Home » Eclipse Projects » EclipseLink » bizarre DATE adjustment during binding
bizarre DATE adjustment during binding [message #530225] |
Wed, 28 April 2010 19:03  |
I'm doing a batch insert with Eclipselink 2.0.2, Oracle JDBC driver
ojdbc5.jar 11.1.0.6.0, and running Oracle 10.2.0.4.0 DB. I've annotated
a java.util.Date with @Temporal(TemporalType.DATE):
@Id
@Column(name="PERIOD_START")
private Date periodStart;
The date is part of the PK, and date values have no time component. For
about half of the inserts the binding is correct, but others are
strangely bound to the day prior:
[EL Fine]: 2010-04-28
16:15:09.406--ClientSession(26440262)--Connection(20153007)- -Thread(Thread[main,5,main])--INSERT
INTO BUDGET_RSRC_CURVE (PERIOD_START, TASKRSRC_ID, BUDGET_TYPE_ID,
TASK_ID, PERIOD_UNITS, DELETE_DATE, AT_COMPLETION_UNITS, PROJ_ID,
UPDATE_DATE, CREATE_USER, PERIOD_COST, AT_COMPLETION_COST, DELETE_USER,
CREATE_DATE, UPDATE_USER) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?,
16:15:09.453--ClientSession(26440262)--Connection(20153007)- -Thread(Thread[main,5,main])--
bind => [2004-08-31, 142719, 2, 35899,
1.517642240537477871242799665196798741817474365234375, null,
16.64731756756756198001312441192567348480224609375, 747, null, P2_USER,
2.435444011444863665616367143229581415653228759765625,
26.71486611486485429622916853986680507659912109375, null, 2010-04-28
15:12:53.515, null]
bind => [2009-05-31, 3357792, 2, 3042074, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 15:14:01.515, null]
16:15:12.921--ClientSession(26440262)--Connection(20153007)- -Thread(Thread[main,5,main])--
bind => [2008-01-01, 1118702, 2, 2335339, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 15:12:54.656, null]
bind => [2005-02-01, 1118813, 2, 2335339, 0, null,
0.0481197860962566947851115628509433008730411529541015625, 747, null,
P2_USER, 0, 4.81197860962566892339964397251605987548828125, null,
2010-04-28 15:12:57.375, null]
16:15:12.937--ClientSession(26440262)--Connection(20153007)- -Thread(Thread[main,5,main])--
bind => [2007-10-31, 8048557, 2, 9036580, 0, null,
4.47829090909090954397697714739479124546051025390625, 747, null,
P2_USER, 0, 447.8290909090909508449840359389781951904296875, null,
2010-04-28 15:14:34.968, null]
bind => [2008-12-01, 1727942, 2, 3042043, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 15:13:31.015, null]
bind => [2008-07-31, 1118715, 2, 2335339, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 15:12:54.796, null]
bind => [2007-10-31, 8922414, 2, 9713611, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 15:14:39.093, null]
bind => [2009-01-01, 1727940, 2, 3042043, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 15:13:29.031, null]
bind => [2006-03-01, 1118893, 2, 2334983,
14.838689732943915799978640279732644557952880859375, null,
13.87078839178081324234881321899592876434326171875, 747, null, P2_USER,
1558.062421959111134128761477768421173095703125,
1456.43278113698534070863388478755950927734375, null, 2010-04-28
15:13:13.64, null]
16:15:12.953--ClientSession(26440262)--Connection(20153007)- -Thread(Thread[main,5,main])--
bind => [2004-12-01, 3260300, 2, 2335047, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 15:13:48.093, null]
bind => [2005-02-01, 6659, 2, 35978, 0, null, 0, 747, null, P2_USER, 0,
0, null, 2010-04-28 15:12:47.843, null]
bind => [2007-09-30, 1118717, 2, 2335339, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 15:12:55.078, null]
bind => [2007-09-30, 1118838, 2, 2334984, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 15:13:02.765, null]
bind => [2008-06-30, 1118814, 2, 2335339, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 15:12:57.625, null]
bind => [2009-02-01, 8166315, 2, 2334983,
0.49032192161031940003113049897365272045135498046875, null, 0, 747,
null, P2_USER, 49.0321921610319435558267286978662014007568359375, 0,
null, 2010-04-28 15:14:37.031, null]
However, when I changed the mapping to use TemporalType.TIMESTAMP, it
binds correctly always:
17:11:03.506--ClientSession(16843259)--Connection(19478135)- -Thread(Thread[main,5,main])--INSERT
17:11:05.069--ClientSession(16843259)--Connection(19478135)- -Thread(Thread[main,5,main])--
