Home » Language IDEs » ServerTools (WTP) » method type inference -- jsdoc @type annotation is not used?
method type inference -- jsdoc @type annotation is not used? [message #530630] Fri, 30 April 2010 07:28 Go to next message
The javascript Content Assist feature mostly seems very impressive, and I'm really hoping to be able to make it standard for use within our company, and an option for use by clients of our APIs. However, there seems to be one major failing:
The inferred type returned by a method does not seem to make use the of @type jsdoc annotation, which tells it precisely what it is!
So, far, I've only been able to get the return value of a method to have type information if it looks like this:
package.Foo.prototype.getX = function()
	return new package.Bar();
or even this:
	return this;
but it never works when it looks more like this:
 * @type package.Bar
	return this.m_oX;
is there some other notation used for indicating a methods return type?
Or, if this is by intention, can anybody point to the right class or package within org.eclipse.wst.jsdt where I should go looking to add this feature?
Thanks in advance, Dominic.
Re: method type inference -- jsdoc @type annotation is not used? [message #531006 is a reply to message #530630] Mon, 03 May 2010 06:29 Go to previous messageGo to next message
Hopefully we'll get to spend some time in the next release deciding
which flavor of "JSDoc" we're actually trying to comply with. Between
http://jsdoc.sourceforge.net/#tagref and
http://code.google.com/p/jsdoc-toolkit/wiki/TagReturns, and we seem to
be leaning toward the latter. The parser is something I want to spend
some time on in the next release, and that includes cleaning up the
JSDoc handling.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: method type inference -- jsdoc @type annotation is not used? [message #531232 is a reply to message #531006] Tue, 04 May 2010 05:21 Go to previous messageGo to next message
Hi Nitin,
Thanks for the response on this, it's much appreciated. Okay, so instead I tried the jsdoc-toolkit usage, as follows:
 * @returns {package.Bar} the X you are looking for.
	return this.m_oX;
but this too failed to make code completion work for the returned type -- I'm using Eclipse Galileo (20100218-1602) BTW. You seem to be indicating that this functionality is in the current codebase. Is it worth me trying the latest Eclipse 3.6M7 milestone to get this functionality?
Also, we've been using jsdoc for at least 5 years at the company I'm currently working at, and have in the region of 100Klocs of Javascript. Until your message I was actually even unaware of the existence of the jsdoc-toolkit implementation, and I'm not sure we'd be able to move easily since we already have lot's of modifications to the original version (very hacky perl code to boot). So ideally, from our perspective, it would be far better if both usages were supported. There doesn't seem to be any particular complications to doing this, except considering which to prefer if (strangely) both ways are used to return the actual type.
Anyway, thanks for your help, Dominic.
[Updated on: Tue, 04 May 2010 05:24] by Moderator
Re: method type inference -- jsdoc @type annotation is not used? [message #532550 is a reply to message #531232] Mon, 10 May 2010 08:52 Go to previous messageGo to next message
Ok, I just took the plunge and installed Eclipse Helios M7 to see if this functionality now works, and it does ... but there's also a serious regression too!
Both '@returns {type} desc' and '@type type' now work, but class inheritance using @base and @extends has stopped working since Eclipse Galileo!
This is critical for people using libraries where inheritance is performed using a library method. In my tests, the only jsdoc tag support we need to allow decent javascript code completion are '@returns/@type' & '@extends/@base'.
Can this regression be fixed before the final release of Hellios? Should I report it somewhere?
Re: method type inference -- jsdoc @type annotation is not used? [message #532593 is a reply to message #531006] Mon, 10 May 2010 10:28 Go to previous message
Hi Nitin Dahyabhai,
> JSDoc handling.
http://www.eclipse.org/forums/index.php?t=msg&th=167646& amp;start=0&#msg_532587
Previous Topic:Icon in Editor
Next Topic:jsDoc vs jsdoc-toolkit
Current Time: Sun Jul 20 06:04:40 EDT 2025
Powered by FUDForum. Page generated in 0.25084 seconds
