Home » Modeling » EMF » EMF + DataBinding + Master/Detail problem
EMF + DataBinding + Master/Detail problem [message #530607] Fri, 30 April 2010 06:04 Go to next message
I must be doing something *very* wrong, but I cannot understand what.
Please point me in the right direction.
-- I have a Master page:
public class WorldMasterBlock extends MasterDetailsBlock {
private IObservableValue treeObs = null;
protected void createMasterPart(final IManagedForm managedForm,
Composite parent) {
tree = toolkit.createTree(composite_2, SWT.BORDER);
tViewer = new TreeViewer(tree);
treeObs = ViewerProperties.singleSelection().observe(tViewer);
protected void registerPages(DetailsPart part) {
part.registerPage(SceneImpl.class, new SceneDetailsPage2(treeObs));
-- and a Details page:
public class SceneDetailsPage2 implements IDetailsPage {
private IObservableValue observableScene = null;
public SceneDetailsPage2(IObservableValue observableScene) {
this.observableScene = observableScene;
public void createContents(Composite parent) {
FormToolkit toolkit = managedForm.getToolkit();
EMFDataBindingContext ctx = new EMFDataBindingContext();
IWidgetValueProperty text = WidgetProperties.text(SWT.Modify);
IWidgetListProperty list = WidgetProperties.items();
IWidgetValueProperty sel = WidgetProperties.selection();
ctx.bindValue(text.observeDelayed(500, txtTitle),
EMFProperties.value(WorldPackage.Literals.IBASE__TITLE).obse rveDetail(observableScene));
ctx.bindValue(text.observeDelayed(500, txtDesc),
EMFProperties.value(WorldPackage.Literals.IBASE__DESC).obser veDetail(observableScene));
ctx.bindValue(text.observeDelayed(500, txtContent),
EMFProperties.value(WorldPackage.Literals.IBASE__CONTENT).ob serveDetail(observableScene));
ctx.bindValue(text.observeDelayed(500, txtWords),
EMFProperties.value(WorldPackage.Literals.SCENE__WORD_COUNT) .observeDetail(observableScene));
ctx.bindList(list.observe(lstActors),
EMFProperties.list(FeaturePath.fromList(WorldPackage.Literal s.SCENE__ACTOR,
WorldPackage.Literals.ACTOR__NAME)).observeDetail(observable Scene));
ctx.bindValue(new
DateAndTimeObservableValue(sel.observeDelayed(500, dtDate),
sel.observeDelayed(500, dtTime)),
EMFProperties.value(FeaturePath.fromList(WorldPackage.Litera ls.IBASE__TIME,
WorldPackage.Literals.TIME_EVENT__DATE)).observeDetail(obser vableScene));
ctx.bindValue(sel.observeDelayed(500, spnDays),
WorldPackage.Literals.TIME_EVENT__SPANS_DAYS)).observeDetail (observableScene));
spnHours),EMFProperties.value(FeaturePath.fromList(WorldPack age.Literals.IBASE__TIME,
WorldPackage.Literals.TIME_EVENT__SPANS_HOURS)).observeDetai l(observableScene));
ctx.bindValue(sel.observeDelayed(500, spnMinutes),
WorldPackage.Literals.TIME_EVENT__SPANS_MINUTES)).observeDet ail(observableScene));
public void selectionChanged(IFormPart part, ISelection selection) {
IStructuredSelection structuredSelection =
(IStructuredSelection) selection;
if (structuredSelection.size() == 1) {
Scene s = (Scene) structuredSelection.getFirstElement();
try {
Object o = observableScene.getValue(); //<-- this is
SceneDetailsPage2.java:359
if (o instanceof Scene) {
Scene z = (Scene) o;
System.out.println("structuredSelection(" +
s.getTitle() + "); observebleScene(" + z.getTitle() + ")");
} else {
s.getTitle() + "); observebleScene(" + o.getClass() + ")");
} catch (Exception e) {
s.getTitle() + "); exception(" + e.getMessage() + ")");
I am using selectionChanged() because I need to setup a few sliders I
didn't figure to how to bind to values. Otherwise it shouldn't be
necessary because observableScene should already track the selection in
Master.
All this works Ok on the *first* selection.
When I switch to another instance of Scene (in Master) it doesn't work
anymore.
A few (??) trials show that, after the first time any access to
observableScene value (observableScene.getValue() or
observableScene.setValue()) bombs with the following error.
What am I doing so wrong?
Note that not using the external treeObs and setting manually
obsevableScene in selectionChanged fails in a similar way from the first
iteration!
