Home » Eclipse Projects » Standard Widget Toolkit (SWT) » TableColumn.setText - doesnt display '&' within String(TableColumn.setText - doesnt display '&' within String)
TableColumn.setText - doesnt display '&' within String [message #527243] Wed, 14 April 2010 10:54 Go to next message
String [] columns = new String [] {"id", "Text(Editable)","button","Text&(NoEdit)", "combo", "spinner", "progress"};
for (int i = 0; i < columns.length; ++i) {
final String colName = columns[i];
logger.debug("Adding Col "+colName);
TableColumn col = new TableColumn(table, SWT.NONE);
col.setAlignment(SWT.CENTER);
col.setText(colName);
col.setAlignment(SWT.LEFT);
creates table with column names:
id, Text(Editable),button,Text(NoEdit), combo, spinner, progress
My Logger does display Adding Col: Text&(NoEdit). But created table have column name as Text(NoEdit).
Please help me to fix this.
Jatin Vasa
Re: TableColumn.setText - doesnt display '&' within String [message #527249 is a reply to message #527243] Wed, 14 April 2010 11:07 Go to previous messageGo to next message
> column name as Text(NoEdit). Please help me to fix this.
You need to write && instead of &, if I remember correctly.
HTH & Greetings from Bremen,
Daniel Krügler
Re: TableColumn.setText - doesnt display '&' within String [message #527259 is a reply to message #527249] Wed, 14 April 2010 11:30 Go to previous messageGo to next message
Thanks Daniel
I tried that before. It doesn't work.
Jatin Vasa
Re: TableColumn.setText - doesnt display '&' within String [message #527378 is a reply to message #527259] Thu, 15 April 2010 02:09 Go to previous messageGo to next message
On 14.04.2010 17:30, Jatin wrote:
> Thanks Daniel
You are right, I just found that there is a open issue with this,
so vote for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154904
Daniel Krügler
Re: TableColumn.setText - doesnt display '&' within String [message #538538 is a reply to message #527378] Mon, 07 June 2010 17:58 Go to previous message
Hi Daniel
Any luck on above '&' issue. I am trying to display '&' on TableColumn. It doesn't show up.
Please help me if you have any turn around solution to this.
Jatin Vasa
Previous Topic:Whatever happend to the book "SWT: The Standard Widget Toolkit, Volume 2"?
Next Topic:Removing columns from viewers
Current Time: Sun Jul 20 09:47:22 EDT 2025
Powered by FUDForum. Page generated in 0.05646 seconds
