Home » Modeling » EMF » ChangeDescription#applyAndReverse not "circular"
ChangeDescription#applyAndReverse not "circular" [message #530743] Fri, 30 April 2010 12:37 Go to next message
Hi all, Hi Ed,
I'm using a (slightly) modified ChangeRecorder and ChangeDescription and
I'm currently facing an issue that sounds to me as a bug in the EMF
change model.
As far as I know, it should be possible to call applyAndReverse
repeatedly and the model would switch repeatedly between 2 states.
Calling applyAndReverse twice should give me the exact same model as in
the initial state.
In order to track down the problem, I created a dummy model:
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="test"
nsURI="http://www.ruag.com/test/v1" nsPrefix="">
<eClassifiers xsi:type="ecore:EClass" name="A">
<eStructuralFeatures xsi:type="ecore:EReference" name="elements"
upperBound="-1"
eType="#//B" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="B">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
lowerBound="1" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="children"
upperBound="-1"
</eClassifiers>
</ecore:EPackage>
Here comes the example:
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns="http://www.ruag.com/test/v1"
xmlns:change="http://www.eclipse.org/emf/2003/Change">
<A>
<elements name="B group">
<children name="B0"/>
<children name="B1"/>
<children name="B2"/>
<children name="B3"/>
</elements>
</A>
<change:ChangeDescription>
<objectChanges key="/0">
<value featureName="elements">
<listChanges index="0"
referenceValues="/0/@elements.0/@children.0"/>
<listChanges index="1"
referenceValues="/0/@elements.0/@children.1"/>
<listChanges index="2"
referenceValues="/0/@elements.0/@children.2"/>
<listChanges index="3"
referenceValues="/0/@elements.0/@children.3"/>
<listChanges kind="REMOVE" index="4"/>
</value>
</objectChanges>
</change:ChangeDescription>
</xmi:XMI>
applyAndReverse
<A>
<elements name="B0"/>
<elements name="B1"/>
<elements name="B2"/>
<elements name="B3"/>
</A>
<listChanges index="4" referenceValues="/1/@objectsToAttach.0"/>
<listChanges kind="REMOVE" index="3"/>
<listChanges kind="REMOVE" index="2"/>
<listChanges kind="REMOVE" index="1"/>
<listChanges kind="REMOVE" index="0"/>
</value>
</objectChanges>
<objectsToAttach xsi:type="B" name="B group"/>
</xmi:XMI>
applyAndReverse
<A>
<elements name="B group"/>
</A>
<listChanges index="0" referenceValues="/1/@objectsToAttach.0"/>
<listChanges index="1" referenceValues="/1/@objectsToAttach.1"/>
<listChanges index="2" referenceValues="/1/@objectsToAttach.2"/>
<listChanges index="3" referenceValues="/1/@objectsToAttach.3"/>
</value>
</objectChanges>
<objectsToAttach xsi:type="B" name="B0"/>
<objectsToAttach xsi:type="B" name="B1"/>
<objectsToAttach xsi:type="B" name="B2"/>
<objectsToAttach xsi:type="B" name="B3"/>
</xmi:XMI>
The change description after the first call to applyAndReverse seems to
miss some information. And as you can see, after the second call to
applyAndReverse, "B group" loses definitely its children :-( I observe
the same behaviour in our model.
Am I doing something wrong here or may I open a bugzilla with the testcase?
Thank you.
Cyril Jaquier
Re: ChangeDescription#applyAndReverse not "circular" [message #530826 is a reply to message #530743] Sat, 01 May 2010 07:50 Go to previous messageGo to next message
Cyril,
It sounds like a bug, but one never knows what problems "slight" changes
can cause. If you open a bugzilla, I'll have a look at the behavior.
Cyril Jaquier wrote:
> Hi all, Hi Ed,
> and I'm currently facing an issue that sounds to me as a bug in the
> EMF change model.
> in the initial state.
> upperBound="-1"
> </eClassifiers>
> upperBound="-1"
> </eClassifiers>
> </ecore:EPackage>
> <A>
> </elements>
> </A>
> </value>
> </objectChanges>
> </xmi:XMI>
> applyAndReverse
> <A>
> </A>
> </value>
> </objectChanges>
> </xmi:XMI>
> applyAndReverse
> <A>
> </A>
> </value>
> </objectChanges>
> </xmi:XMI>
> to miss some information. And as you can see, after the second call to
> testcase?
> Thank you.
> Regards,
> Cyril Jaquier
Re: ChangeDescription#applyAndReverse not "circular" [message #530950 is a reply to message #530826] Mon, 03 May 2010 03:01 Go to previous message
Hi Ed,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=311334
Thank you. I would really appreciate if you could have a look at it.
Eclipse project with test case is attached to the bugzilla.
Thank you.
Cyril
Ed Merks wrote:
> Cyril,
>> Hi all, Hi Ed,
>> EMF change model.
>> <?xml version="1.0" encoding="UTF-8"?>
>> upperBound="-1"
>> </eClassifiers>
>> upperBound="-1"
>> </eClassifiers>
>> </ecore:EPackage>
>> <A>
>> </elements>
>> </A>
>> </value>
>> </objectChanges>
>> </xmi:XMI>
>> applyAndReverse
>> <A>
>> </A>
>> </value>
>> </objectChanges>
>> </xmi:XMI>
>> applyAndReverse
>> <A>
>> </A>
>> </value>
>> </objectChanges>
>> </xmi:XMI>
>> testcase?
>> Thank you.
>> Regards,
>> Cyril Jaquier
Previous Topic:EMF + DataBinding + Master/Detail problem
Next Topic:Experience with emf and .NET?
Current Time: Sat Jul 19 17:35:49 EDT 2025
Powered by FUDForum. Page generated in 0.03523 seconds
