Home » Eclipse Projects » Remote Application Platform (RAP) » Problem using 1.3.M6 with BIRT
Problem using 1.3.M6 with BIRT [message #530298] Thu, 29 April 2010 05:00 Go to next message
I would like to use RAP 1.3.M6 together with BIRT and followed the
documentation described here: http://wiki.eclipse.org/RAP/BIRT_Integration
Thats why I do not use the com.ibm.icu.base_4.2.1.v20100212.jar bundle
contained in the rap-tooling.
But when running with BIRTs com.ibm.icu_4.0.1.v20090822.jar I get the
following error. I also tried the com.ibm.icu_4.2.1.v20100212.jar from
the eclipse SDK 3.6.M6.
Where is my mistake?
java.lang.NoClassDefFoundError: com/ibm/icu/text/Collator
at
org.eclipse.ui.internal.registry.EditorRegistry$1.<init>(EditorRegistry.java:143)
at
org.eclipse.ui.internal.registry.EditorRegistry.<clinit>(EditorRegistry.java:142)
at
org.eclipse.ui.internal.WorkbenchPlugin.getEditorRegistry(Wo rkbenchPlugin.java:609)
at
org.eclipse.ui.internal.EditorManager.getEditorRegistry(Edit orManager.java:561)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:632)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2716)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2630)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2622)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2574)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2569)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2553)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2544)
at client.ui.common.DefaultEditAction.run(DefaultEditAction.jav a:69)
at
client.ui.common.DefaultEditAction.doubleClick(DefaultEditAc tion.java:99)
at
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:823)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:821)
at
org.eclipse.jface.viewers.StructuredViewer.handleDoubleSelec t(StructuredViewer.java:1085)
at
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1197)
at
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:239)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:236)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:301)
at
org.eclipse.swt.internal.widgets.UntypedEventAdapter.dispatc hEvent(UntypedEventAdapter.java:651)
at
org.eclipse.swt.internal.widgets.UntypedEventAdapter.widgetD efaultSelected(UntypedEventAdapter.java:82)
at
org.eclipse.swt.events.SelectionEvent.dispatchToObserver(Sel ectionEvent.java:197)
at org.eclipse.rwt.internal.events.Event.processEvent(Event.jav a:44)
at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.ja va:160)
at org.eclipse.swt.events.TypedEvent.executeNext(TypedEvent.jav a:200)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.readAndDispa tch(RWTLifeCycle.java:266)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1006)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2396)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2355)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 06)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:424)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.jface.internal.databinding.realmadapter.RealmAda pter.run(RealmAdapter.java:44)
at
org.eclipse.rap.ui.internal.RealmAdapterHook.runWithDefault( RealmAdapterHook.java:48)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:427)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at
client.RapApplication.start(RapApplication.java:58)
at
org.eclipse.rap.ui.internal.application.EntrypointApplicatio nWrapper.createUI(EntrypointApplicationWrapper.java:27)
at
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:253)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:117)
at java.lang.Thread.run(Thread.java:619)
at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.jav a:80)
Caused by: java.lang.ClassNotFoundException: com.ibm.icu.text.Collator
at
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:460)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
... 50 more
I there a newer
Lars
Re: Problem using 1.3.M6 with BIRT [message #530305 is a reply to message #530298] Thu, 29 April 2010 05:45 Go to previous messageGo to next message
I found that the birt reportengine runtime contains a bundle fragment
org.eclipse.birt.api version 1.0.0. This fragment is exporting many
packages. E.g. com.ibm.icu.text version 4.0.1.
Without this fragment, rap 1.3.M6 is able to run with the full
com.ibm.icu_4.2.1.v20100212.jar. But I don't know if it is needed for BIRT.
Lars
Re: Problem using 1.3.M6 with BIRT [message #530476 is a reply to message #530298] Thu, 29 April 2010 13:36 Go to previous messageGo to next message
did you take a look at the FAQ?
http://wiki.eclipse.org/RAP/FAQ#How_to_integrate_BIRT.3F
HTH
Rüdiger
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 50 more
> I there a newer
> Regards,
> Lars
Rüdiger Herrmann
http://eclipsesource.com
Re: Problem using 1.3.M6 with BIRT [message #530571 is a reply to message #530476] Fri, 30 April 2010 04:05 Go to previous messageGo to next message
Hello Rüdiger,
Your link forwards to the HOWTO which I used.
I got it working now: RAP 1.3.M6 with BIRT 2.5.2. But I have to take
care that the bundle fragment org.eclipse.birt.api version 1.0.0 is not
used.
Don't know if this is a bug of BIRT.
Lars
Re: Problem using 1.3.M6 with BIRT [message #530605 is a reply to message #530571] Fri, 30 April 2010 05:39 Go to previous messageGo to next message
Hi Lars,
you could ask on the BIRT newsgroup (eclipse.birt) what the use of this
fragment is and maybe file a bug against BIRT. If you do so, it would be
nice if you could let us know if there is something to be added to our
HOWTO.
Thanks, Ralf
Lars Fischer wrote:
> Hello Rüdiger,
> used.
> Regards,
> Lars
Re: Problem using 1.3.M6 with BIRT [message #533866 is a reply to message #530605] Mon, 17 May 2010 06:10 Go to previous messageGo to next message
Hi Ralf,
> HOWTO.
I got no response on the BIRT group.
But I could use BIRT together with RAP as described in the HOWTO. The
only thing to take care of is to _not_ include the org.eclipse.birt.api
fragment.
This is working fine for me.
Maybe this could be added as a hint to the WIKI entry?
Lars
Re: Problem using 1.3.M6 with BIRT [message #533884 is a reply to message #533866] Mon, 17 May 2010 07:34 Go to previous message
Sure, just go ahead and add it as a hint to the wiki page.
Benny
Lars Fischer wrote:
> Hi Ralf,
>> HOWTO.
> fragment.
> Regards,
> Lars
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Previous Topic:TableTree bug
Next Topic:UploadWidget is not working with latest CVS
Current Time: Sun Jul 20 04:24:42 EDT 2025
Powered by FUDForum. Page generated in 0.31861 seconds
