Home » Eclipse Projects » Rich Client Platform (RCP) » TextEditor connection
TextEditor connection [message #526935] |
Tue, 13 April 2010 10:16  |
Hi All,
I am cross-posting on emf and rcp because I am actually asking two,
tightly bound, questions.
I need to connect a (simple) model to a TextEditor Syntax scanner.
More precisely I need:
1) highlight with a certain color/font all words in a certain list; list
is dynamic and list is in the model; color/font is in the model.
Usage case: I have a list of locations in the model and each time I type
in the Text Editor the name of a known place I want it highlighted in
the text. Of course I can add a location to the model and I want to have
the Text to be updated accordingly. I can have different classes of
locations, hence the different colors/fonts.
2) highlight with a certain color/font everything *between* two matched
tags; start-tag, end-tag and TextAttribute are in the model.
Usage case: implement several kind of semantic quoting in the Text: this
is a place description, this is a touristic information, this is
historical note, ...
I have tried using the usual partition/syntax scanners, but those have
(at least) two issues:
a) they are virtually static, I found no (easy) way to change them "on
the fly", while I would like to be able to add a new "location" or even
a new "semantic class" (adding them to the model, that's the easy part!)
while I'm typing in the TextEditor.
b) I would like to recognize the class (1) (keywords) even inside the
class (2) (semantic tagging), sometimes it would even make sense to nest
one semantic class into another (I am speaking about history and I then
insert info about a specific museum, which is touristic info).
All this doesn't seem possible with stock partition/syntax scanners.
Nearest thing I found would be to implement Semantic via
IDocumentPartitioner and Keyword using DefaultDamagerRepairer.
This approach still suffers from (a) and does not allow for nested
semantic sections.
Before I start (re)writing a huge portion of code:
Can someone tell me if something along these lines is available somewhere?
If the answer is "no": can someone tell me what is the "eclipse correct"
way to tackle the problem?
Thanks in advance.
Re: TextEditor connection [message #526964 is a reply to message #526935] |
Tue, 13 April 2010 11:04  |
--------------050300040209090600070302
Mauro,
Comments below.
Mauro Condarelli wrote:
> Hi All,
Sounds like a job for Xtext <http://www.eclipse.org/Xtext/>...
> list is dynamic and list is in the model; color/font is in the model.
> type in the Text Editor the name of a known place I want it
> highlighted in the text. Of course I can add a location to the model
> and I want to have the Text to be updated accordingly. I can have
> different classes of locations, hence the different colors/fonts.
> matched tags; start-tag, end-tag and TextAttribute are in the model.
> this is a place description, this is a touristic information, this is
> even a new "semantic class" (adding them to the model, that's the easy
> part!) while I'm typing in the TextEditor.
> nest one semantic class into another (I am speaking about history and
> I then insert info about a specific museum, which is touristic info).
> semantic sections.
> somewhere?
> correct" way to tackle the problem?
Before you write a line of code, you need to explore Xtext. It
generates everything you describe from BNF-style grammar.
> Thanks in advance.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Mauro,<br>
<br>
Comments below.<br>
<br>
<br>
<blockquote cite="mid:hq1ubo$p2d$1@build.eclipse.org" type="cite">Hi
All,
<br>
<br>
<br>
<br>
<br>
</blockquote>
Sounds like a job for <a href="http://www.eclipse.org/Xtext/">Xtext</a>...<br>
<blockquote cite="mid:hq1ubo$p2d$1@build.eclipse.org" type="cite"><br>
<br>
type in the Text Editor the name of a known place I want it highlighted
in the text. Of course I can add a location to the model and I want to
have the Text to be updated accordingly. I can have different classes
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
nest one semantic class into another (I am speaking about history and I
<br>
<br>
<br>
<br>
semantic sections.
<br>
<br>
<br>
somewhere?
<br>
<br>
</blockquote>
generates everything you describe from BNF-style grammar.<br>
Thanks in advance.
<br>
</blockquote>
</body>
</html>
--------------050300040209090600070302--
Current Time: Sat Jul 19 15:49:05 EDT 2025
Powered by FUDForum. Page generated in 0.45786 seconds
