Home » Eclipse Projects » Rich Client Platform (RCP) » Contribution Item on status line still visible if status line is set invisible
Contribution Item on status line still visible if status line is set invisible [message #528376] Tue, 20 April 2010 05:45 Go to next message
Originally posted by: gemaspecial.yahoo.com.hk
I have created a contribution item (text with one image) onto the Status line with the ui.menu extension
When I programmatically make the status line invisible by:
WorkbenchWindow.setStatusLineVisible(false);
The fast view, memory monitor is gone but my own contribution is left behind.
Do I miss something? Thanks
Re: Contribution Item on status line still visible if status line is set invisible [message #528517 is a reply to message #528376] Tue, 20 April 2010 14:58 Go to previous messageGo to next message
That refers specifically to the StatusManagerContribution. It won't
effect other contributions (added by org.eclipse.ui.menus) since they
all have their own visibleWhen clause.
It's possible through the use of the visibleWhen and variables (or
property testers) to make your other contribution disappear as well.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Contribution Item on status line still visible if status line is set invisible [message #528579 is a reply to message #528517] Wed, 21 April 2010 03:17 Go to previous message
> PW
Right, I have added visibleWhen to both the toolbar and the toolbar contribution item (there is only 1 item in this toolbar) such that
visible = WorkbenchWindow.getStatusLineVisible();
No luck, the toolbar and the item is still there....
Previous Topic:Integrate external tool in Eclipse RCP
Next Topic:IFile Open Listener
Current Time: Sun Jul 20 12:02:55 EDT 2025
Powered by FUDForum. Page generated in 0.07065 seconds
