Home » Eclipse Projects » Eclipse 4 » XWT. TreeViewer with TreeColumn.
XWT. TreeViewer with TreeColumn. [message #526947] Tue, 13 April 2010 10:43 Go to next message
Following code causes exception.
It seems that by some reason "headerVisible" is trying to apply to TreeColumn instead of Tree itself.
Same code, with replacement of word "Tree" with "Table" works without any problem.
<Shell xmlns="http://www.eclipse.org/xwt/presentation" xmlns:x="http://www.eclipse.org/xwt">
	<Shell.layout>
		<RowLayout/>
	</Shell.layout>
	<TreeViewer x:Style="BORDER">
		<TreeViewer.tree headerVisible="true" linesVisible="true">
			<TreeColumn text="New Column" width="100"/>
		</TreeViewer.tree>
	</TreeViewer>
</Shell>
java.lang.IllegalArgumentException: object is not an instance of declaring class
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.e4.xwt.javabean.metadata.properties.BeanProperty.setValue(BeanProperty.java:72)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.initSegmentAttribute(ResourceLoader.java:1610)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.initAttribute(ResourceLoader.java:1388)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.init(ResourceLoader.java:1056)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.initSegmentAttribute(ResourceLoader.java:1643)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:622)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:658)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.createCLRElement(ResourceLoader.java:363)
	at org.eclipse.e4.xwt.internal.core.Core.createCLRElement(Core.java:606)
	at org.eclipse.e4.xwt.internal.core.Core.load(Core.java:646)
	at org.eclipse.e4.xwt.internal.core.Core.load(Core.java:633)
	at org.eclipse.e4.xwt.XWTLoader.loadWithOptions(XWTLoader.java:835)
	at org.eclipse.e4.xwt.XWTLoader$1.run(XWTLoader.java:768)
	at org.eclipse.e4.xwt.XWTLoader.open(XWTLoader.java:762)
	at org.eclipse.e4.xwt.XWTLoader.open(XWTLoader.java:714)
	at org.eclipse.e4.xwt.XWT.open(XWT.java:416)
	at test.MyTest.main(MyTest.java:21)
[Updated on: Tue, 13 April 2010 11:06] by Moderator
Re: XWT. [message #527124 is a reply to message #526947] Wed, 14 April 2010 03:48 Go to previous message
The tests on Tree is limited. Please fill a bug and we will take care of it
ASAP.
yves
"Konstantin Scheglov" <Konstantin.Scheglov@gmail.com> wrote in message
news:hq1vv2$1t8$1@build.eclipse.org...
> problem.
> <Shell.layout>
> <RowLayout/>
> </Shell.layout>
> </TreeViewer.tree>
> </TreeViewer>
> </Shell>
> class
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> org.eclipse.e4.xwt.javabean.metadata.properties.BeanProperty .setValue(BeanProperty.java:72)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.initSegmentAttrib ute(ResourceLoader.java:1610)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.initAttribute(Res ourceLoader.java:1388)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.init(ResourceLoad er.java:1056)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.initSegmentAttrib ute(ResourceLoader.java:1643)
> at
> at
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(Resource Loader.java:622)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(Resource Loader.java:658)
> at
> org.eclipse.e4.xwt.javabean.ResourceLoader.createCLRElement( ResourceLoader.java:363)
> at org.eclipse.e4.xwt.internal.core.Core.createCLRElement(Core. java:606)
> at org.eclipse.e4.xwt.XWTLoader.loadWithOptions(XWTLoader.java: 835)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> Konstantin Scheglov,
> Instantiations, Inc.
Previous Topic:Default alignment of labels
Next Topic:XWT.
Current Time: Sat Jul 19 17:59:40 EDT 2025
Powered by FUDForum. Page generated in 0.03962 seconds
