor to "Class sClass" (removing the <S>) javac is happy, though of course there are warnings in both eclipse and javac.
This is on various flavors of Linux if that matters.
Which compiler is correct? I'm wondering if I should I file a bug with eclipse or Sun.
Re: Difference between eclipse and javac [message #532215 is a reply to message #531716] Fri, 07 May 2010 10:48 Go to previous messageGo to next message
I opened bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=312076 for investigation.
Olivier
icon7.gif  Re: Difference between eclipse and javac [message #532314 is a reply to message #532215] Fri, 07 May 2010 20:00 Go to previous message
Thanks! I'll be watching that bug.
Previous Topic:Eclipse freezes often
Next Topic:Platform fails installing JDT
Current Time: Sun Jul 20 08:43:50 EDT 2025
Powered by FUDForum. Page generated in 0.34967 seconds
