Home » Eclipse Projects » Remote Application Platform (RAP) » TableTree bug
TableTree bug [message #530274] Thu, 29 April 2010 03:49 Go to next message
I use a table-tree implemented with a TreeViewer and a ITableLabelProvider.
But I have a problem, when I expand nodes, labels of the first column
overlap with other columns.
Do you experience the same problem?
Patrick
Re: TableTree bug [message #530276 is a reply to message #530274] Thu, 29 April 2010 04:03 Go to previous messageGo to next message
Hi Patrick,
which version of RAP are you using? A code snippet will be useful to
check and reproduce it.
Best,
Ivan
On 04/29/2010 10:49 AM, Patrick wrote:
> Hello,
Re: TableTree bug [message #530282 is a reply to message #530276] Thu, 29 April 2010 04:13 Go to previous messageGo to next message
Hi Ivan,
I use a recent (last week) version from CVS. I didn't update today
because I have to do a demo this morning.
Here is a snippet, try to expand the nodes:
public class View extends ViewPart implements ITableLabelProvider,
ITreeContentProvider
public static final String ID = View.class.getName ();
private static final Random random = new Random ();
public View () {
public void createPartControl (Composite parent) {
TreeViewer tree = new TreeViewer (parent, SWT.NONE);
tree.setLabelProvider (this);
tree.setContentProvider (this);
tree.getTree ().setHeaderVisible (true);
TreeColumn column = new TreeColumn (tree.getTree (), SWT.NONE);
column.setText ("A");
column.setWidth (40);
column.setText ("B");
tree.setInput ("");
public void setFocus () {
public Image getColumnImage (Object element, int columnIndex) {
return null;
public String getColumnText (Object element, int columnIndex) {
return String.valueOf (random.nextInt ());
public boolean isLabelProperty (Object element, String property) {
return false;
public Object[] getChildren (Object parentElement) {
return getElements (parentElement);
public Object getParent (Object element) {
return null;
public boolean hasChildren (Object element) {
return true;
public Object[] getElements (Object inputElement) {
return new Object[] {"", ""};
public void inputChanged (Viewer viewer, Object oldInput, Object
newInput) {
public void addListener (ILabelProviderListener listener) {
public void removeListener (ILabelProviderListener listener) {
public void dispose () {
Le 29/04/2010 10:03, Ivan Furnadjiev a écrit :
> Hi Patrick,
> Best,
> Ivan
>> Hello,
>> Thanks,
Re: TableTree bug [message #530283 is a reply to message #530282] Thu, 29 April 2010 04:26 Go to previous messageGo to next message
Hi Patrick,
I think that you run into this bug:
284763: [Tree] Cell text doesn't clip if column is too narrow
https://bugs.eclipse.org/bugs/show_bug.cgi?id=284763
Best,
Ivan
On 04/29/2010 11:13 AM, Patrick wrote:
> Hi Ivan,
> public View () {
> tree.setInput ("");
> return null;
> return false;
> return null;
> return true;
> newInput) {
>> Hi Patrick,
>> Best,
>> Ivan
>>> Hello,
>>> Thanks,
Re: TableTree bug [message #530289 is a reply to message #530283] Thu, 29 April 2010 04:44 Go to previous messageGo to next message
OK thanks. Do you know if there is a workaround, or better, a plan for a
patch?
Patrick
Re: TableTree bug [message #530343 is a reply to message #530274] Thu, 29 April 2010 08:46 Go to previous messageGo to next message
Patrick wrote on Thu, 29 April 2010 09:49
Patrick
Hi Patrick,
Can you be a tad clearer. Do you mean something in the lines of this situation.
Your columns are closly fitting yet the tree go's on.
Somtin like this picture.
Dont mind the border lines and the full selection I used a patch from https://bugs.eclipse.org/bugs/show_bug.cgi?id=232406.
[Updated on: Thu, 29 April 2010 08:50] by Moderator
Re: TableTree bug [message #530344 is a reply to message #530289] Thu, 29 April 2010 08:50 Go to previous messageGo to next message
Roland,
I'm sorry to say, but there is no a workaround. With the current client
side implementation (qooxdoo Tree widget) it is very hard to fix it. We
are planning a new client-side Tree implementation ( see bug 309519 ),
but this will not be part of 1.3 release.
Best,
Ivan
> a patch?
