Home » Archived » M2M (model-to-model transformation) » ATL and References in XMI files(ATL and References in XMI files)
ATL and References in XMI files [message #531436] Tue, 04 May 2010 17:13
Hello
I made a transformation using an ATL Kaos metamodel that instantiates of SysML that instantiates also of uml .
I want to know if ATL takes into consideration the references?
for example when i execute i have this error message:
Error loading platform:/resource/stage1/test.sysml: The feature 'nd1' is not a valid feature
test.sysml is a source file:
<uml:Model xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:kaos="http://www.topcased.org/kaos/1" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML">
<packagedElement xsi:type="kaos:AbstractGoal" name="g" clientDependency="#//And1 #//And2" />
<packagedElement xsi:type="kaos:ElementryGoal" name="k"/>
<packagedElement xsi:type="kaos:ElementryGoal" name="m"/>
<packagedElement xsi:type="kaos:And" name="And1" supplier="#//k" client="#//g"/>
<packagedElement xsi:type="kaos:And" name="And2" supplier="#//m" client="#//g"/>
</uml:Model>
It not accept "#//",I would like to know if the reference class And (name And1) is known by ATL.
thanks
Previous Topic:[Xtend] Assign value to Array of EInt
Next Topic:[QVTo] How to specify configuration properties using Ant task?
Current Time: Sun Jul 20 12:05:02 EDT 2025
Powered by FUDForum. Page generated in 0.03365 seconds
