Home » Language IDEs » Java Development Tools (JDT) » Eclipse ant build reports "cannot find symbol [javac] symbol : XXXX" (Eclipse ant build reports "cannot find symbol [javac] symbol : XXXX" )
Eclipse ant build reports "cannot find symbol [javac] symbol : XXXX" [message #530759] Fri, 30 April 2010 13:44
Hi, all:
Sorry to ask such a newbie question.
I'm trying to compile "java-ml" using Eclipse 3.5.2 IDE.
http://java-ml.sourceforge.net/
It's strange that I'm not able to compile(ant build) this package from within Eclipse IDE, and always obtained the following error message
cannot find symbol [javac] symbol : class svm_parameter
For this project, Eclipse IDE doesn't show any red cross, which means this project should be able to be successfully compiled.
But, whenever I'm trying to "ant build" from within Eclipse IDE, I obtained the above error message, which seems to tell ant build can't find some package.
So, "ant build" seems to build project using file "build.xml".
And the packages that the error message indicates are mostly stored in
/usr/share/java
What can I do?
Do I just need to add
/usr/share/java
to my environment's path?
Best Regards
JIA
Previous Topic:compiler creates generated fields/methods when class switches on enum
Next Topic:How to set a non normal application as JRE for Running in a Project
Current Time: Sat Jul 19 13:24:46 EDT 2025
Powered by FUDForum. Page generated in 0.06209 seconds