> Regards,
> Patrick
Re: TableTree bug [message #530351 is a reply to message #530343] Thu, 29 April 2010 09:22 Go to previous messageGo to next message
> situation.
No, it looks like this:
https://bugs.eclipse.org/bugs/attachment.cgi?id=142667
Re: TableTree bug [message #530352 is a reply to message #530351] Thu, 29 April 2010 09:34 Go to previous messageGo to next message
Patrick wrote on Thu, 29 April 2010 15:22
> situation.
And if you try this:
TreeColumnLayout  mainCompositeTreeColumnLayout = new TreeColumnLayout();
parent .setLayout(mainCompositeTreeColumnLayout);
mainCompositeTreeColumnLayout.setColumnData(column, new ColumnWeightData(40, true));
tree.setInput ("");
This will make the colums overlap and not preasure the words together.
Re: TableTree bug [message #530361 is a reply to message #530344] Thu, 29 April 2010 09:33 Go to previous messageGo to next message
OK. The only workaround I think of would be to fix the 1st column's
width at a sufficient size. However it's not feasible if the tree is
very large.
Patrick
Re: TableTree bug [message #530362 is a reply to message #530352] Thu, 29 April 2010 09:51 Go to previous messageGo to next message
> tree.setInput ("");
Sorry, but the problem is still there if you expand the tree...
Thanks for the help anyway.
Re: TableTree bug [message #530364 is a reply to message #530362] Thu, 29 April 2010 09:59 Go to previous messageGo to next message
Patrick wrote on Thu, 29 April 2010 15:51
> tree.setInput ("");
Weaerd becouse I am using a JTree constantly in a table like way. And never saw taht problem. Witch is why I toucht that should work.
Re: TableTree bug [message #530522 is a reply to message #530344] Thu, 29 April 2010 18:53 Go to previous message
That is an annoying bug. If you go to TreeItem.js and replace the updateColumnsWidth function with the following:
updateColumnsWidth : function() {
      var columnWidth = new Array();
      var fullWidth = this.getTree().getParent().getColumnsWidth();
      this.setWidth( fullWidth );
      for( var c = 0; c < this.getTree().getParent()._columns.length; c++ ) {
        columnWidth[ c ] = this.getTree().getParent()._columns[ c ].getWidth();
      if( columnWidth.length > 0 ) {
    	var iconObj = this.getIconObject();
    	var iconWidth = this._images[ 0 ] == null ? 0 : this.getIconObject().getWidth();
    	var checkBoxWidth = this._checkBox == null ? 0 : 16; // 13 width + 3 checkbox margin
    	var spacing = iconWidth > 0 ? iconObj.getMarginRight() : 0;
    	var labelObj = this.getLabelObject();
        labelObj.setWidth( columnWidth[ 0 ]
          - ( this.getLevel() * 19 )   // TODO: [bm] replace with computed indent width
          - checkBoxWidth
          - iconWidth
          - spacing );
        if (iconWidth == 0 && checkBoxWidth == 0) {
	        var indentObj = this.getIndentObject();
	        var indentObjWidth = indentObj.getWidth();
			var firstCell = indentObj.getWidth()+checkBoxWidth+iconWidth+spacing;
			if (firstCell > columnWidth[0]) {
			  indentObj.setClipWidth(columnWidth[0]);
			  indentObj.setWidth(columnWidth[0]);
			  iconObj.setVisibility(false);
			else {
			  iconObj.setVisibility(true);
			  this._updateIndent();
        var coLabel;
        for( var i = 1; i < columnWidth.length; i++ ) {
          coLabel = this._colLabels[ i - 1 ];
          iconWidth = this._images[ i ] == null ? 0 : 16;
          spacing = iconWidth > 0 ? coLabel.getSpacing() : 0;
          if( coLabel != null && coLabel.getLabelObject() != null ) {
            coLabel.getLabelObject().setWidth( columnWidth[ i ]
              - iconWidth
              - spacing );
AND add the following function:
    flushTree : function() {
    	this.base(arguments);
        this.updateColumnsWidth();
Then the first column in the previously posted test snippet will not encroach on the other columns when expanded.
However, this is a solution that currently only works for tree tables without icons or checkboxes. That is another whole can of worms.
A little late for the demo, but Enjoy!
Previous Topic:Open a PDF book
Next Topic:Problem using 1.3.M6 with BIRT
Current Time: Sun Jul 20 15:15:30 EDT 2025
Powered by FUDForum. Page generated in 0.32636 seconds
