Home » Eclipse Projects » SWTBot » Using SWT Bot with GMF - GEF
Using SWT Bot with GMF - GEF [message #487736] Thu, 24 September 2009 05:46 Go to next message
Hello Mariot,
I see that you are attending to make a presentation in the eclipse summit in Octobre 2009
(see http://www.eclipsecon.org/summiteurope2009/sessions?id=966)
In the overview you are refering about testing on GMF / GEF.
I wonder if you can send an example how to get the EditPart and navigate into it.
You are referring about the recent GEF support contribution.
I'm using the 2.0.0.394-dev-e34. Is it already containing the GMF / GEF support ?
Thanks a lot.
Ivan
Re: Using SWT Bot with GMF - GEF [message #487807 is a reply to message #487736] Thu, 24 September 2009 09:22 Go to previous messageGo to next message
Hi Ivan,
Thanks for your interest for SWTBot GEF/GMF support.
Comments below
Truong Ivan a écrit :
> Hello Mariot,
Yes I will be there :)
> into it.
Please have a look to the code attached to https://bugs.eclipse.org/bugs/show_bug.cgi?id=269609.
You will find an example.
> support ?
I committed yesterday the code into the SWTBot svn. I need now to work with ketan to build the new plugin.
So it's not included in 2.0.0.394-dev-e34.
> Thanks a lot.
> Ivan
Mariot
Re: Using SWT Bot with GMF - GEF [message #530794 is a reply to message #487807] Fri, 30 April 2010 22:03 Go to previous messageGo to next message
Hi Mariot, or others who may know ...
First, I'm having some trouble finding good examples of SWT-Bot code with GEF. I clicked on that link but it says the bug cannot be found.
Second, I have a situation where I am trying to test a GEF editor. and whenever the mouse is positioned in this GEF editor, without even clicking on anything, just hovering, a toolbar pops up (assuming the mouse isn't moving). However, SWT-Bot spy view doesn't change as I hover over the toolbar buttons.
It shows:
//Shell/-1//Composite/4//Composite/0//Composite/10//Composit e/0//Composite/0//FlyoutPaletteComposite/0//RulerComposite/2 //FigureCanvas/0
I tried accessing these buttons with the GEF toolBarButton API, using the tooltip string, but it does not recognize them. Any idea?
Finally, is there a way to search for objects created in the GEF editor, so that you can get their x,y positions? Say if you wanted to find a node so that you could then draw a line from that node to another node.
Thanks!
Steve
Re: Using SWT Bot with GMF - GEF [message #530948 is a reply to message #530794] Mon, 03 May 2010 03:14 Go to previous messageGo to next message
You can find some examples of SWTBot tests on GMF editor in Bonita Open Solution code base [1].
AFAIK, you'll have to use the "regular" GEF API to retrieve your diagram, browse it to find your nodes, and get locations from the figures of EditParts.
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: Using SWT Bot with GMF - GEF [message #530951 is a reply to message #530948] Mon, 03 May 2010 03:28 Go to previous message
Sorry, missed the link to example: http://www.bonitasoft.org/websvn/filedetails.php?repname=Bon ita+Open+Solution&path=%2Fbonita-studio%2Ftrunk%2Ftests% 2Forg.bonitasoft.studio.diagram.test%2Fsrc%2Forg%2Fbonitasof t%2Fstudio%2Fdiagram%2Ftest%2FDiagramTests.java
Previous Topic:junit4 headless doesn't seem to work with CDT master zip plugin
Next Topic:RCP with SWTBOT
Current Time: Sun Jul 20 02:35:39 EDT 2025
Powered by FUDForum. Page generated in 0.04065 seconds