Resource file:/C:/Tmp/La-Missione.world is clean
structuredSelection(Prologo); observebleScene(Prologo)
structuredSelection(il Matrimonio);
exception(org.eclipse.emf.ecore.util.EObjectResolvingEList cannot be
cast to org.eclipse.emf.ecore.EObject)
java.lang.ClassCastException:
org.eclipse.emf.ecore.util.EObjectResolvingEList cannot be cast to
at
org.eclipse.emf.databinding.internal.EMFListProperty.doGetLi st(EMFListProperty.java:64)
at
org.eclipse.core.databinding.property.list.SimpleListPropert y.getList(SimpleListProperty.java:63)
at
org.eclipse.core.internal.databinding.property.list.SimplePr opertyObservableList.getList(SimplePropertyObservableList.ja va:122)
at
org.eclipse.core.internal.databinding.property.list.SimplePr opertyObservableList.toArray(SimplePropertyObservableList.ja va:161)
at java.util.ArrayList.<init>(Unknown Source)
at
org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableList$3.run(DetailObservableList.java:99)
at
org.eclipse.core.databinding.observable.ObservableTracker.ru nAndIgnore(ObservableTracker.java:169)
at
org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableList$2.handleValueChange(DetailObservableL ist.java:97)
at
org.eclipse.core.databinding.observable.value.ValueChangeEve nt.dispatch(ValueChangeEvent.java:62)
at
org.eclipse.core.databinding.observable.ChangeManager.fireEv ent(ChangeManager.java:119)
at
org.eclipse.core.databinding.observable.value.DecoratingObse rvableValue.fireValueChange(DecoratingObservableValue.java:5 5)
at
org.eclipse.core.databinding.observable.value.DecoratingObse rvableValue.handleValueChange(DecoratingObservableValue.java :93)
at
org.eclipse.core.databinding.observable.value.DecoratingObse rvableValue$1.handleValueChange(DecoratingObservableValue.ja va:67)
at
at
at
org.eclipse.core.databinding.observable.value.AbstractObserv ableValue.fireValueChange(AbstractObservableValue.java:71)
at
org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableValue.access$1(DetailObservableValue.java: 1)
at
org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableValue$3.run(DetailObservableValue.java:92)
at
at
org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableValue$2.handleValueChange(DetailObservable Value.java:88)
at
at
at
at
at
at
at
at
at
org.eclipse.core.internal.databinding.property.value.SimpleP ropertyObservableValue.notifyIfChanged(SimplePropertyObserva bleValue.java:120)
at
org.eclipse.core.internal.databinding.property.value.SimpleP ropertyObservableValue.doGetValue(SimplePropertyObservableVa lue.java:97)
at
org.eclipse.core.databinding.observable.value.AbstractObserv ableValue.getValue(AbstractObservableValue.java:76)
at
org.eclipse.core.databinding.observable.value.DecoratingObse rvableValue.getValue(DecoratingObservableValue.java:98)
at
it.condarelli.writer.editors.SceneDetailsPage2.selectionChan ged(SceneDetailsPage2.java:359)
at org.eclipse.ui.forms.DetailsPart$1.run(DetailsPart.java:274)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.forms.DetailsPart.showPage(DetailsPart.java:2 61)
at org.eclipse.ui.forms.DetailsPart.update(DetailsPart.java:234 )
at org.eclipse.ui.forms.DetailsPart.selectionChanged(DetailsPar t.java:219)
at
org.eclipse.ui.forms.ManagedForm.fireSelectionChanged(Manage dForm.java:148)
at
it.condarelli.writer.editors.WorldMasterBlock$2.selectionCha nged(WorldMasterBlock.java:240)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
at
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:2132)
at
org.eclipse.jface.viewers.StructuredViewer.handleSelect(Stru cturedViewer.java:1160)
at
org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected( StructuredViewer.java:1190)
at
org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenS trategy.java:228)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:222)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:389)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3910)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3503)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at it.condarelli.writer.Writer.start(Writer.java:20)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Many thanks in advance
Mauro
Re: EMF + DataBinding + Master/Detail problem [message #530703 is a reply to message #530607] Fri, 30 April 2010 10:52 Go to previous messageGo to next message
On 30/04/2010 12.04, Mauro Condarelli wrote:
I'm answering to myself... up to a point.
