Home » Eclipse Projects » Rich Client Platform (RCP) » CommonNavigator (CNF) and CheckboxTreeViewer
CommonNavigator (CNF) and CheckboxTreeViewer [message #524936] Sun, 04 April 2010 09:29 Go to next message
Does anybody know if it is possible to use a CheckboxTreeViewer with the CNF? I wanted to take advantage of the CNF architecture (and declarative contributions) but I wanted to render checkboxes with each node.
Is this possible?
Re: CommonNavigator (CNF) and CheckboxTreeViewer [message #527228 is a reply to message #524936] Wed, 14 April 2010 10:18 Go to previous message
Hi Epoch,
Yes. Override this method of the navigator:
* Constructs and returns an instance of {@link CommonViewer}. The ID of the
* Eclipse view part will be used to create the viewer.
* Override this method if you want a subclass of the CommonViewer
* @param aParent
* A composite parent to contain the CommonViewer
* @return An instance of CommonViewer
* @since 3.4
protected CommonViewer createCommonViewerObject(Composite aParent) {
return new CommonViewer(getViewSite().getId(), aParent, SWT.CHECK
| SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL);
Best Regards,
Wim Jongman
-- ASCII question, get an ANSI!
(Eclipse Old Skool Quote Service)
> Is this possible?
Previous Topic:how to implement Zoom Bar in ScalableFreeformRootEditPart
Next Topic:Adding Checkbox in specific columns of nebula Grid Tree Viewer
Current Time: Sun Jul 20 08:12:47 EDT 2025
Powered by FUDForum. Page generated in 0.38280 seconds
