Incorrect validation [message #530077] |
Wed, 28 April 2010 08:07  |
Hi all,
I have a schema file(A1.xsd, ns="http://www.example.org/A") that imports another schema (B.xsd, ns="http://www.example.org/B"). This second schema imports another schema file that has the same target namespace as A1 - A.xsd, ns="http://www.example.org/A".
After loading an XSDSchema instance for A1.xsd, the validation returns an error saying that "Type reference 'http://www.example.org/A#A_ST_01' is unresolved".
Do I have to do something with the imports before invoking the schema validation?
10x
Tsvetan
Source code:
A1.xsd
<schema xmlns="http://www.w3.org/2001/XMLSchema" targetNamespace="http://www.example.org/A" xmlns:tns="http://www.example.org/A" elementFormDefault="qualified" xmlns:b="http://www.example.org/B">
<import namespace="http://www.example.org/B" schemaLocation="B.xsd"></import>
<complexType name="C_CT_02">
<sequence>
<element name="e1" type="tns:A_ST_01"></element>
<element name="e2" type="tns:A_ST_01NOTEXISTING" nillable="false"></element>
</sequence>
</complexType>
</schema>
B.xsd
<schema xmlns="http://www.w3.org/2001/XMLSchema" targetNamespace="http://www.example.org/B" xmlns:tns="http://www.example.org/B" elementFormDefault="qualified" xmlns:a="http://www.example.org/A">
<import schemaLocation="A.xsd" namespace="http://www.example.org/A"></import>
<complexType name="B_CT_01"></complexType>
<simpleType name="B_ST_01">
<restriction base="string"/>
</simpleType>
<element name="B_E_01" type="string"/>
<element name="B_E_02" type="tns:B_CT_01"/>
<element name="B_E_03" type="a:A_ST_01"/>
<element name="B_E_04" type="a:A_CT_01"/>
</schema>
A.xsd
<schema xmlns="http://www.w3.org/2001/XMLSchema" targetNamespace="http://www.example.org/A" xmlns:tns="http://www.example.org/A" elementFormDefault="qualified">
<complexType name="A_CT_01"></complexType>
<simpleType name="A_ST_01">
</simpleType>
<element name="A_E_01" type="string"></element>
<element name="A_E_02" type="tns:A_CT_01"></element>
</schema>
Java
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_LOCATION, Boolean.TRUE);
URL entry = Activator.getDefault().getBundle().getResource("resources/original/A1.xsd");
URI uri = URI.createURI(entry.toString());
XSDResourceImpl xsdResource = (XSDResourceImpl) resourceSet.getResource(uri, true);
XSDSchema schema = xsdResource.getSchema();
schema.validate();
EList<XSDDiagnostic> allDiagnostics = schema.getAllDiagnostics();
for (XSDDiagnostic diagnostic : allDiagnostics) {
System.out.println(diagnostic.getLine() + ":" + diagnostic.getMessage());
Re: Incorrect validation [message #530090 is a reply to message #530077] |
Wed, 28 April 2010 08:55   |
Tsvetan,
A1.xsd will not generally see the indirect imports of any schemas it
directly imports so I don't expect A1.xsd to see what's in A.xsd. As
such, the error message is expected unless you add an include.
Tsvetan Stoyanov wrote:
> Hi all,
> validation?
> 10x
> Tsvetan
> Source code:
> A1.xsd
> <sequence> <element name="e1"
> </sequence>
> </complexType>
> </schema>
> B.xsd
> </simpleType>
> </schema>
> A.xsd
> </simpleType>
> </schema>
> Java
> resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
> Boolean.TRUE);
> URL entry =
> Activator.getDefault().getBundle().getResource("resources/original/A1.xsd ");
> schema.validate();
Re: Incorrect validation [message #530112 is a reply to message #530107] |
Wed, 28 April 2010 09:52  |
Tsvetan,
It's not supposed to see indirect imports.
> Hi Ed,
> That's strange. If I iterate over the schemes tree starting from A1,
> invoke importSchema() on each XSDImport and then update() the schema,
> the error message is not shown anymore and the type definition is
> resolved.
> Here is the code I'm using in order to make A1 see the indirect imports:
> private static void updateSchema(XSDSchema schema) {
> if (schema == null)
> return;
> for (XSDSchemaContent ref : schema.getContents() ) {
> if (ref instanceof XSDImport) {
> ((XSDImportImpl) ref).importSchema();
> updateSchema(((XSDImport) ref).getResolvedSchema());
> schema.update(true);
> Best Regards,
> Tsvetan
Re: Incorrect validation [message #604632 is a reply to message #530090] |
Wed, 28 April 2010 09:44  |
Hi Ed,
That's strange.
If I iterate over the schemes tree starting from A1, invoke importSchema() on each XSDImport and then update() the schema,
the error message is not shown anymore and the type definition is resolved.
if (schema == null)
return;
Best Regards,
Tsvetan
Re: Incorrect validation [message #604637 is a reply to message #604632] |
Tsvetan,
> Hi Ed,
> resolved.
> if (schema == null)
> return;
> Best Regards,
> Tsvetan
FUDForum. Page generated in 0.03930 seconds