I managed to pinpoint the error to this binding:
ListViewer listViewer = new ListViewer(composite_1, SWT.BORDER);
List lstActors = listViewer.getList();
ctx.bindList(
EMFProperties.list(
WorldPackage.Literals.SCENE__ACTOR,
).observeDetail(observableScene)
where, in the model I have:
public interface Scene extends IBase {
* @model lower="1" many="true"
EList<Actor> getActor();
Actors are contained elsewhere; here is just a list of references.
public interface Actor extends EObject {
* @model default="Nemo" required="true"
String getName();
I suspect I don't really understand the semantics of
EMFProperties.list() and, possibly, of FeaturePath.fromList()
I need to construct a list of Actors and fill the ListView with their Names.
Thanks in Advance
Mauro
Re: EMF + DataBinding + Master/Detail problem [message #530711 is a reply to message #530703] Fri, 30 April 2010 11:14 Go to previous messageGo to next message
Originally posted by: Thomas.Kowatsch.ruag.com
Hi Mauro.
Best thing you have a look at Tom Schindel's EMF Databinding Blog.
http://tomsondev.bestsolution.at/2009/06/15/galileo-emf-data binding-part-4
He is also discussing how to setup master detail bindings.
HTH
--Thomas
>> Hi,
> ctx.bindList(
> EMFProperties.list(
> String getName();
> Names.
> Thanks in Advance
> Mauro
Re: EMF + DataBinding + Master/Detail problem [message #530734 is a reply to message #530711] Fri, 30 April 2010 12:17 Go to previous messageGo to next message
On 30/04/2010 17.14, Thomas Kowatsch wrote:
> Hi Mauro.
> HTH
> --Thomas
Thanks for the hint, Thomas.
I am aware of that.
Actually it is my main source of information.
The Javadoc pages are somewhat terse.
I think I managed to understand what's wrong, but I have no idea about
hos to make it right.
In Tom's Example he has:
// 2. Use case - observe the nested list
// The list of all subprojects of the projects parent
public IObservableList uc2(Project p) {
IEMFListProperty prop = EMFProperties.list(
FeaturePath.formList(
ProjectPackage.Literals.PROJECT__PROJECT,
ProjectPackage.Literals.PROJECT__SUBPROJECTS
return prop.observe(p);
where ProjectPackage.Literals.PROJECT__PROJECT is a single value, while
ProjectPackage.Literals.PROJECT__SUBPROJECTS represents a list. i.e.: he
is dereferencing a project and using that to find a list of subprojects.
I have the reverse: I have a list of Actors and for *each* of those I
need to retrieve a single attribute (the Name).
I'm even unsure if that can be done (with Databinding, I mean) and I'm
completely in the fog about *how* to do it.
Any comment?
Side issue: I understand there should be a new edition of the book "EMF:
Eclipse Modeling Framework".
Two questions there:
1) when will it be available?
2) will it cover the above issues?
Thanks in Advance
Mauro
Re: EMF + DataBinding + Master/Detail problem [message #530805 is a reply to message #530734] Sat, 01 May 2010 03:36 Go to previous messageGo to next message
Am 30.04.10 18:17, schrieb Mauro Condarelli:
>> Hi Mauro.
>> HTH
>> --Thomas
> I am aware of that.
Right but I also think that in case of Databinding and the description
of the usecases it's probably impossible to get this into Javadoc,
that's why I wrote the Databinding Blog Series (BTW every part of it has
been already 4.000 hits == 20.000 hits in total :-).
Probably time to write a book about Eclipse-Databinding :-)
This is not supported if I get your request right. I'm not sure what
you'd expect to use the actors name for. Can you show us the code you
are using? If you want to observe the all actors names what you are
searching for is an IObservableMap.
> Any comment?
It's already available since about a year.
No.
Tom
Re: EMF + DataBinding + Master/Detail problem [message #530811 is a reply to message #530805] Sat, 01 May 2010 05:08 Go to previous messageGo to next message
>>> Hi Mauro.
>>> HTH
>>> --Thomas
>> I am aware of that.
If You do in a reasonable timeframe (before I discover the last secret
of Databinding) You have already sold at least my copy ;)
.... but I don't really understand: You can write whatever You want in
Javadoc, including, but not limited to: "The Lord of the Rings" :p (see:
http://java.sun.com/j2se/javadoc/writingdoccomments/ "Writing
Programming Guide Documentation"). I use extensively this feature at
work to document libraries I write (I actually use Doxygen because I
program mainly in C/C++). Hint. Hint. :) ;) :)
Here it comes!
Problematic binding is:
ctx.bindList(
EMFProperties.list(
String getName();
What I need is to:
- display in the ListViewer the names of the Actors in the Scene EList.
