Home » Modeling » EMF » ID Attribute Name
ID Attribute Name [message #530928] Sun, 02 May 2010 20:48 Go to next message
I have XML documents that use "ID" as the ID attribute name. I am currently using ExtendedMetaData. What is the best approach to enable automatic recording of extrinsic IDs in the Resource? From what I have read, XMLMap is not compatible with ExtendedMetaData and the two should not be used together.
JT
Re: ID Attribute Name [message #530981 is a reply to message #530928] Mon, 03 May 2010 05:12 Go to previous messageGo to next message
JT,
You'll see someone else asked a similar question recently in the thread
"automatic assignment of generated UUID to attribute with property
ID=true [intrinsic]".
> JT
Re: ID Attribute Name [message #530990 is a reply to message #530928] Mon, 03 May 2010 05:33 Go to previous messageGo to next message
Ed:
Thanks for the reply. I don't want intrinsic IDs. After reviewing the source code, I see that in XMLHandler idAttribute is set to the value of xmlMap.getIDAttributeName() and in SAXXMLHandler, if an attribute exists with a name that is equal to idAttribute, then the extrinsic ID is set automatically. So I think what I want is something like:
XMLMap xmlMap = new XMLMapImpl();
xmlMap.setIDAttributeName("ID");
resource.getDefaultLoadOptions().put(XMLResource.OPTION_XML_MAP, xmlMap);
However, my concern is that I am already using ExtendedMetaData as an option on the same resource. I am wondering if it is a good idea to use both options simultaneously. From other posts, it seems that it is not recommended. Please advise.
JT
[Updated on: Mon, 03 May 2010 06:00] by Moderator
Re: ID Attribute Name [message #530997 is a reply to message #530990] Mon, 03 May 2010 05:37 Go to previous message
JT,
If necessary (if the XML map option interacts badly; it wasn't designed
to be used with extended meta data) you can construct a specialized
instance of XMLHandler and set idAttribute directly.
> Ed:
> boolean useIDs() { return true; }
> resource.getDefaultLoadOptions().put(XMLResource.OPTION_XML_ MAP, xmlMap);
> JT
Previous Topic:The feature 'mixed' of **** with 2 element values must have exactly 1 element value
Next Topic:EContentAdapter
Current Time: Sat Jul 19 20:39:49 EDT 2025
Powered by FUDForum. Page generated in 0.04229 seconds
