Home » Modeling » EMF » Fast & loud proxy resolution failure
Fast & loud proxy resolution failure [message #528100] Mon, 19 April 2010 07:11 Go to next message
Is there a way of having proxy resolution fail loud and fast, instead of silently
and slowly?
Calling any of the ECoreUtil.resolve* methods seems to
(a) attempt to create and load a resource for the URI passed, if it's not already
present (instead I would like it to fail immediately if the resource isn't present)
and
(b) snuff the exception when resolution fails, and return the proxy (instead I'd like
to know about the resolution failure.)
/Caspar
Re: Fast & loud proxy resolution failure [message #528154 is a reply to message #528100] Mon, 19 April 2010 10:06 Go to previous messageGo to next message
Caspar,
Comments below.
> of silently and slowly?
> not already present (instead I would like it to fail immediately if
The resource will always be created and then will attempt to load. You
can scan the resource set and look at each resource's getErrors to see
which ones represent bogus attempts to load a resource that fails for
one reason or another.
> and
> (instead I'd like to know about the resolution failure.)
It already does that.
There's the unresolved proxy cross referencer you can use to find all
broken proxies...
> Thanks
> /Caspar
Re: Fast & loud proxy resolution failure [message #528305 is a reply to message #528154] Tue, 20 April 2010 02:15 Go to previous messageGo to next message
Ed,
Thanks for your response, see my additional comments below.
>> fast, instead of silently and slowly?
>> passed, if it's not already present (instead I would like
> to load. You can scan the resource set and look at each
> resource's getErrors to see which ones represent bogus
> attempts to load a resource that fails for one reason or
> another.
Yes, but the load attempt is exactly what I'd like to avoid,
since it could be slow (especially if the URI's scheme is
http) and I know it will fail anyway. I'm dealing with
interdependent packages, and if the ResourceSet can't find
the nsURI in the package registry (via
delegatedGetResource), I want it to just give up instead of
attempt to load over the network.
>> and
You mean snuff the exception and return the proxy? Yes, but
that's the behavior I don't want. I would prefer to
receive the exception immediately...
> to find all broken proxies...
True, but it seems that would requires two scans of the data
tree: one to attempt resolution of all proxies, and another
to find the ones that couldn't be resolved. I was wondering
if there is a more efficient way.
/Caspar
Re: Fast & loud proxy resolution failure [message #528385 is a reply to message #528305] Tue, 20 April 2010 06:48 Go to previous message
Caspar,
Comments below.
> Ed,
>> another.
You could (would need to) specialize your ResourceSetImpl for that.
Note that loading only fails once per resource...
>>> and
This seems to contradict your earlier statement. eResolveProxy is
called on the EObject that holds the proxy, so you could throw
exceptions whenever that is going to return a proxy.
Are you really dealing with a situation where you'd notice it was 10
times slower? Could you notice there are failed resources and only then
look for proxies.
> Thanks
> /Caspar
Previous Topic:Distinguishing calls to createObject()
Next Topic:EMFObservables Provisional Status
Current Time: Sat Jul 19 13:43:12 EDT 2025
Powered by FUDForum. Page generated in 0.04076 seconds
