Associating javadoc with a plugin [message #527284] |
Wed, 14 April 2010 12:23  |
I failed to associate a plugin containing javadoc for another plugin. Here's the detail:
I am using zest plugin, but since its update package(site) doesn't come with a separate javadoc plugin, I tried to generate one out of its source bundle via 'Project > Generate Javadoc...'. So far, the index.htm can be properly presented.
The reason I am doing this: CTRL+F2 on a class/method so that I can browse the javadoc in a browser, and as a plus I can wander around relevant APIs. It's more effective than simply reading from the popup javadoc info.
I noticed from some plugin within the platform that in order to achieve this I just have to create another plugin with "org.eclipse.pde.core.javadoc" extension point correctly implemented, and here's what I did:
<?eclipse version="3.4"?>
<plugin>
<extension
point="org.eclipse.pde.core.javadoc">
<javadoc
path="reference/api">
<plugin
id="org.eclipse.zest.core">
</plugin>
</javadoc>
</extension>
</plugin>
The generated javadoc files was placed under '<JAVADOC_PLUGIN_PROJECT_ROOT>/reference/api' and is configured to be exported in the binary build:
bin.includes = META-INF/,\
plugin.xml,\
reference/
The exported plugin seems correctly structured. I put it under the plugin directory, restarted eclipse, checked that the plugin was recognized by the platform, but CTRL+F2 doesn't work.
Re: Associating javadoc with a plugin [message #527289 is a reply to message #527284] |
Wed, 14 April 2010 12:39  |
More detail:
IDE: Rational Software Architect (RSA) for Websphere 7.5.4
feature version:
Eclipse RCP: 3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHcYBr4A63
Eclipse RCP: 3.4.100.v200809240100
Eclipse Platform: 3.4.2.R342_v20090122-9I96EiWElHi8lheoJKJIvhM3JfVsYbRrgVIWL
Also, I noticed that the "org.eclipse.platform.doc.isv" plugin has something "weird" in its MANIFEST.MF:
l
SHA1-Digest: XspTVzdwDSan+b7R8zYiLw8QOPc=
Is this relevant?
FUDForum. Page generated in 0.07087 seconds
