Home » Modeling » EMF » Quite empty editor project
Quite empty editor project [message #527031] Tue, 13 April 2010 14:39 Go to next message
--------------040805040903060707070602
I see something strange, when I create a genmodel for the attached ecore and generate the EMF code the editor project is
quite empty (only a plugin class that's all). I tried creating the genmodel from scratch but got the same result. Is
there a setting I am missing? I created the model project manually (so not through new emf project) but it is a standard
eclipse plugin project.
I am trying this on Eclipse 3.5.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Content-Type: text/xml;
name="texo-annotations-model.ecore"
Content-Disposition: inline;
filename="texo-annotations-model.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="annotationsmodel"
nsURI="http://www.eclipse.org/emf/texo/annotations/model" nsPrefix="annotationsmodel">
<eClassifiers xsi:type="ecore:EClass" name="ENamedElementAnnotation" abstract="true">
<eOperations name="getJavaAnnotation" eType="ecore:EDataType platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E String ">
<eParameters name="identifier" lowerBound="1" eType="ecore:EDataType platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E String "/>
</eOperations>
<eStructuralFeatures xsi:type="ecore:EReference" name="eNamedElement" lowerBound="1"
eType="ecore:EClass platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E NamedElement "/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EClassifierAnnotation" abstract="true"
eSuperTypes="#//ENamedElementAnnotation">
<eStructuralFeatures xsi:type="ecore:EReference" name="eClassifier" lowerBound="1"
eType="ecore:EClass platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E Classifier "
changeable="false" volatile="true" transient="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EClassAnnotation" abstract="true" eSuperTypes="#//EClassifierAnnotation">
<eStructuralFeatures xsi:type="ecore:EReference" name="eClass" lowerBound="1"
eType="ecore:EClass platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E Class "
<eStructuralFeatures xsi:type="ecore:EReference" name="eStructuralFeatureAnnotations"
upperBound="-1" eType="#//EStructuralFeatureAnnotation"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EDataTypeAnnotation" abstract="true"
<eStructuralFeatures xsi:type="ecore:EReference" name="eDataType" lowerBound="1"
eType="ecore:EClass platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E DataType "
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EStructuralFeatureAnnotation" abstract="true"
<eStructuralFeatures xsi:type="ecore:EReference" name="eStructuralFeature" lowerBound="1"
eType="ecore:EClass platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E StructuralFeature "
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EPackageAnnotation" abstract="true"
<eStructuralFeatures xsi:type="ecore:EReference" name="ePackage" lowerBound="1"
eType="ecore:EClass platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E Package "
<eStructuralFeatures xsi:type="ecore:EReference" name="eClassifierAnnotations"
upperBound="-1" eType="#//EClassifierAnnotation" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EReferenceAnnotation" abstract="true"
eSuperTypes="#//EStructuralFeatureAnnotation">
<eStructuralFeatures xsi:type="ecore:EReference" name="eReference" lowerBound="1"
eType="ecore:EClass platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E Reference "
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EAttributeAnnotation" abstract="true"
<eStructuralFeatures xsi:type="ecore:EReference" name="eAttribute" lowerBound="1"
eType="ecore:EClass platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E Attribute "
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EEnumAnnotation" abstract="true" eSuperTypes="#//EDataTypeAnnotation">
<eStructuralFeatures xsi:type="ecore:EReference" name="eEnum" lowerBound="1" eType="ecore:EClass platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E Enum "
</eClassifiers>
</ecore:EPackage>
--------------040805040903060707070602--
Re: Quite empty editor project [message #527061 is a reply to message #527031] Tue, 13 April 2010 16:25 Go to previous messageGo to next message
Martin,
All the classes are abstract so there are no classes the editor could
create.
Martin Taal wrote:
> ecore and generate the EMF code the editor project is quite empty
> scratch but got the same result. Is there a setting I am missing? I
> but it is a standard eclipse plugin project.
Re: Quite empty editor project [message #527065 is a reply to message #527061] Tue, 13 April 2010 17:03 Go to previous messageGo to next message
Thanks Ed, clear, my idea was/is to add the non-abstract subtypes through other models.
gr. Martin
Ed Merks wrote:
> Martin,
> create.
> Martin Taal wrote:
>> Hi,
The Netherlands
Re: Quite empty editor project [message #527066 is a reply to message #527065] Tue, 13 April 2010 17:08 Go to previous message
Martin,
In the past we didn't have the ability to contribute children via other
models. There remains the problem that the wizard can't create
anything so I guess we'd still not generate that...
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> create.
>> Martin Taal wrote:
>>> Hi,
Previous Topic:loading genmodel in separate java application
Next Topic:Teneo + GMF Exception: "Could not initialize a collection"
Current Time: Sun Jul 20 13:08:19 EDT 2025
Powered by FUDForum. Page generated in 0.05292 seconds