- be able to get a pointer to the Actor when I select it's Name (to edit
it).
- remove or add to the EList via drag&drop from the full list of Actors.
Right now I would be happy to achieve point 1. :(
>> Any comment?
I oops. I thought there would be a "third Edition" soon.
Does it describe a reasonably current state of EMF?
> No.
I think some specific would be *very* useful!
> Tom
Mauro
Re: EMF + DataBinding + Master/Detail problem [message #530817 is a reply to message #530811] Sat, 01 May 2010 06:19 Go to previous messageGo to next message
Am 01.05.10 11:08, schrieb Mauro Condarelli:
>>>> Hi Mauro.
>>>> HTH
>>>> --Thomas
>>> I am aware of that.
Yes but what you really need is example code to understand how all this
things work together.
> Here it comes!
> ctx.bindList(
> EMFProperties.list(
IListProperty lp =
EMFProperties.value(WorldPackage.Literals.SCENE__ACTOR);
IValueProperty p =
EMFProperties.value(WorldPackage.Literals.ACTOR__NAME);
ObservableListContentProvider cp = new ObservableListContentProvider();
TableViewer listViewer = new ListViewer(composite_1, SWT.BORDER);
listViewer.setContentProvider(cp);
listViewer.setLabelProvider(new
ObservableMapLabelProvider(p.observeDetail(cp.getKnownElemen ts()))
listViewer.setInput(lp.observeDetail(observableScene));
If you want a better LabelProvider I'd suggest you take a look at the
class is wrote for my blog example named GenericMapCellLabelProvider.
> String getName();
> What I need is to:
See above how this should look like
> it).
With a Table you can use EditingSupport
See above modifying the EList updates your viewers content.
Tom
Re: EMF + DataBinding + Master/Detail problem [message #530818 is a reply to message #530817] Sat, 01 May 2010 06:23 Go to previous messageGo to next message
Am 01.05.10 12:19, schrieb Tom Schindl:
>>>>> Hi Mauro.
>>>>> HTH
>>>>> --Thomas
>>>> I am aware of that.
>> Here it comes!
>> ctx.bindList(
>> EMFProperties.list(
> IListProperty lp =
> IValueProperty p =
In the end it is the stuff described in
http://tomsondev.bestsolution.at/2009/06/27/galileo-emf-data binding-part-5/
when I talk about binding a TableViewer.
Tom
Re: EMF + DataBinding + Master/Detail problem [message #530853 is a reply to message #530817] Sat, 01 May 2010 17:18 Go to previous messageGo to next message
>>>>> Hi Mauro.
>>>>> HTH
>>>>> --Thomas
>>>> I am aware of that.
Agreed.
What I sourly miss is a cookbook-style book on RCP development.
There are a lot of ways to do similar things and I'm lost.
I hope to come to a grip sooner or later.
>> Here it comes!
>> ctx.bindList(
>> EMFProperties.list(
> IListProperty lp =
> IValueProperty p =
I modified Your code as follows (for obvious errors):
IListProperty lp = EMFProperties.list(WorldPackage.Literals.SCENE__ACTOR);
IValueProperty p = EMFProperties.value(WorldPackage.Literals.ACTOR__NAME);
listViewer.setLabelProvider(new ObservableMapLabelProvider(p.observeDetail(cp.getKnownElemen ts())));
this somewhat works, but doesn't always update well when I change the selection in my Master.
My Master/Detail is as follows:
Composite parent) {
lstActors.setLayoutData(new GridData(SWT.FILL, SWT.FILL, false, false, 2, 1));
IStructuredSelection structuredSelection = (IStructuredSelection) selection;
try {
Object o = observableScene.getValue(); //<-- this is SceneDetailsPage2.java:405
System.out.println("structuredSelection(" + s.getTitle() + "); observebleScene(" + z.getTitle() + ")");
} else {
System.out.println("structuredSelection(" + s.getTitle() + "); observebleScene(" + o.getClass() + ")");
System.out.println("structuredSelection(" + s.getTitle() + "); exception(" + e.getMessage() + ")");
I am using selectionChanged() because I need to setup a few sliders I didn't figure to how to bind to values. Otherwise it shouldn't be necessary because observableScene should already track the selection in Master.
