Re: Initial documentation of b3 aggregator and b3 command line interface [message #530741 is a reply to message #530247] |
Fri, 30 April 2010 12:31  |
Hi have reviewd and edited the aggregator manual wiki page. There are
some questions at the end - can you elaborate a bit on those? (then we
are done I think).
- henrik
7.1 Questions
How is blame-mail handled when running in the UI? Are the options
"production" etc. available then?
How do you know what the "log output url" is? How can it be set?
Why is there a section that says "there is no hudson support" - is
hudson support needed/required in any way??
Some configurations seems to be missing - or is the list open ended?
(Sparc, Motif, etc..) - I assume user can put anything there?
It seems that it is possible to load maven repositories. I suppose the
result of aggregation is a valid p2 repository (or a combination of
p2/maven)??
On 4/29/10 7:21 AM, Filip Hrbek wrote:
> here is an initial documentation of
> b3 aggregator: http://wiki.eclipse.org/Eclipse_b3/aggregator/manual
> and
> b3 command line interface: http://wiki.eclipse.org/Eclipse_b3/cli
> More work needs to be done but perhaps something is better than nothing ;-)
> Filip
Re: Initial documentation of b3 aggregator and b3 command line interface [message #606370 is a reply to message #530247] |
are done I think).
- henrik
7.1 Questions
p2/maven)??
> and
> Filip
FUDForum. Page generated in 0.05188 seconds
