Home » Eclipse Projects » Rich Client Platform (RCP) » How to refresh the enabledwhen status? A question about "IEvaluationService"?
How to refresh the enabledwhen status? A question about "IEvaluationService"? [message #526836] Tue, 13 April 2010 04:19 Go to next message
I have two commands "Power on" and "Power off" in a toolbar.
They should be like a switch. When poweron is enabled ,poweroff is disabled, and when poweroff is enabled poweron is disabled.
There are several objects (machines) in a treeviewer. The enabledwhen clause of the handler uses a property tester to test whether the object is "poweron" or "poweroff".
Now When I press the "Power on ", I did change the machine state to "poweron" but I couldn't refresh the enabledwhen status. I have to select another object in the treeviewer and reselect the machine object ,then the enabledwhen status is refreshed.
I tried to google and found the following code:
IEvaluationService service = (IEvaluationService)getSite.getService(IEvaluationService.class);
service.requestEvaluation("your.property.name");
I want to call these codes after a handler.execute is complete.
The getSite method seem could only be write in a viewer class.
Where should I write these codes?
I'm grateful for any help you can offer
WangYing
[Updated on: Tue, 13 April 2010 04:42] by Moderator
Re: How to refresh the enabledwhen status? A question about "IEvaluationService"? [message #526844 is a reply to message #526836] Tue, 13 April 2010 05:29 Go to previous message
Try IExecutionListener.postExecuteSuccess(). You need to register the
listener in the ICommandservice
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Previous Topic:Problem making section content scrollable
Next Topic:Tabs INSIDE a view??
Current Time: Sat Jul 19 11:29:19 EDT 2025
Powered by FUDForum. Page generated in 0.03751 seconds
