Home » Eclipse Projects » Remote Application Platform (RAP) » Exception when running demo app
Exception when running demo app [message #531213] Tue, 04 May 2010 04:16 Go to next message
Hi all
I downloaded pure eclipse 3.5.2 (RCP bundle), installed it and then installed tha RAP 1.2 via update site by foilllowing instructions here: http://eclipse.org/rap/gettingstarted.php.
Then I created rap.demo app and run it. I got following output:
I'm new to OSGI and RAP. What is wrong - this is "pure" installatoin and I suppose this demo app should run.
I tested it on eclipse 3.6 M5 and 4.0 M5 with similar result.
Thanks for responses.
Radek.
!SESSION 2010-05-04 09:17:08.203 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=cs_CZ
Command-line arguments: -dev file:C:/Users/terber/workspaces/rap/.metadata/.plugins/org.e clipse.pde.core/RAP Application/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.rap.demo 4 0 2010-05-04 09:17:08.777
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui; bundle-version="0.0.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolverError(AbstractBundle.java:1313)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolutionFailureException(AbstractBundle.java:1297)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:309)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:370)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1068)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:557)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:464)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:248)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:445)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:337)
!ENTRY org.eclipse.core.databinding 4 0 2010-05-04 09:17:09.098
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Import-Package: com.ibm.icu.text; version="0.0.0"
!ENTRY org.eclipse.osgi 4 0 2010-05-04 09:17:09.111
!MESSAGE Bundle initial@reference :file:plugins/org.eclipse.core.databinding_1.2.0.M20090819-0 800.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-05-04 09:17:09.112
!MESSAGE Bundle initial@reference :file:../../../../../Users/terber/workspaces/rap/org.eclipse .rap.demo/ was not resolved.
Re: Exception when running demo app [message #531242 is a reply to message #531213] Tue, 04 May 2010 05:54 Go to previous messageGo to next message
Hi Radek,
welcome to the RAP newsgroup. Did you install and switch on the RAP
target platform? How did you create the demo application? How did you
launch it?
Best,
Ivan
On 05/04/2010 11:16 AM, Radek Terber wrote:
> Hi all
> here: http://eclipse.org/rap/gettingstarted.php Then I created
> Radek.
> java.version=1.6.0
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> version="0.0.0"
> !MESSAGE Bundle mailto:initial@reference
> was not resolved.
Re: Exception when running demo app [message #531276 is a reply to message #531213] Tue, 04 May 2010 08:19 Go to previous messageGo to next message
Hi Radek,
have you checked your MANIFEST Require directives?
Check your plugin.xml-Editor. Tab "Dependencies".
Add org.eclipse.rap.ui if necessary.
May be the icu dependency (the other) resolves automatically.
Rob
Am 5/4/2010 10:16 AM, schrieb Radek Terber:
> Hi all
> http://eclipse.org/rap/gettingstarted.php Then I created rap.demo app
> Radek.
> java.version=1.6.0
> x86 -consoleLog
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> version="0.0.0"
> was not resolved.
> was not resolved.
Re: Exception when running demo app [message #531490 is a reply to message #531276] Wed, 05 May 2010 04:41 Go to previous messageGo to next message
All I did was exactly according to the instructions in video-tutorial on this page: "http://eclipse.org/rap/gettingstarted.php" Video on right side) . Demo app was instantied from plugin list. Dependency to "org.eclipse.rap.ui" is registered in "plugin.xml". I have jre 1.6.0 (not an JDK). A launch demo app by click to link "Launch a RAP Application" in in plugin-xml editor (as is described in video tutorial).
Re: Exception when running demo app [message #531537 is a reply to message #531490] Wed, 05 May 2010 07:10 Go to previous messageGo to next message
Hi Radek,
Please confirm that you install the RAP target platform from within
Eclipse Welcome page -> Overview -> Rich Ajax Platform (RAP) -> Install
Target Platform and switch it on (check box is selected).
Best,
Ivan
Re: Exception when running demo app [message #531575 is a reply to message #531537] Wed, 05 May 2010 09:02 Go to previous messageGo to next message
Yes, the checkbox is checked and target platform is installed.
I forgot to wrile it to the last post - I tried run and compile it with both choices - "RAP" and "Running platform" (switching it in preferences). When "Running platform" is selected, the project is even compiled with errors, hence it is evident that the configuration is bad.
Re: Exception when running demo app [message #531624 is a reply to message #531575] Wed, 05 May 2010 11:54 Go to previous messageGo to next message
Hi Radek,
I've followed the screencast step-by-step and everything is working as
expected (Eclipse for RCP/Plug-in Developers 3.5 SR2 + RAP 1.2.2). The
only change that I've made is to use this update site (
*http://download.eclipse.org/rt/rap/1.2/update*) as it is documented
here [1].
[1] http://eclipse.org/rap/gettingstarted.php
Best,
Ivan
On 05/05/2010 4:02 PM, Radek Terber wrote:
> Yes, the checkbox is checked and target platform is installed. I
Re: Exception when running demo app [message #531815 is a reply to message #531490] Thu, 06 May 2010 04:36 Go to previous message
there should be a launch configuration called "RAP Workbench Demo". Did
you try to use this one?
If you are using your own/a generated launch configuration, does
"Validate Plug-ins" report any issues?
HTH
Rüdiger
Previous Topic:Vertical label
Next Topic:Eclipse RAP and OSGi DS
Current Time: Sun Jul 20 12:09:17 EDT 2025
Powered by FUDForum. Page generated in 0.09269 seconds