bind => [2008-01-01 00:00:00.0, 6192516, 2, 7509227,
4.6675985656858554051495957537554204463958740234375, null, 0, 747, null,
P2_USER, 583.449820710731955841765739023685455322265625, 0, null,
2010-04-28 16:10:23.581, null]
bind => [2006-01-01 00:00:00.0, 3260294, 2, 2335047, 0, null, 0, 747,
null, P2_USER, 0, 0, null, 2010-04-28 16:07:30.036, null]
bind => [2007-02-01 00:00:00.0, 4234621, 2, 2334985,
0.12251197917296341444171048351563513278961181640625, null, 0, 747,
null, P2_USER, 12.251197917296341444171048351563513278961181640625, 0,
null, 2010-04-28 16:09:28.921, null]
bind => [2010-10-01 00:00:00.0, 8166315, 2, 2334983,
0.5161283385371806531338734203018248081207275390625, null, 0, 747, null,
P2_USER, 51.61283385371806531338734203018248081207275390625, 0, null,
2010-04-28 16:10:50.271, null]
bind => [2007-06-01 00:00:00.0, 1118717, 2, 2335339, 0, null, 0, 747,
null, P2_USER, 0, 0, null, 2010-04-28 16:05:36.171, null]
bind => [2005-09-01 00:00:00.0, 6652, 2, 35900, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 16:05:09.593, null]
bind => [2005-01-01 00:00:00.0, 1118644, 2, 2335336,
0.0025919990928003179900263042156893789069727063179016113281 25, null, 0,
747, null, P2_USER, 15.55199455680190823159136925823986530303955078125,
0, null, 2010-04-28 16:05:25.828, null]
bind => [2007-05-01 00:00:00.0, 1118815, 2, 2335339, 0, null, 0, 747,
null, P2_USER, 0, 0, null, 2010-04-28 16:05:40.75, null]
bind => [2007-04-01 00:00:00.0, 3260301, 2, 2335047, 0, null, 0, 747,
null, P2_USER, 0, 0, null, 2010-04-28 16:07:43.881, null]
bind => [2007-11-01 00:00:00.0, 3447331, 2, 4886278, 0, null, 0, 747,
null, P2_USER, 0, 0, null, 2010-04-28 16:09:12.279, null]
bind => [2007-12-01 00:00:00.0, 5776433, 2, 2335985, 0, null, 0, 747,
null, P2_USER, 0, 0, null, 2010-04-28 16:09:50.61, null]
bind => [2007-07-01 00:00:00.0, 6642, 2, 35899, 0, null, 0, 747, null,
P2_USER, 0, 0, null, 2010-04-28 16:05:06.453, null]
bind => [2005-10-01 00:00:00.0, 2677691, 2, 2335033, 0, null, 0, 747,
null, P2_USER, 0, 0, null, 2010-04-28 16:06:53.534, null]
17:11:05.084--ClientSession(16843259)--Connection(19478135)- -Thread(Thread[main,5,main])--
bind => [2005-11-01 00:00:00.0, 3260294, 2, 2335047, 0, null, 0, 747,
bind => [2006-05-01 00:00:00.0, 1118847, 2, 2334984, 0, null, 0, 747,
null, P2_USER, 0, 0, null, 2010-04-28 16:06:03.546, null]
bind => [2008-02-01 00:00:00.0, 1814180, 2, 3129496, 0, null, 0, 747,
null, P2_USER, 0, 0, null, 2010-04-28 16:06:43.142, null]
Any ideas why we're seeing these inconsistencies with TemporalType.DATE?
I thought it might be a problem with the Oracle JDBC driver, but I
tried with the latest ojdbc6.jar and got the same results.
Note that I've also set the following properties, as recommended for
batch inserts according to
http://forums.oracle.com/forums/thread.jspa?messageID=382956 5 (though I
got the same results without eclipselink.jdbc.batch-writing set):
<property name="eclipselink.jdbc.batch-writing" value="JDBC"/>
<property name="eclipselink.cache.shared.default" value="false"/>
Since it works correctly with TemporalType.TIMESTAMP, we're fine, but
I'd like to know why it's not working consistently with TemporalType.DATE.
Ari
Re: bizarre DATE adjustment during binding [message #531459 is a reply to message #530868] |
Wed, 05 May 2010 02:11   |
Hey Chris,
I ran the test using Calendar with @Temporal(TemporalType.TIMESTAMP),
and I don't see any milliseconds off -- everything looks fine. On
@PrePersist, the logs show data like:
periodStart=java.util.GregorianCalendar[time=1214899200000,a reFieldsSet=true,areAllFieldsSet=true,lenient=true,zone=sun. util.calendar.ZoneInfo[id= "GMT-08:00" ,offset=-28800000,dstSavings=0,useDaylight=false,transitions =0,lastRule=null],firstDayOfWeek=1,minimalDaysInFirstWeek=1, ERA=1,YEAR=2008,MONTH=6,WEEK_OF_YEAR=27,WEEK_OF_MONTH=1,DAY_ OF_MONTH=1,DAY_OF_YEAR=183,DAY_OF_WEEK=3,DAY_OF_WEEK_IN_MONT H=1,AM_PM=0,HOUR=0,HOUR_OF_DAY=0,MINUTE=0,SECOND=0,MILLISECO ND=0,ZONE_OFFSET=-28800000,DST_OFFSET=0]
all records show: MILLISECOND=0
Using Calendar with @Temporal(TemporalType.DATE) gives the same
inconsistencies as java.util.Date does.
