Home » Archived » M2M (model-to-model transformation) » how to run the UML2OWL atl transformation using the ANT build tool
how to run the UML2OWL atl transformation using the ANT build tool [message #529987] Tue, 27 April 2010 19:04 Go to next message
Hello
I have problem running the example of ATL transformation called UML2OWL
and that is because it has an ant Build file which I should run, but that requires am3 plugin which i do not have downloaded in my Eclipse, please tell me how to get compatible plugin with my Galileo modeling eclipse and how to run ant file please, it is urgent and I have no time
and can u tell me what are the prerequsts for Ant, like tomcat or some thing like that
wafaa
Re: how to run the UML2OWL atl transformation using the ANT build tool [message #530019 is a reply to message #529987] Wed, 28 April 2010 04:02 Go to previous messageGo to next message
You can use this eclipse. It's not Galileo tho
Re: how to run the UML2OWL atl transformation using the ANT build tool [message #530133 is a reply to message #530019] Wed, 28 April 2010 11:31 Go to previous message
Dear Sylvain EVEILLARD
I do not know how to say thanks, million of thanks does not fit
Really thank you, it worked by ur eclipse and every thing is fine
I will now start my work and hope u be with me on line for more questions Very Happy
thank u again and again
i have another theoritical question:
How did they import the uml.ecore metamodel in thier work and If i want to use it , should i copy it from the plugin file to my project or what
wafaaa Razz
Previous Topic:[ATL] Atl doesn't preserve order of a metamodel ordered attribute
Next Topic:No Resource found
Current Time: Sat Jul 19 06:29:54 EDT 2025
Powered by FUDForum. Page generated in 0.03334 seconds