when it starts misbehaving I consistently get the following error:
structuredSelection(Il Risveglio); exception(null)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:1542)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1029)
at it.condarelli.writer.model.world.impl.IBaseImpl.eGet(IBaseIm pl.java:597)
at it.condarelli.writer.model.world.impl.ChapterImpl.eGet(Chapt erImpl.java:262)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1013)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1005)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1000)
at org.eclipse.emf.databinding.internal.EMFListProperty.doGetLi st(EMFListProperty.java:65)
at org.eclipse.core.databinding.property.list.SimpleListPropert y.getList(SimpleListProperty.java:63)
at org.eclipse.core.internal.databinding.property.list.SimplePr opertyObservableList.getList(SimplePropertyObservableList.ja va:122)
at org.eclipse.core.internal.databinding.property.list.SimplePr opertyObservableList.toArray(SimplePropertyObservableList.ja va:161)
at org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableList$3.run(DetailObservableList.java:99)
at org.eclipse.core.databinding.observable.ObservableTracker.ru nAndIgnore(ObservableTracker.java:169)
at org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableList$2.handleValueChange(DetailObservableL ist.java:97)
at org.eclipse.core.databinding.observable.value.ValueChangeEve nt.dispatch(ValueChangeEvent.java:62)
at org.eclipse.core.databinding.observable.ChangeManager.fireEv ent(ChangeManager.java:119)
at org.eclipse.core.databinding.observable.value.DecoratingObse rvableValue.fireValueChange(DecoratingObservableValue.java:5 5)
at org.eclipse.core.databinding.observable.value.DecoratingObse rvableValue.handleValueChange(DecoratingObservableValue.java :93)
at org.eclipse.core.databinding.observable.value.DecoratingObse rvableValue$1.handleValueChange(DecoratingObservableValue.ja va:67)
at org.eclipse.core.databinding.observable.value.AbstractObserv ableValue.fireValueChange(AbstractObservableValue.java:71)
at org.eclipse.core.internal.databinding.property.value.SimpleP ropertyObservableValue.notifyIfChanged(SimplePropertyObserva bleValue.java:120)
at org.eclipse.core.internal.databinding.property.value.SimpleP ropertyObservableValue.doGetValue(SimplePropertyObservableVa lue.java:97)
at org.eclipse.core.databinding.observable.value.AbstractObserv ableValue.getValue(AbstractObservableValue.java:76)
at org.eclipse.core.databinding.observable.value.DecoratingObse rvableValue.getValue(DecoratingObservableValue.java:98)
at it.condarelli.writer.editors.SceneDetailsPage2.selectionChan ged(SceneDetailsPage2.java:405)
at org.eclipse.ui.forms.ManagedForm.fireSelectionChanged(Manage dForm.java:148)
at it.condarelli.writer.editors.WorldMasterBlock$2.selectionCha nged(WorldMasterBlock.java:240)
Can You divine what's going wrong?
I will, even if a plain list is ok.
>> String getName();
>> What I need is to:
I'm still missing something :(
>> it).
> Tom
Mauro
Re: EMF + DataBinding + Master/Detail problem [message #530878 is a reply to message #530853] Sun, 02 May 2010 06:03 Go to previous message
>>>>>> Hi Mauro.
>>>>>> HTH
>>>>>> --Thomas
>>>>> I am aware of that.
> Agreed.
>>> Here it comes!
>>> ctx.bindList(
>>> EMFProperties.list(
>> IListProperty lp =
>> IValueProperty p =
Answering to myself (again):
the following works
if and only if observableScene always contains a Scene.
This means I cannot directly observe the variable provided by the Master,
but I have to use a local one updated in selectionChanged().
My other bindings work regardless.
I tried to modify the above copying from http://tomsondev.bestsolution.at/2009/06/27/galileo-emf-data binding-part-5/,
but my code below doesn't work (no error, but no entries in the list):
IObservableMap am = EMFProperties.value(/*editingDomain,*/
).observeDetail(cp.getKnownElements());
listViewer.setLabelProvider(new ObservableMapLabelProvider(am));
It is clear to me I really do not understand Databinding.
In an attempt to fill my knowledge gap I just bought "Eclipse Rich Client Platform: Designing, Coding,
and Packaging Java Applications, Second Edition" and I'm now studying it.
Can someone suggest other fonts of overall description?
TiA
Mauro
> @Override
> Composite parent) {
> @Override
> try {
> } else {
>>> String getName();
>>> What I need is to:
>>> it).
>> Tom
> Thanks
> Mauro
Previous Topic:[CDO Teneo] Do not set your version attribute to negative default
Next Topic:ChangeDescription#applyAndReverse not "circular"
Current Time: Sun Jul 20 17:16:14 EDT 2025
Powered by FUDForum. Page generated in 0.05408 seconds