Any ideas? I'm fine using @Temporal(TemporalType.TIMESTAMP), but
there's definitely something wrong if I can't use
@Temporal(TemporalType.DATE) in this situation.
Thanks again,
Ari
Ari Meyer wrote:
> Hi Chris,
> I'm running the latest 1.6.0_20, so unless there's been a regression,
> the JDK version is not the issue. Will test with a Calendar and let you
> know how it goes.
> Ari
> Chris Delahunt wrote:
>> Hello,
>> Which JDK are you using? I noticed a strange issue with calendar
>> conversions when using an early JDK 1.6.0 build, causing problems
>> inserting dates since it would shift milliseconds by one or two. They
>> went away when I switched to using jdk 1.6.0_17. You might not be
>> getting the problem when you use a timestamp temporal type if you are
>> using a timestamp in your object since no conversion is neccessary.
>> Try using a timestamp temporal type on a calendar so you can see if
>> the milliseconds are off or not. Best Regards,
>> Chris
Re: bizarre DATE adjustment during binding [message #531465 is a reply to message #531459] |
Wed, 05 May 2010 02:23   |
Also, just to be thorough, the output of the binding for Calendar with
@Temporal(TemporalType.TIMESTAMP) looks fine as well, with all the time
components showing 00:00:00.0:
[EL Fine]: 2010-05-04
18:45:22.328--ClientSession(10130611)--Connection(9995652)-- Thread(Thread[main,5,main])--INSERT
TASK_ID, PERIOD_UNITS, AT_COMPLETION_UNITS, PROJ_ID, UPDATE_DATE,
CREATE_USER, PERIOD_COST, AT_COMPLETION_COST, CREATE_DATE, UPDATE_USER)
VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
18:45:22.343--ClientSession(10130611)--Connection(9995652)-- Thread(Thread[main,5,main])--
bind => [2009-07-01 00:00:00.0, 1727948, 2, 3042045, 0, 0, 747, null,
P2_USER, 0, 0, 2010-05-04 17:45:09.046, null]
bind => [2008-06-01 00:00:00.0, 1727947, 2, 3042045, 0, 0, 747, null,
P2_USER, 0, 0, 2010-05-04 17:45:08.984, null]
bind => [2008-06-01 00:00:00.0, 1727936, 2, 3042043, 0, 0, 747, null,
P2_USER, 0, 0, 2010-05-04 17:45:07.343, null]
18:45:22.375--ClientSession(10130611)--Connection(9995652)-- Thread(Thread[main,5,main])--
bind => [2007-03-01 00:00:00.0, 3758174, 2, 2335032, 0, 0, 747, null,
P2_USER, 0, 0, 2010-05-04 17:45:17.765, null]
bind => [2006-10-01 00:00:00.0, 5776433, 2, 2335985, 0, 0, 747, null,
P2_USER, 0, 0, 2010-05-04 17:45:19.296, null]
bind => [2004-11-01 00:00:00.0, 1118653, 2, 2335337,
0.0054400027200013599537609110257108113728463649749755859375 , 0, 747,
null, P2_USER, 32.6400163200081578906974755227565765380859375, 0,
2010-05-04 17:45:03.25, null]
Ari
Ari Meyer wrote:
> Hey Chris,
> Thanks again,
> Ari
> Ari Meyer wrote:
>> Hi Chris,
>> you know how it goes.
>> Thanks,
>> Ari
>>> Hello,
>>> They went away when I switched to using jdk 1.6.0_17. You might not
>>> be getting the problem when you use a timestamp temporal type if you
>>> are using a timestamp in your object since no conversion is
>>> neccessary. Try using a timestamp temporal type on a calendar so you
>>> can see if the milliseconds are off or not. Best Regards,
>>> Chris
Re: bizarre DATE adjustment during binding [message #536695 is a reply to message #531465] |
Sat, 29 May 2010 21:47   |
Should I log a bug for this, or is this considered expected behavior?
If it's to be expected, please add this to the docs.
Ari
> Regards,
> Ari
> Ari Meyer wrote:
>> Hey Chris,
>> Thanks again,
>> Ari
>> Ari Meyer wrote:
>>> Hi Chris,
>>> Thanks,
>>> Ari
>>>> Hello,
>>>> you can see if the milliseconds are off or not. Best Regards,
>>>> Chris
Current Time: Sun Jul 20 05:30:54 EDT 2025
Powered by FUDForum. Page generated in 0.03606 seconds
