Home » Language IDEs » PHP Development Tools (PDT) » External Tools - selected text to tool's stdin
External Tools - selected text to tool's stdin [message #529633] Mon, 26 April 2010 11:19 Go to next message
When I define an External Tool, is there a way to pass currently selected text to the tool's standard input?
I've been using this feature a lot in EditPadPro. I mark a piece of text, click a tool and the text is replaced by whatever output from the tool.
Thanks in advance...
Re: External Tools - selected text to tool's stdin [message #529796 is a reply to message #529633] Tue, 27 April 2010 05:10 Go to previous messageGo to next message
On 2010-04-26 17:19, hemil wrote:
> Hello,
Sounds like you are looking for this:
${selected_text}
For input use standard pipes or just write that to temp file and then pass this
file to Your program.
> tool.
Should be easy, I hope You will succeed :)
Please then share final script :)
dominik
Re: External Tools - selected text to tool's stdin [message #529878 is a reply to message #529633] Tue, 27 April 2010 10:35 Go to previous messageGo to next message
Thanks for the suggestion.
I didn't mention I am on windows xp.
I am unable to send the ${selected_text} data to the command line tool's standard input. Is this possible with Eclipse's External Tools settings?
A compromise I arrived at works like in the following example, which runs the marked text as PHP code and displays the result in the console panel.
In External Tools Configuration:
Arguments: -r "${selected_text}"
The selected text variable in Arguments must be enclosed in double quotes.
The selected text in the editor cannot contain double quotes.
Re: External Tools - selected text to tool's stdin [message #530536 is a reply to message #529878] Thu, 29 April 2010 22:49 Go to previous messageGo to next message
In this way.
Arguments: /c echo ${selected_text}|php.exe
However,
Exactly...
Also,
I believe it is impossible.
Unless there is a plugin which can
1. execute an external tool
2. send selected text in the editor to stdin
3. grab output from the tool
4. replace selected text with grabbed text
Any lacks?
Re: External Tools - selected text to tool's stdin [message #530621 is a reply to message #529633] Fri, 30 April 2010 06:59 Go to previous messageGo to next message
Thanks a lot for the advice.
It works for me.
I came across another character which the selected text cannot contain - the ampersand &
A little observation - on the build tab in External Tools Configuration panel we can uncheck "Build before launch" to prevent the Save changes prompt when running the tool. We're only only using ${selected_text}, so the file will remain untouched.
Re: External Tools - selected text to tool's stdin [message #530865 is a reply to message #530536] Sat, 01 May 2010 22:51 Go to previous messageGo to next message
http://sourceforge.jp/projects/pdt-tools/releases/?package_i d=9452
->Substituter
Re: External Tools - selected text to tool's stdin [message #531219 is a reply to message #529633] Tue, 04 May 2010 04:39 Go to previous messageGo to next message
I didn't realize you were planning to create such a plugin.
Wonderful! Thank you.
I am testing it right now. Here are my notes:
- works well when the selection is fairly short
- when I marked a larger volume of text, eclipse (galileo) hangs,
90 chars OK, 100 chars - eclipse stops responding
- if I needed to set up several tools using this plugin, what would be the procedure?
- would it be possible to choose between replacing the selected text and outputting the result to the console individually for each tool?
Thanks for your time, don't work on this anymore unless it goes with the flow Smile
Re: External Tools - selected text to tool's stdin [message #532061 is a reply to message #529633] Thu, 06 May 2010 20:27 Go to previous messageGo to next message
Sorry! The plugin had too cheap implementation.
It is impossible for now.
It is impossible for now too.
I will update the plugin in a few days. Smile
Re: External Tools - selected text to tool's stdin [message #551539 is a reply to message #529878] Fri, 06 August 2010 17:45 Go to previous messageGo to next message
hemil wrote on Tue, 27 April 2010 10:35
This is very cool! I I think will use this a lot... Also to execute PHP scripts that genereate/return slug-text, database queries (based on a table name) and maybe a few other things Smile
Re: External Tools - selected text to tool's stdin [message #1709974 is a reply to message #551539] Fri, 02 October 2015 06:37 Go to previous message
I am looking for a tool exactly like the Substituter tool mentioned above.
It appears the link to the tool is now dead. Does anyone know where I can get this plugin from, or know of anything with similar functionality?
Darren
Previous Topic:Indicating syntax error when it's none
Next Topic:PDT 3.6 released with Mars.1 !
Current Time: Sun Jul 20 19:57:20 EDT 2025
Powered by FUDForum. Page generated in 0.04646 seconds
